Default JB4 B58 Methanol Dyno Testing - 450whp - 03-04-2016, 03:39 PM
Had a chance to strap down our 2016 340i today for an hour of dyno tuning. Having done lots of runway testing last weekend at Shift Sector, including taking down a stock tune M4, I had a feeling the car was going to perform pretty well on the dyno. And was not disappointed.
The current setup is 100% stock except for a B58 JB4 BETA, BMS intake, and a BMS B58 water/meth kit. Exhaust is fully stock. Fuel was ~93 octane and meth mixture ~80%.
The BMS B58 water/meth kit has some additional parts not included in our normal kits including a PNP nozzle adapter, an EWG connector for the JB4, and some additional fittings.
With the EWG connector in place we're able to control as much boost as the turbo wants to make. But we've found power peaks out ~21psi, despite the turbo willingly making much more boost. Runs from 22-24psi at the same timing values all resulted in the same or less power. So we're probably approaching the stock turbo limits now. Maybe another 15-20whp ultimately in there with exhaust and other work.
Most impressive is how well it holds power to redline especially relative to previous turbo BMW motors like the N54 & notoriously weak top end N55. I'm pretty excited about this new motor.
Default 03-04-2016, 05:17 PM
Wow, I need that meth kit to do some testing with a ********.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 03-04-2016, 05:21 PM
Awesome! Can't wait to see turbo upgrades.
This is why I lost! Making more power then M3/M4 on stock tuning.
krazi3azn krazi3azn is offline
Default 03-04-2016, 06:02 PM
Wow, had my heart set out for a m2 in the future. But now looking at the b58 potential I might want to get a 240i lol. Very impressive numbers!
Default 03-04-2016, 06:24 PM
That would be something is the B58 had more potential. I can't wait to get my hands on an M2 for a day or two.
schmidty335i's Avatar
schmidty335i schmidty335i is offline
Car: 2012 335i 6mt
Default 03-04-2016, 07:52 PM
damn this is depressing for us E series n55 guys... thinking maybe its time to upgrade.
2012 335i Msport E92 6mt M3 gauge cluster, FBO, Jb4 G5 iso w/ff, BMS meth kit, Stg2 LPFP, Fuel-it TBI, 3.5bar, Pure turbo w/ inlet pipe and GFB DV
ShlemN55's Avatar
ShlemN55 ShlemN55 is offline
Car: F30 335i msport
Default 03-04-2016, 08:27 PM
Dang thats how much jb4 M4 makes on map 1 .. Thats a serious Statement from B58 ..
1993 Dodge Caravan ( Bone Stock )
2016 Tanzanite Blue F80 M3 jb4 , awe non res, bmc filters.
AC792 AC792 is offline
Car: 2012 F30 335i
Default 03-04-2016, 08:33 PM
Unbelievable! Makes me feel really bad about my N55...
WHEELPROO WHEELPROO is offline
Car: f30
Default 03-05-2016, 09:55 AM
which map you used with meth or when you made 450whp ?
Peter @ Pure's Avatar
Peter @ Pure Peter @ Pure is online now
Car: F20 M135i
Default 03-05-2016, 11:01 AM
That are indeed impressive numbers for stock turbo and just meth with JB4.
Not sad having N55 as it has Pure Stage2 But looks like B58 is very promising!
F21 M140i - currently stock
F80 M3 - 100-200: 4.6, 60-130: 5.3
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 03-07-2016, 05:45 PM
It really does... It's great to see how much potential newer BMWs have though.
2011 E92 335i Auto
12.0 @ 125MPH JB4
12.6 @ 112MPH 92 Octane | 11.7 @ 120MPH E30 MHD
Back to stock
2014 E84 X1 35i 13.9 @ 99MPH 293 AWHP 305 AWTQ
ER Chargepipe | BMS Intake |
Default 03-07-2016, 05:52 PM
For the B58 meth is attached to map7 with a variable additive that determines the level of aggressiveness.
rwalker rwalker is offline
Default 03-07-2016, 09:42 PM
Terry, do you think this motor can do 450whp with just a JB4 and race gas (instead of meth), a la the N54 I used to run, or is the platform stingy on fuel like the N55?
Car: 2011 e92 335i
Default 03-07-2016, 10:04 PM
I'm pretty sure he said that the stock fueling is maxed out near 385-395whp and that you would need something external such as meth, port injection, or throttle body injection (which meth on this platform is)
2011 E92 335i Auto
12.0 @ 125MPH JB4
Back to stock
Default 03-07-2016, 10:07 PM
Thanks for reminding me. You're following this pretty closely!
Default 03-08-2016, 10:20 AM
No the IPW cap limits power around 390whp (at reasonable AFR) without a 3rd party fuel source.
340iwhite 340iwhite is offline
Car: bmw 340i
Default 03-08-2016, 10:28 AM
TERRY ORDER THE METH KIT AND THE DOWN ***** FROM VM AND I WANTED TO KNOW WHAT MAP SHOULD I RUN AND IS THERE AN UPDATES ON THE MAPS FOR THE B58 JB4 AND BOOST GAUGE STILL DOES NOT WORK AND SENT IN A DATA LOG
Default 03-08-2016, 10:37 AM
If you need tech support on a BETA product you'd have to email in.
Car: bmw 340i
Default 03-08-2016, 10:52 AM
terry what your email thank you
Default 03-08-2016, 10:55 AM
Matt? You can email me as well for troubleshooting.
Car: bmw 340i
Default 03-08-2016, 11:00 AM
sweet what your email man
Track Master's Avatar
Track Master Track Master is offline
Car: 135i, 2010, N55, DCT
Default 03-08-2016, 11:14 AM
Well done Terry
N55 DCT, 135i, 12.00@116.2, W/O Meth
,12.01@119.3, With Meth
,11.91@119.025 added BMS Intake
,12.10@115 e85 + ISO
390whp@497 - 0.60 in 3.75sec
Default 03-08-2016, 11:44 AM
Was this using dual CM5's or larger? Also, think there is a chance to gather individual cylinder data to ensure proper meth distribution?
From the looks of it the n55 has a little more grunt in the lower rpm's, especially the pure stage 2 dynos that you have as a example, something like 100+whp at 4krpm. I bet the efficiency is up due to higher compression (and I am sure other things).
2012 N55 135I, Speedtech 7670, JB4 + MHD, Fuel-it port injection & stage 3 LPFP, M4 A2W IC, Mfactory LSD, KW V1, Apex EC-7
Default 03-08-2016, 11:54 AM
PayamHarouni@gmail.com
Tuned1M's Avatar
Tuned1M Tuned1M is offline
Car: AW 1M
Default 03-16-2016, 07:20 AM
I can't wait until you get your hands on a M2 as well! Mine will be here mid-April.
'16 LBB M2 in production
'11 BMW 1M sold
