(#51)
Car: 2013 Genesis Coupe
Default 05-06-2017, 01:28 PM
AOh OK, sounds very promising
CurtisFCauto CurtisFCauto is offline
Technician
Car: 08 alpine 335i e92
Default 05-06-2017, 07:01 PM
I will be putting mine on the dyno tomorrow to get a baseline on power. My current ethanol content is e72 (bench testing). I'm very curious to trying this out. My SW version now is 32.5 along with 1.50 on the MHD i believe. Not sure if I should make the changes before or after dyno.
08 E92, AW, FBO, NEW OE turbos, MHD/JB4, MMP high flow inlets & silicone outlets, Mbz AMG Fuel pumps, straight e85, 4bar, PLX, PI meth
98 SFWD civic, Billet 6765HP, 725whp, T1 tuned
02 IS300 LS2 swap (in progress)
05 E83 X3 3.0i, gray, taracata
Default 05-06-2017, 09:47 PM
You'll want to log and evaluate the PI if updating.
Technician
Default 05-06-2017, 11:30 PM
I have the port injection meth plate and 7 nozzles but im currently not using it and would like to not have too anymore. Since I installed the twin bucket AMG fuel pump setup I haven't had (to my knowledge) any drop in LPFP with straight e85 (72% atm). Testing the AMG twins they flow slightly better than the walbro 450 at 72psi. My HPFP seems to stay above 10 even at 22-23psi. I will most likely need to gap the plugs down to .18. Very seldom it will try to blow the spark out. New to posting here but been working on these cars for years. I've learned alot from this forum over the years. That said, I really appreciate and respect the achievements y'all have done.
lightning lightning is offline
Car: BMW 1M Coupe
Default 05-07-2017, 12:22 AM
Any news on the upgraded iPhone version jb4 mobile with regards to this new firmware?
orteeze orteeze is offline
Car: 08' 335i
Default 05-07-2017, 10:54 AM
Does this function still require an ethanol analyzer between the physical sensor and JB4? Or will this be the signal wire from the ethanol sensor straight to the JB4?
E90 LCI M Sport
Default 05-07-2017, 10:56 AM
What function? The new settings allows for configuration of a physical sensor in various JB4 inputs, or a virtual sensor, depending on the situations.
Default 05-07-2017, 11:15 AM
Working on porting these changes over to the N55 E series ISO firmware today.
brainsurgery brainsurgery is offline
Car: BMW E91 LCI 335xi
Default 05-07-2017, 11:20 AM
What's the unit of calculated torque?
335i LCI xDrive AT, JB4, ***, Stage1 LPFP, MHD E85 flash.
Car: 08' 335i
Default 05-07-2017, 11:24 AM
Something as simple as ethanol display
E90 LCI M Sport
Car: 08' 335i
Default 05-07-2017, 11:38 AM
E90 LCI M Sport
Default 05-07-2017, 11:43 AM
You mean an in dash ethanol display at startup?
Car: 08' 335i
Default 05-07-2017, 11:50 AM
Thru the JB4 mobile app without use of an analyzer
E90 LCI M Sport
Default 05-07-2017, 11:53 AM
It's whatever the DME spits out. Used to verify the back end flash map has calculated torque set to equal or higher than actual torque, to increase auto trans holding capacity.
Default 05-07-2017, 11:54 AM
The new E85 field is included in the JB4 mobile app as well as the windows interface.
Logan's Avatar
Logan Logan is offline
Car: E90' 335i
Default 05-07-2017, 07:12 PM
Terry,
if the default for Virtual Sensor Offset is 132 would putting a higher number lower content?I do notice now my ethanol content reading higher about a Ethanol content of 10 higher then my mix i put in(reading E61 but mix is more closer to E50).Or does it have to be driven?All i did was a cold startup and got reading.Would it be best to drive it for a more accurate reading?Warmed up?
Default 05-07-2017, 08:42 PM
The algorithm only updates itself when oil temps are 170 degrees or more. If you need personalized help configuring it and testing, just email me.
Default 05-07-2017, 11:43 PM
Thanks.
I uploaded this firmware yesterday and drove around 100 miles. I can confirm it works like the older one.
My phone hasn't received new version of Android app, so I don't have E85 value yet visible. Also I can not change eg. meth settings probably because old version of app is not compatible with the changed firmware.
500hp500tq 500hp500tq is offline
Default 05-08-2017, 06:54 AM
Hey Guys,
Has this been release for the ST JB4 firmware 13.0 yet?
What do I need to do to enable it? I see the options in the interface.
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
T3hD0gg's Avatar
T3hD0gg T3hD0gg is offline
Car: BMW 335is
Default 05-08-2017, 07:23 AM
Originally Posted by 500hp500tq
Hey Guys,
It looks like the ST firmware isn't public yet. Terry asks people to email him in his post if they would like to give it a try. (#39)
2013 BMW 335is DCT - Pure Stage 2 turbos among many other things
Default 05-08-2017, 07:39 AM
+1 just email me for the ST version. If I post it here we'll have twin turbo guys loading it by mistake and wasting our support crew's time.
sosn54 sosn54 is offline
Car: BMW 335I Xdrive
Default JB4 Mobile App - 05-08-2017, 07:39 AM
These new features are still not available on the mobile app....
2010 E92 335iX, JB4 G5 ISO, MHD RACE BEF, N20 TMAP SENSOR, VTT GC Lites, VTT Inlets Outlets, BMS DCI, VRSF c.a.t_less D.P., VRSF 7.5" Race FMIC, VRSF Charge Pipe with tial BOV, BMS Meth Kit, BMS OCC, Boost Concept Stage 2 LPFP., 335iS Clutch, MFactory Single Mass Flywheel, CFS High Performance Aluminum Radiator, N55 exhaust.
Default 05-08-2017, 08:02 AM
Should be for Android. Apple has a slow approval process. Check with Donnie for the latest on app updates.
Default 05-10-2017, 10:46 PM
Should I be able to set this to 132?
Default 05-11-2017, 07:23 AM
Did You update the JB4 firmware to 32_8?
Still waiting to get the JB4 mobile update through the app store....
