Car: 2013 Genesis Coupe
Default 04-27-2017, 08:32 AM
So is the ultimate goal to never have to flash again due to different E mixtures and the DME to auto adjust and JB4 to read ethanol content?
08_335i 08_335i is offline
Car: 2008 335i
Default 04-27-2017, 09:14 AM
Sounds on par with what it should be. Although, I would assume JB4 would be making the corrections for the E content.
Lightbulb 04-27-2017, 09:35 AM
Still confused how it would manipulate a flash to achieve the desired goal 🤔
Car: 2008 335i
Default 04-27-2017, 12:08 PM
I'm unsure how much in depth control JB4 has over AFR and timing when it's run on a BEF. Maybe Terry can chime in on this and give us better explanation as to how this will actually function.
Default 04-27-2017, 12:53 PM
Correct. JB4 reads ethanol via sensor or virtual sensor and handles everything with its logic and the improved bef maps being developed.
Its discussed that in detail in other threads like the one on bimmerboost.
Default 04-27-2017, 02:43 PM
So I guess we would still need to flash to E85, pump, or race regardless with this feature but jb4 would automatically raise or lower timing/boost target, etc.. Based off of E content? I'd love to try the new update but I just lost compression on cyl 4&5 only at 70k miles.
Default 04-27-2017, 04:26 PM
Oh no.. What did it?
N54 | Build Thread
Default 04-27-2017, 04:36 PM
Don't want to deviate from topic but not sure, could be a head gasket, valves or piston ring. I have theories how it caused one of the above to occur, but I won't tear into it until next month. If it's bottom end issue, I'm just going to build it.
m5james's Avatar
m5james m5james is offline
Default 04-29-2017, 08:24 PM
Great to hear!! There's a handful of its S63 owners who are basically at the limits of what tunes/stacking allows for our engine. I know a few people who are waiting to buy their JB4 because they think this is a hardware change, but this is only a firmware update, yes?
'08 BMW 535xiT - MHD 1+, BMS DCI, RB/Mishimoto, VRSF 7"
Default 04-30-2017, 08:22 AM
This thread is N54 specific, but we will be rolling most changes out to other platforms as we can. What the S63 needs is good at home flashing to tweak a back end flash. It's an MSD85 DME so should be easy to do. Maybe you can talk MHD in to adding it.
m5james's Avatar
Default 04-30-2017, 09:56 AM
...similar changes will be made across all JB4 platforms...
My bad, sounds like Protecon (the guy who linked me to this thread), myself and the guys who are discussing this on the GroupMe app have falsely gotten our hopes up that we'd get some trickle down benefits. I know for myself that using an E30 mix caused me to max out TRIMS no matter what I do, which isn't good for daily use.
Any validity to this post then since us getting the E85 firmware update sounds unlikely? He's ready to buy but seems he's holding off due to misinformation.
m5james's Avatar
Default 04-30-2017, 10:06 AM
As an individual asking, I doubt they'll take it on, but if it's as easy as you say, I'll ask and see what happens.
Default 05-04-2017, 03:28 PM
Added the BETA twin turbo N54 firmware to the first post. Email me for the single turbo version.
With this new firmware the new options on the meth page are now active. I believe Donnie added them to the android JB4 mobile interface, and they are in the windows interface, the rest are on the way.
The new field "virtual sensor offset" is used to calibrate the virtual flex fuel sensor reading. The logic still needs some work but its getting closer and more data always helps. With our E85 back end flash maps, which run a scalar of 1.30 under lower loads, a value of 132 has been working well. Which is the default value. For the factory BEF and RACE/PUMP BEF we'll have to evaluate different values. And of course there might be car to car variances.
We're working on a calibration method but one option is to run straight PUMP which should be around E10 and then adjust the field until virtual flex fuel content hovers around 10.
Default 05-05-2017, 04:49 PM
Added a few notes for v32.8
500hp500tq 500hp500tq is offline
Default 05-05-2017, 08:39 PM
Does this work on ST JB4 firmware 13.0?
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
N54QC N54QC is offline
Car: 07 BMW 335i
Default 05-05-2017, 10:15 PM
Hey Terry, if I have the fuel scalar at 1.40 for example, do I set the virtual sensor offset to 140 or does it not work that way and I would have to make adjustments to it to see what works?
rhm135's Avatar
rhm135 rhm135 is offline
Tech
Car: 335is
Default 05-06-2017, 06:59 AM
I keep getting kicked to safety map for value 5. Anyone else? I'm currently at a half mile event.
2012 335is DCT - JB4 - Fuel-it! - MHD - DocRace 6466
Default 05-06-2017, 09:13 AM
It's a fuel trims variance fault. Enable bank2 trim logging and let's see a log.
Also, a FUA setting of 65 disables that safety setting should you determine there isn't an actual problem.
Default 05-06-2017, 09:15 AM
Email for the latest ST firmware with these changes.
Default 05-06-2017, 09:16 AM
I have not made a formula yet.. So, you'll have to play with it, and find a value that works.
Default 05-06-2017, 10:00 AM
Can't you use Ethanol sensor and analyzer to see what your content is and adjust accordingly for the virtual sensor?
Default 05-06-2017, 10:20 AM
We do but most don't have a physical sensor for calibration for their specific vehicles. Looking for a wider range of user data before publishing default values for various scalars.
Default 05-06-2017, 12:34 PM
Could you technically add e10, e15, e20 etc... And adjust according to that data or would there be other variances? I figure it would be more accurate to utilize your physical sensor to get better readings?
Default 05-06-2017, 12:55 PM
We need values from a variety of cars and conditions to evaluate the algorithm.
