Newguy123's Avatar
Car: 12' 135i
Default 12-31-2016, 08:16 AM
1.***sooba
2.andym3100k
3.newguy123
4.
5.
12' DCT 135i
#PURETURBOS
#FUELIT
Jeffrey Jeffrey is offline
Car: 335
Default 12-31-2016, 09:21 PM
8 or 6 bolt option?
phil1320 phil1320 is offline
Car: 2011 335is
Default 01-01-2017, 01:31 AM
What type of weight are we talking about with the MFactory version?
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 01-01-2017, 02:00 AM
According to the YCW website its a 21lb flywheel for the m/t
So i am guessing about the same for the dct?
I am sure Stepehen will have more info once he gets his sample
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
MFactory MFactory is offline
Car: BMW E92 M3
Default 01-01-2017, 02:13 AM
Originally Posted by Jeffrey
8 or 6 bolt option?
The sample we are being sent I believe is an 8-Bolt, but if there is enough interest in both fitments, we can do both easily enough (must have enough interest though)
Car: 335
Default 01-01-2017, 03:46 AM
Okay if 8 is the first round then add me to the list!
katsooba's Avatar
Car: 135i N55 DCT
Default 01-01-2017, 04:14 AM
Judging by the op, seems like it is a 6 bolt
Or am i missing something?
Realoem also states 6 mounting bolts
Car: BMW E92 M3
Default 01-01-2017, 07:01 AM
He has various spare flywheels, so need to confirm which one it is that I'm being sent.
katsooba's Avatar
Car: 135i N55 DCT
Default 01-01-2017, 10:46 AM
well, according to this
http://www.realoem.com/bmw/enUS/partxref?q=21207590853
and this
http://www.realoem.com/bmw/enUS/part...829&series=F87
seems like the DCT for the E92 E82
and all new M cars are 6 bolts.
i guess time will tell
keep us posted
Kish2604's Avatar
Kish2604 Kish2604 is offline
Default 01-01-2017, 02:57 PM
Add me to the list... I will take one...
|RB old gen|Jb4 G5|3" **'s|ER Competition Cooler|ER Charge pipe|Tial BOV|CM Meth Kit|Dual nozzle setup|BMS cowl filters|AFE intakes+scoops|
|BMS low temp oil thermo|MHD flash + coding|HnR Springs|M3 Control arm kit + H&R + Koni|LED Angel eyes+plate lights
Car: F06 N55 640i Gran Coupe
Default 01-02-2017, 02:43 AM
Yes is a 8 bolt unit from my Y09 E92 335i DCT.
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS ** n FULL Custom Exhaust
Custom BC forge 18/17 set up
Default 01-02-2017, 02:46 AM
1.***sooba
2.andym3100k 2-3sets
3.newguy123
4.Jeffery
5.kish2604
6.
saddart saddart is offline
Default 01-02-2017, 07:22 AM
1.***sooba
3.newguy123
4.Jeffery
5.kish2604
6.saddart
katsooba's Avatar
Car: 135i N55 DCT
Default 01-02-2017, 07:46 AM
Hi Andy,
are you sure its an 8 bolt?
couldnt find an 8 bolt DCT flywheel on realoem
Default 01-03-2017, 02:28 AM
Originally Posted by ***sooba
Hi Andy,
Alright allow me to go back to the workshop & check it out, will update tomo.
Car: 2011 335is
Default 01-03-2017, 06:55 AM
1. ***sooba
2. andym3100k 2-3sets
3. newguy123
4. Jeffery
5. kish2604
6. saddart
7. Phil1320
Default 01-04-2017, 04:42 AM
Hi Andy,
Hi Sooba, mine confirmed is a 8 bolts flywheel.
katsooba's Avatar
Car: 135i N55 DCT
Default 01-04-2017, 05:11 AM
Hi Andy
Thank you for the update
If it is an 8 bolt flywheel then i am out of the list
As in the op post, and by realoem, i have the 6 bolt engine flywheel and so does every other dct owner
Couldnt even seem to find an 8 bolt flywheel for the n54/n55 motors.
So until we have a flywheel option as in the OP
I am out.
Good luck guys!
Car: 335
Default 01-04-2017, 06:32 AM
Thanks for confirming! I'm good to stay on the list
Car: 2011 335is
Default 01-04-2017, 07:41 AM
How do you find out on Real OEM? I found the flywheel, I'm assuming it is a 6 bolt flywheel since it says I need 6 "ISA Screws" for repair? If so, I'm out of the group buy
Car: 335
Default 01-04-2017, 07:50 AM
I'm sure a lot of guys on the list didn't check what they have. Everyone please check before adding yourself. Pretty sure the list will be 2-3 left.
katsooba's Avatar
Car: 135i N55 DCT
Default 01-04-2017, 07:58 AM
well, by the op, it seems that M2\M3\M4 cars are 6 bolts and so is his car.
so after checking in realoem i assumed everyone has the 6 bolt flywheel
but andy send MFactory an 8 bolt flywheel.
in all of my searches i couldnt find the 8 bolt flywheel.
Car: 2011 335is
Default 01-04-2017, 08:13 AM
I'm not sure why some would have a 8 bolt flywheel? That would mean a whole different crank and as far as I'm aware all of the N54 use the same crank?
Default 01-04-2017, 08:22 AM
This is what I have.... (edit can't attached pic thru my phone but confirmed is a 8bolts)
I thought MFactory mentioned if there are more demand, making a 6 or 8 bolts don't mean much different for them. Pls look at MFactory post #30. No??? By looking at the bolts spacing, making a 6 or 8 bolts really isn't anything difficult, maybe MFactory can voice up.
Car: 335
Default 01-04-2017, 08:32 AM
I thought MFactory mentioned if there are more demand, making a 6 or 8 bolts don't mean much different for them. No?
That is correct. Also what car did the flywheel come from? Might help people. Thanks!
Some are 8 bolt and others are 6.
