PrzeChuj PrzeChuj is offline
Car: 08 335i
Exclamation WMI Bogging motor ???? Any Help - 09-07-2017, 02:59 AM
So here is what i have going on just finished installing a WMI on 08 335i FBO with Pump BEF currently Irma has cut my supply of E85 short currently .
Im running a devils own pump and solinoid with BMS FSB and currently one DO5 nozzle.
First issue i had was a bad FSB and after some trouble shooting the crew at BMS sent me a new one and the system works , I can purge and everything is running perfectly at a stand still. I put it in map 3 and try to log but as soon as the WMI turns on my motor boggs down the rpms drop almost as if the WMI is killling my spark and WMI shuts off completely and it wont turn on untill i let of the gas and try again. Same goes for map 7. I started with two Do5 nozzles but it was alot worse so i figured i will get one running before stepping up to two nozzles. About 2k ago i replaced spark plugs ( NGKR gapped to 0.022" and new coils just to keep the ignition in top shape )
Any map without WMI performs flawlessly im only having issues getting the car to pull on WMI. I have all my settings on default 40 60 and played around changing the psi acctivation point without any success. I will be regapping my plugs after work to 0.02" to see if it helps . I have my thank filled with 50/50 distilled water and denatured alchol. Initially my first two or three pulls performed perfectly with the injection and ever since those i cant get my car like it.
Any one can chime in and give me some advice or a direction to go in. I included a log with the motor chocking for life and one from map 2 that was taken right afterwards.
e92 MT 08
FBO
450 lpfp
BEF
Car: 08 335i
Default 09-07-2017, 03:02 AM
i did get a 30fc just once trying to run it in map 7 but can not get it to repeat it again. Never get the code before or after the one time. all my vacuum lines are new as are my orings for ic and charge pipe.
e92 MT 08
FBO
450 lpfp
BEF
Default 09-07-2017, 08:11 AM
First...meth scale is set wrong..it should be 60.
Second...meth won't flow on map 2 and your map 7 log is too short to see anything.
Car: 08 335i
Default 09-07-2017, 08:42 AM
Thanks Steve I will make changes to the scaling after work. Map 2 was just a log afterwards to make sure all is well with the motor I was not expecting any meth on the log just a diagnostic logs for all functionsand verify there is no other present issues.
e92 MT 08
FBO
450 lpfp
BEF
Car: 08 335i
Default 09-07-2017, 06:29 PM
So I checked my settings and my scaling was set to 60 and I have 40 on boost additive as per BMS instructions. I gave map 3 two tries after work and the issue persist. When I got home I pulled my plugs and dropped the gap from 0.022 to 0.02 and went for a drive. It still boggs the motor down but only once before everything works correctly including meth flow. I only get this bogging as soon as meth starts to flow. Any suggestions on how to get rid of it. I will do some logs in the morning and get them posted to put more light on the situation
e92 MT 08
FBO
450 lpfp
BEF
Default 09-07-2017, 09:57 PM
It wasn't set to 60 in the logs. One was set to 45 and the other was set to 50.
You'll need to upload a log with the proper settings for review.
Car: 08 335i
Default 09-08-2017, 03:40 AM
sorry Steve u are correct. I changed it afterwards and just slipped my mind . But here are three logs that i was able to get today. Hopefully it can shed some light.
e92 MT 08
FBO
450 lpfp
BEF
Default 09-08-2017, 07:03 PM
Of those 3 logs...one is decent.
It looks pretty normal, FF just needs to learn down a bit.
Car: 08 335i
Default 09-08-2017, 07:14 PM
I think I gunned it from second on that log . But my hesitation problem persist as soon as meth kick on. Flow goes straight to 100 is it possible my pump is cranked up to high. I'm only using a single DO5 nozzle. It almost feels like the motor is dying with the meth and kick back on a split second later. I have one more perfect day to log left street in Tampa Bay are empty after everyone evacuated . So it's perfect logging season atleast rill the storm comes.
e92 MT 08
FBO
450 lpfp
BEF
Car: 08 335i
Default 09-08-2017, 07:16 PM
Don't need no pickup to get plywood for Windows when a 335i can haul ass and hauls wood
e92 MT 08
FBO
450 lpfp
BEF
Default 09-08-2017, 07:43 PM
Screenshot of WMI tab?
Car: 08 335i
Default 09-08-2017, 07:56 PM
Here u go sir
e92 MT 08
FBO
450 lpfp
BEF
Car: 08 335i
Default 09-08-2017, 07:57 PM
Hope it looks better one at a time
e92 MT 08
FBO
450 lpfp
BEF
Car: 08 335i
Default 09-08-2017, 07:59 PM
1
e92 MT 08
FBO
450 lpfp
BEF
Default 09-10-2017, 09:53 PM
Don't see any issues there...thought maybe you had some external trigger settings enabled. Disable those ethanol setup parameters and set min flow boost to 8.
Something is strange but can't put my finger on what is causing it. Lets see if those changes have any affect.
Car: 08 335i
Default 09-11-2017, 07:08 AM
Ok will do for next log. I reset the virual senosor to zero and it keeps setting it self back
e92 MT 08
FBO
450 lpfp
BEF
Default 09-11-2017, 05:16 PM
Virtual sensor is no problem.
Car: 08 335i
Default 09-14-2017, 04:12 AM
So I got virtual sensor reset to zero. Set min flow to 8 . I made a few runs and same issue persist. Once I hit tatget boost meth flow goes to 100 and motor boggs down or missed a beat. Tried logging it but the log only gets the WOT portion maybe a second but does not log the meth bogging the motor down. Is it possible to much pressure is being applied causing a heavy flow . I'm running a single DO5 for now i removed the other DO5 nozzle untill I can get some results. Is there any recommended psi I should be getting at the nozzle? I have a pressure gauge after solinoid and before nozzle so I can pretty accuratetly set the output psi.
e92 MT 08
FBO
450 lpfp
BEF
Default 09-14-2017, 09:35 AM
Deselect "Log Heavy Throttle Only" and try another log for review.
Car: 08 335i
Default 09-14-2017, 09:42 AM
Did not think of that. I will give that a shot in the morning I don't have my laptop with me. Thanks Steve
e92 MT 08
FBO
450 lpfp
BEF
Car: 08 335i
Default 09-15-2017, 02:54 AM
Here is a fourth gear log. I have a third but file wsa slightly to big. hope it can shine some light
e92 MT 08
FBO
450 lpfp
BEF
Default 09-15-2017, 11:17 AM
I'm not sure what your issue is...looks like you have some sort of communication issue.
Do you have anything else plugged in to the CANbus?
Car: 08 335i
Default 09-15-2017, 11:25 AM
Nothing else is plugged in . I ordered some boost juice today to see if anything will change I'm currently running 50/50 denatured alchol and distilled water. My first fsb did not work and this is a replacement from bms. On changes I can think of is Terry had me jump out two resistors on jb4 when trouble shooting but I doubt that has any affect to my issue. I try to get a better log in third today , it does it more aggressive ly then in fourth
e92 MT 08
FBO
450 lpfp
BEF
Car: 08 335i
Default 09-15-2017, 01:12 PM
here are two more logs of the problem im having. youtube link is a video showing the problem that im talking about. second log is the video.
https://www.youtube.com/watch?v=PGFY7X2wI7E
e92 MT 08
FBO
450 lpfp
BEF
Default 09-17-2017, 03:21 PM
I can't tell anything from the logs. Appears to me something isn't wired correctly or ??? Meth signal isn't correct.
