Willyb84 Willyb84 is offline
Car: 2011 BMW 335xi
Default N55 JB4 Wastegate settings - 07-14-2018, 05:47 AM
My car is not working correct because my wastegate setting are off
Should I reset to the default settings of wastegate position to 60 and if so and my cars FF/ wastegate adaptation does not go to 100 is something wrong with the solenoid or something else? Thanks
Default 07-16-2018, 05:40 PM
First step in any diagnostic is to attach a JB4 log of whatever problem you are having is.
Nothing you said in your post indicates any issue. DWP=60 is default, FF learns as needed to keep boost on target.
Car: 2011 BMW 335xi
Default 07-17-2018, 05:07 AM
i have some logs now sorry it took so long
my issue is that ive changed my DWP from 40 to 80 and everywhere in between yet my FF never changes from 43. do you know what could cause this?
thanks for having a look at the logs for me if you need anything else let me know and il get it ASAP
File Type: csv 2018-06-27 18_14_04 fuel issue hpfp.csv (20.8 KB, 13 views)
