(#1676)
g0t2bmiirii's Avatar
Default 12-10-2017, 08:28 PM
Hoping within the weeks =)
-Catback + d0wnp1pes
-Stillen Cold Air Intake
-Jb4 (map 6)
jrobohm's Avatar
jrobohm jrobohm is offline
Default 12-10-2017, 08:37 PM
We've been helping a lot of Q50/Q60 customers via email and a lot of new Stage1 and JB4 systems are going out.
Our intakes came in but I wasn't happy with how one of the brackets turned out in the production run those remain pending. Hopefully ready before 2019.
And we've got some firmware updates we're evaluating on this end. Per usual, nothing to share publicly.
Better right than close enough - Thanks Terry!!
TorchikRS TorchikRS is offline
Car: 2016 Infiniti Q50 RS400
Default 12-11-2017, 01:04 AM
I hope I don’t have to settle for some Stillen intakes cuz that’s what it looks like ��
ralphie1313 ralphie1313 is offline
Car: 2018 q50 red sport
Default 12-11-2017, 05:26 AM
sorry for these types of ? I'm new to this stuff so I keep debating which to go with stage 1 or the jb4 I believe the difference is the stage one is set u cannot change settings, so my ? is on the jb4 is there all ready preset modes for different power levels or do u have to enter everything yourself?
thanks
jrobohm's Avatar
Default 12-11-2017, 05:48 AM
thanks
Think of the JB1 as a raw power boost - which you can adjust with a couple of parameters via a cable and/or usb connection to the JB4 application (see post #1.) The JB4 is the big brother version (or upgrade to a JB1) which includes all the JB1 features as well as CANbus Data via an additional connector. This additional data allows the JB4 to capture and log far more data points and thereby allow for fine tuning. Most folks start with the JB1 (seriously consider the JB4 Bluetooth Connector - very convenient) and then upgrade to the JB4.
BlueSleeper BlueSleeper is offline
Car: 2017 Q50 Red Sport
Default 12-11-2017, 09:54 AM
Yes, and if you would like to see what happens when "close enough" becomes the standard, just take a look at how that worked out for Stillen.
Terry, thanks for your conservative, get it right approach.
Default 12-11-2017, 10:05 AM
Originally Posted by TorchikRS
I hope I donít have to settle for some Stillen intakes cuz thatís what it looks like ��
It's just the nature of the intake business. There is still a chance we get everything perfect looking on this end, send a few out, and it turns out some specific DME software version or vehicle throws a fault with them that we didn't uncover in our testing. But the project is slowly chugging forward and we've got a warehouse full of awesome looking CNC machined intakes that *should* work perfectly, once a specific bracket is remade for them.
Default 12-11-2017, 10:18 AM
We wonít have to update our DME software version right?
-Jb4 (map 6)
Default 12-11-2017, 10:44 AM
If it turns out the intake problems are DME software version specific then that would become a factor. I expect and hope our design will work for all versions without issue.
Default 12-11-2017, 10:46 AM
thanks
The basic idea is the Stage1 is the sort of tuner you can buy, install in literally 2 minutes, and enjoy a nice power gain. The JB4 is a more advanced tuner with more user adjustment, maps, and features, but it costs $100 more and takes another 15-20min to install routing the OBDII cable.
Chiller Chiller is offline
Car: 2016 Q50 Silver Sport
Question water leak? - JB4? - 12-11-2017, 03:58 PM
Hey folks,
With the coming of colder weather, I've noticed condensation on the inside of my windows and wet carpet on the drivers side rear floor. Upon further inspection, it seems that there is dampness in the area around the grommet where I passed the cable through the firewall for the OBDII cable. Has anyone else had an issue with this? Any thoughts on an non-detectable way to seal it or an alternate way to pass the cable through? I've heard others have had issues with sunroof drains - so may be unrelated...comments welcome!
Default 12-11-2017, 04:27 PM
Originally Posted by Chiller
Hey folks,
Oh wow I have the same exact issue (rear driver seat) but I noticed mine when I went for a car wash, I have the weather tech mats and the guy told it out and he said you have water inside and it was soaked. Someone told me it could be the drain, I told it to my local mechanic to check the drains he said it looks fine the drain. So now since you mention by the grommet part I have not even checked that part to see if there was any moisture. I donít wanna take it to the dealer cause of the aftermarket parts I have.one of these days Iím gonna check the grommet area to see if there is any moisture around that area, Iíll post when if I do and if it crosses my mind Iíll take some pictures
-Jb4 (map 6)
Car: Infiniti Q50 RS400
Default 12-11-2017, 05:10 PM
Apply black or clear silicone sealant on the top part of the grommet.
Esco Esco is offline
Default 12-11-2017, 05:27 PM
Had the same exact issue. My drivers side rear mat had condensation on the bottom. After taking it to the dealership (had a horrible experience) and not having my car for a week they diagnosed the problem being the grommet that I installed my JB4 through. Per the dealer the groument had losen from the firewall and every time I would take it through the wash the following morning I would open my door only to smell mildew.
Default 12-11-2017, 06:23 PM
Yeah thatís probably what Iím gonna try next thanks man
-Jb4 (map 6)
RS400BLUE RS400BLUE is offline
Car: Q50 Red sport
Default 12-12-2017, 04:40 PM
I had the same problem and it was absolutely annoying. Now my car is smelling like water I need to fix that. Please help me figure out how to fix this grommet issue. Its pretty big issue.
Default 12-12-2017, 05:16 PM
Not had any issues here on the grommet and I do a drive through car wash weekly. But if you want to fully seal it push the grommet back in fully over the CANbus wire, which is relatively thin.
jrobohm's Avatar
Default 12-12-2017, 08:15 PM
Same here - no issues with car washes (granted I have not done an engine compartment cleaning.) As for the grommet - I did fully seal it as Terry suggested so that maybe the delta in why dozens of rainy driving and car washes has not resulted in water infiltration of the cabin.
ekpogi ekpogi is offline
Car: Infiniti Q50
Default Yesterday, 12:59 PM
I have no issues here as well, although i think car wash would pour more water into that area than engine cleaning.
Perhaps some people we're very excited to test out JB4 and didn't bother enough to properly secure the grommet in place Not to mention, putting back the grommet is also not as easy as it may seem.
jrobohm's Avatar
Default Yesterday, 01:39 PM
Here is a photo of my install for reference.
Default Today, 12:46 PM
My install looked very similar, in that the grommet appeared to be seated. There was no car wash or engine bay cleaning involved - just a very rainy night. The car was parked with the front end slightly elevated. Silicone, might be an option, but I would prefer a technique where nothing is left behind when the cable is removed....
Default Today, 12:53 PM
Are you sure anything is leaking in through that grommet? Seems unlikely given its placement. As a test maybe tape a paper towel or two there so we can figure out exactly how its getting in? One option might be to place the OBDII cable at the very bottom of the grommet so when you push it in the top part is more fully sealed if yours isn't currently.
