mcamera mcamera is offline
Car: 2013 BMW 335i
Default Missing at WOT - 10-12-2017, 09:19 AM
My car occasionally misses at WOT. I've attached a clean, full 3rd gear run and a run where the car stumbles during WOT. It didn't stumble as badly as it has in the past. Usually I floor it and the car has no power, and then there's a lot of abnormal crackling from the exhaust as I back off the throttle.
2013 335i (early build PWG)
N55
93oct fuel
6sp manual
62k miles
BMS Intake
VSRF hollow midpipe
M-sport catback
JB4 on Map 2
NGK 5992 1-Step Colder Spark Plug gapped at 0.022"
Default 10-12-2017, 04:42 PM
You need to update your firmware before going any further...that is really old firmware. Raise your FOL to 70 when you do.
Car: 2013 BMW 335i
Default 10-13-2017, 05:06 AM
I updated the firmware and changed FOL to 70. I wasn't able to get a 3rd gear run in this morning, but here is a great log showing the loss of power I'm feeling.
Car: 2013 BMW 335i
Default 10-14-2017, 07:24 AM
A check engine light and error code 180001 popped up twice yesterday for having a hollow midpipe. I was on map 1 and map 5 when it came on. Aren't those maps supposed to suppress the CEL for a hollow midpipe? It hasn't done that the last 6 months until I updated the firmware yesterday. Do I need to activate the CEL suppression somehow?
Default 10-15-2017, 12:00 PM
Trims are maxed out and you are running lean. Raise FOL to 90 and see if that helps.
JB4 can clear codes but is not a long term fix for running C-less.
http://www.n54tech.com/forums/showthread.php?t=47748
Car: 2013 BMW 335i
Default 10-17-2017, 06:39 AM
I raised my FOL to 90.
I noticed my trims are still maxed out on a short run on Map 2 (attached) and didn't want to do a high rpm run while lean. I did a longer run on Map 1 to see if lowering the boost helps (attached). Looks like Map 1 also maxes out trims for a while but comes down a little during the run.
Is it safe for me to run Map 1 currently? I have a 400 mile road rally this weekend and need to find something safe to run by Friday. I have more time to figure the Map 2 problems.
Thanks,
Mike
Default 10-17-2017, 08:00 PM
Correct...trims are still high. I'd suspect there is something else contributing to that. Injector, intake leak, ???
If possible, I'd try resetting adaptions. You could also try map 6 at 12psi or so and see how that looks.
Car: 2013 BMW 335i
Default 10-17-2017, 08:45 PM
How do I reset adaptations on an F30 N55? I'm seeing different methods but mainly for N54.
Car: 2013 BMW 335i
Default 10-18-2017, 07:34 AM
Hey Steve,
I reset my adaptations this morning and did another log on Map 1 (attached). I'm still maxing out my trims from 2400-3600rpm. I'm hitting a peak boost of 11.5psi, so I'm not sure increasing that to 12psi on Map 6 will help. Unless there's something special about Map 6 I don't know?
Do you think an injector could be dead or clogged? I've run fuel cleaner through the car twice in the last 6 months. My fuel pressure looks fairly low though which I would think means no large restrictions (clogged injector).
I'll check for vacuum leaks tonight.
Thanks for your help so far!
Dave @ Fuel-it!'s Avatar
Default 10-18-2017, 04:17 PM
I don’t see an updated log?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Pure Turbos
TFT Inlet System
Fueling by Fuel-It!
Car: 2013 BMW 335i
Default 10-18-2017, 04:54 PM
I swear I attached it this morning. Sorry, here it is. Couldn't find any obvious vacuum leaks on top of the engine.
Default 10-18-2017, 09:45 PM
Trims still maxing, and AFR looks pretty lean..
e92 AT 335xi 2.0
Pure Turbos
TFT Inlet System
Fueling by Fuel-It!
