F56Maximuz's Avatar
F56Maximuz F56Maximuz is offline
Car: Mini S F56
Exclamation F25 35i N55 Logs - 10-12-2017, 11:38 AM
Hi friends, I have a BMW F25 35i, mod´s i have:
1) GFB - BOV
2) FTP - CHARGE PIPE + BOOST PIPE
3) CM DOWN PIPE
4) VIBRANT 3´ RESONATORS
5) JB4 + BT CONNECTION KIT
I HAVE SOME ISSUES, I CAN GET A STABLE BOOST CONTROL, I HAVE NO BOOST LEAKS, NEW BOOST SOLENOID, NEW VACUUM LINES.
I SEND MY LOG FILE.
ANY HELP PLS.
BMW F25 35i Burger tuned.....
Default 10-12-2017, 04:45 PM
Poor communications....you might need to slow down the canbus rate with the FUD bits. Nothing else in the OBDII port and no other accessories correct? Connect kit powered properly?
F56Maximuz's Avatar
Car: Mini S F56
Default 10-12-2017, 05:11 PM
Ok, I will slow down the can bus rate; no, i have nothing in the OBDII, just the JB4, Connect kit well powered (Good ground and 12v connection).
The can bus rate is on the menu from the Ios App?
How can I slow down the bus rate by the IOS App or the pc ? BMW F25 does not have the Dash and control wheel active.
F56Maximuz's Avatar
Car: Mini S F56
Default 10-12-2017, 05:56 PM
Perfect, I get it, now holds perfect the boost thanks ����
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 10-12-2017, 06:11 PM
any new logs?
F56Maximuz's Avatar
Car: Mini S F56
Default 10-12-2017, 06:13 PM
I will upload new log’s asap.
Default 10-12-2017, 07:15 PM
Check your JB4 mobile install guide...it should not be 12 volts.
F56Maximuz's Avatar
Car: Mini S F56
Thumbs up 10-13-2017, 12:15 AM
The new log’s
It is beter.......
Default 10-14-2017, 11:04 AM
Looks pretty normal, a little DB tuning may help hold a bit more boost up top.
Frikiton's Avatar
Default 10-14-2017, 11:46 AM
What about Map2 ?
Default 10-15-2017, 03:25 PM
Map 2 and map 5 look pretty similar.
F56Maximuz's Avatar
Car: Mini S F56
Default 10-15-2017, 04:21 PM
Why is so similar, map2 = 12 psi and map5 = 15 psi right ?
It’s something wrong in the JB4 ?
Default 10-15-2017, 10:21 PM
Similar curve, with a slight difference in target boost. Map 2 will likely be more consistent with slightly higher boost target based on current map 5 learning. Map 2 was targeting 14psi at tip in and then tapering.
