(#1626)
Herc Herc is offline
Car: F20 125i
Default 05-28-2018, 01:57 AM
brand new the X1 or the chip?
bucketfoot bucketfoot is offline
Car: 2014 BMW X1 28i xDrive
Default 05-28-2018, 06:52 AM
JB4
Default 05-28-2018, 10:13 AM
The X1 is a unique setup and we ship it with X1 firmware ready to go. It's harness is also different. You should not need to do anything but if settings were purged somehow trying to get connected then you'll just need to fix those. Set TMAP = 0 though.
Default 05-28-2018, 01:11 PM
Thanks, that's good to know, since I had set TMAP = 1 per the instructions on page 1 for EWG vs PWG
Default 05-29-2018, 04:18 PM
Still running into problems with the adjusted settings. Had two instances of it resetting to Map 0.
I'm attaching three logs:
The first one stopped logging before I saw any changes. Do the logs have a size/time limit? - This one ended up being to large to attach
The second and third are instances of the map changing from 1 to 0. The funny thing I don't see how I did anything that would have caused this as I was tooling along at 25 mph through a neighborhood in both instances.
Please let me know if anything else looks out of whack in the settings.
Also, what does it mean when the two turn signals (aka hazards) flash? This happened to me a couple of times when I put my foot into it.
Default 05-30-2018, 09:50 AM
I don't see that it should impact anything, but one added note is that I am using the bluetooth adapter.
Default 05-30-2018, 12:24 PM
Let's start with the basics. I used this information from page 1 of the thread to configure my JB4 (see attachment).
Combined with setting TMAP = 0 per Terry, is this the correct configuration for the X1?
If not, can you point me to where I can get the correct information.
Default 05-30-2018, 12:30 PM
Tmap is value at 1, should be at 0 IIRC.
Default 05-30-2018, 12:52 PM
I'll double-check that.
I know I went in and set it to 0 after Terry told me that was what it should be.
Default 05-30-2018, 01:08 PM
Verified that N20 TMAP = 0 (could the 1 you are seeing be the TMAP Voltage?), but I did find that Auto Shift Boost Reduction was set to 0 rather than 10.
I changed that, but won't get a chance to try things until I leave work.
Default 05-30-2018, 03:17 PM
No worries, try that for now and report back. Make a thread in the support section so we can get back to you there.
Default 05-30-2018, 03:35 PM
It's only one trip, but this was the first time I completed my commute home or to work with without the map changing.
Default 05-30-2018, 03:38 PM
Okay perfect, that's a good sign then!
Default 05-30-2018, 03:46 PM
I've noticed my hazards flash when I really put my foot into it. Is this an RPM related warning, as it looks like it is happening at about 6500 RPM?
Default 05-31-2018, 05:00 PM
Thanks, had one good trip but then had the issue again this morning (unfortunately didn't get a log for it). So as suggested I started a thread in the support section.
Default 05-31-2018, 08:50 PM
I'll take a look
