Wuz Wuz is offline
Car: BMW
Default Help with my 535i - 10-10-2017, 06:43 PM
Hi guys. I have a 09 535i that has turned into a total nightmare.
The car's rev's surge and eventully the car shuts off after a couple of minutes. See the video. The following codes are what i'm getting. This car is 100% stock no mods ever done
3100 - Boost pressure control 2
2DEB - Power-management power failure
2AA3 - Camshaft sensor exhaust, loss
2AA2 - Intake camshaft sensor, gap loss
2ACB - DME relay short circuit
2CEF - Throttle actuator
2D09 - Throttle
2F9A - Ambient temp sensor (sensor's missing already have that part in just haven't plugged it in)
Video: https://www.youtube.com/watch?v=PMIPa9ke_SY
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 10-10-2017, 07:06 PM
Mods and tuning?
Have you already searched this site for those codes and/ or done any troubleshooting?
2009 535i Sport
Wuz Wuz is offline
Car: BMW
Default 10-10-2017, 07:12 PM
Originally Posted by LessIsMore
Mods and tuning?
nope no mods at all. I got the crankshaft sensor replaced, waste of 115 bucks. made no difference. Vanos are clean too
Wuz Wuz is offline
Car: BMW
Originally Posted by E36graduate
No a professional but trying to help.....
if you have a tune on, shut it off......you probably already did that! My car had an episode like that once and it was because I shorted out my jb4 which also shorted out my TMAP sensor at the DME.. All hell broke loose then. Shut off jb4, grounded tmap and everything is fine.
Battery good and charged?
No mods or tunes at all. Battery is almost dead, but i tried with another and the problem is the same
Wuz Wuz is offline
Car: BMW
Default 10-10-2017, 07:23 PM
Why not plug in temp sensor - reset codes and check codes again?
I thought that would be useless, but I'll give it a try. I get a message on the dash saying it's -40 outside.
Wuz Wuz is offline
Car: BMW
Default 10-10-2017, 07:51 PM
Probably is.....not sure if it affects anything other than the temp gauge.....I was thinking it was somethings else, sorry.
Something is up with your throttle control, agree? Do you have any boost leaks before the throttle? Charge pipe leaking?
I literally have no idea. It was leaking oil from the oil filter housing. Got that gasket replaced and the oil cooler was messed up too and replaced. After that it started to have problems
LessIsMore's Avatar
Inner Circle Member
Default 10-11-2017, 10:43 AM
A low battery charge can definitely make a bunch of random codes show up all the sudden. Are you sure the newer battery you put in was good? Low battery seems like the most likely cause of all those codes coming up all the sudden, especially in cold weather. Unless your DME got wet or something.
Clear all the codes, see if they return.
if so, search this site and other forums for the codes you are getting, to see what are the common causes and fixes.
2009 535i Sport
Wuz Wuz is offline
Car: BMW
Default 10-11-2017, 01:14 PM
I need a new battery for sure. Will the one on the picture work?
casterson's Avatar
casterson casterson is offline
Car: Audi A5
Default 10-11-2017, 01:51 PM
So is the battery definitely the issue?
Wuz Wuz is offline
Car: BMW
Default 10-11-2017, 02:03 PM
I doubt it, when I got the car it had the same battery and it didn't give any codes or issues, besides the oil leak. it's not the BMW battery, it looks like a normal size Camry or Accord battery.
LessIsMore's Avatar
Inner Circle Member
Default 10-11-2017, 02:24 PM
After installing a new battery, you also need to register the new battery to the car using MHD or INPA, or at dealership.
2009 535i Sport
Wuz Wuz is offline
Car: BMW
Default 10-11-2017, 03:09 PM
I know, but I don't think the battery will make a difference because these problems came after the gasket and oil cooler were replaced
LessIsMore's Avatar
Inner Circle Member
Default 10-12-2017, 08:35 AM
I don't see how the OFHG or oil cooler could cause the codes you are seeing. Maybe something else was damaged/disconnected during the install ...
It seems like an electrical issue, not a hardware issue to me. Check for blown fuses.
This thread seems like it may be similar symptoms:
http://www.n54tech.com/forums/showthread.php?t=36083
2009 535i Sport
Wuz Wuz is offline
Car: BMW
Default 10-12-2017, 08:47 AM
What fuse can it be? I think it may be a electrical issue too, just can't figure it out. I drove the car yesterday and after going about 1000ft the car lost power and completely shut off. It wouldn't start back up just kept cranking. It did eventually start but that was after 5-10 min
LessIsMore's Avatar
Inner Circle Member
Default 11-10-2017, 10:01 AM
OP, any update?
Have you tried resetting adaptations with MHD or INPA? Also clear 'other module codes'. See if that changes the behavior and/or codes.
2009 535i Sport
Wuz Wuz is offline
Car: BMW
Default 11-10-2017, 10:10 AM
OP, any update?
Nothing yet, put a new throttle body and reset adaption and still nothing. The throttle body doesn't do it's click sound where it opens and closes. All the connections have power going through
BrownPower's Avatar
BrownPower BrownPower is offline
Car: 2008 535i
Default 11-11-2017, 01:57 AM
if checking the fuse panels didn't solve your problem, there is a series of 5 larger fuses inside the DME box. I had some similar codes and it turned out one of those were blown. My car did not start though.
Located in Toronto
Cars:
2006 Saab 9-3 Aero 335whp+390wtq
2008 BMW 535i; JB4, MHD PUMP BEF, DCI, VRSF **, ER CP TIAL BOV, BMS FSB METH KIT
turboalb's Avatar
turboalb turboalb is offline
Car: 08' 535i
Default 11-11-2017, 03:09 AM
It seem like this are ghost codes, Dme relay would definitely cause a no start issue. Check grounds and trace back anything that was touched when it was at the shop
08' 535i sport auto, jb4/mdh/xhp
10' x5m 11.72 1/4 record jb4 only
00' hayabusa turbo street bike
440 rwhp 1/8 5.42 141mph
07 SS trailblazer tuned/flex fuel
DOCRAMON DOCRAMON is offline
Car: 2008 535i
Default check the odb2 cables - 11-16-2017, 10:55 AM
I had something like that happened to me.
It was the odb2 cables to the female plug some got disconnected.
Wuz Wuz is offline
Car: BMW
Default 11-29-2017, 08:04 AM
Bmw shop says it needs a new DME, which i got but the new one can't be programmed without the cas and remote from the same car
BrownPower's Avatar
Car: 2008 535i
Default 11-29-2017, 06:36 PM
Reputable shop?
You checked the fuses i mentioned in the DME box???
Located in Toronto
Cars:
Wuz Wuz is offline
Car: BMW
Default 11-29-2017, 07:56 PM
Originally Posted by BrownPower
Reputable shop?
yep, they switched the dme cas and remote from a different car and it worked perfectly. its my 3rd time buying a DME, 1st one was wrong, 2nd one didn't have cas and remote. Maybe 3rd times the charm
BrownPower's Avatar
Car: 2008 535i
Default 11-29-2017, 08:01 PM
well im glad you got it sorted out. not sure whats worse, oil leaks or electrical problems.
both are $$$$$
Located in Toronto
Cars:
Wuz Wuz is offline
Car: BMW
Default 11-29-2017, 09:54 PM
both are $$$$$
This is my second worst bmw experience. I've owned 8 beamers. I just want to get rid of this one asap when its fixed.
Wuz Wuz is offline
Car: BMW
Default 01-03-2018, 09:38 AM
New issue
Heater isn't working and its 30 F outside help.
