laptop4079 laptop4079 is offline
Car: 2007 335i
Default Killed an o2 sensor? - 07-13-2018, 07:15 PM
Hello everyone, back again with another weird problem. I recently installed the ** fix and when I started it for the first time I checked both banks of o2 sensors and they were reading fine. So I took it on a test drive and within 5 miles she started running really rough and misfiring so I turned around and looked at my jb4 app and bank one was still reading fine but bank 2 was stuck at 20. I get home and remove the fix and reset adaptations and it's still stuck at 20 and running rough. When I clear the codes it smooths out momentarily and then gets rough again. I don't believe in coincidences did I mess up some simple wiring and killed an o2 sensor?
Another thing I'll add. I didn't have my secondary o2 sensors plugged in when I installed the fix because I thought I didn't need them.
Default 07-16-2018, 08:46 AM
Plug the secondary and reset adaptation and see if it fixes it. Sounds like you might have fried your O2 though
Car: 2007 335i
Default 07-16-2018, 08:52 AM
Sorry I forgot to update the thread. I bit the bullet and bought a bosch sensor from the parts store and it fixed it. Only replaced one because I'm planning on getting the adv o2's soon. She's happy again for now haha
Dave @ Fuel-it!'s Avatar
Default 07-16-2018, 10:55 PM
I currently run the ADV O2s - pricey but seem to do the trick.
Hopeflly you donít burn up the OEM sensor, but if you do, ADV might be worth considering.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