Car: 2013 BMW 335i
Default 10-19-2017, 10:38 AM
I put my factory intake back on to eliminate another variable. Ran Map 1. The range of maxing out trims got a lot smaller but it's still happening.
Did a run on Map 4 through my trouble area (2000-3000rpm). Trims stayed under 41, but my afr is still in the 14's. Is that safe for 2-3k? I'll run Map 4 this weekend for my rally if I don't find a leak tomorrow. Should I bump my FOL from 90 up to 95 or 100 to help?
Checking my exhaust midpipe for leaks tomorrow morning. It's the only other thing I've touched. Other than that, sounds like I'll have to drop the car off at the shop to diagnose a vacuum leak or dead injector. I still have no misfires or codes.
Attached datalogs.
Car: 2013 BMW 335i
Default 11-14-2017, 06:10 PM
Had to wait 3 weeks to get into the dealer but finally did. They replaced my lpfp under a recall but wouldn't check anything else on my car since it has a tuner and hollow midpipe. My fuel trims did come down some but I'm still able to hit 49 with Map 1 and 2.
I've attached a 3rd gear run for Map 1 and 2.
Is it safe for me to run Map 1?
Default 11-15-2017, 08:03 AM
Map 1 looks fine. Trims are high but not maxed out.
WaqasRiyami's Avatar
WaqasRiyami WaqasRiyami is offline
Car: Bmw 535i - 2011
Default 11-15-2017, 08:20 AM
@steve
sorry to intrude this thread but i have a question in reading the logs
in his map 1 - the target was exactly -4 to the boost
** so if the boost was 10 the target was 6 **
but in his map 2 - the boost was ether equal to target or lower
what dose that mean ?
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | TREBILA BEF Tune | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/XEO6ZpR.jpg |
Coming Soon: | Pure Stage 2 Turbo | Custom High Flow Inlet | GFB DV+ | Fuel-It Stage 2 LPFP | N20 3.5bar TMAP Sensor
Default 11-16-2017, 01:21 AM
Originally Posted by WaqasRiyami
@steve
**so if the boost was 10 the target was 6 **
bump, any one ?
Car: 2013 BMW 335i
Default 01-23-2018, 07:38 PM
Could you please check my attached datalog for any issues?
I figure this thread may help somebody else in the future so here's what's been going on. For reference, I have a 2013 F30 335i with the early build pneumatic wastegate (PWG).
My car has still been stuttering under med-hard throttle. Even with the JB4 on Map 0 (disabled/stock). After talking to my local dealership, they agreed to diagnose the car if I took off the JB4 and my BMS intake. They were not worried about my c-less midpipe so I left that installed. After having the car for a week and the shop manager driving it home a few times, they couldn't recreate the stuttering. The car also passed inspection and some misfire test they performed at the dealership. I've had the car back for 3 weeks now and haven't had any stuttering issues without the JB4 installed. To summarize:
JB4 Map 1 + BMS intake + hollow midpipe = stutter
JB4 Map 0 + BMS intake + hollow midpipe = stutter
JB4 Map 0 + hollow midpipe = stutter
just a hollow midpipe = normal
So I believe that even though the JB4 was on Map 0 (disabled), it was still causing an issue by being installed.
I mailed my tuner to BMS to diagnose it for issues. No issues were found. After talking to Terry at BMS, he suggested there might be an issue with how my JB4 is controlling the PWG. So he gave me an EWG board to swap into my tuner, even though my car is a PWG. With the EWG board installed, my JB4 doesn't need to connect to the wastegate solenoid any more like my old JB4 did. Eliminating what Terry thought might be the issue. I installed the tuner again a few days ago, uploaded the latest PWG firmware to the EWG board, and everything seems to be working well again. I've had no stuttering and power delivery seems smoother overall so far.
Default 01-24-2018, 06:15 AM
If you have been working with Terry, I would suggest continuing to do so. Since your case is different, nobody else is going to know what is going on with it.
