ty1204 ty1204 is offline
Car: E93 N54 DCT
Default 08-18-2017, 05:14 AM
Hi Guys, sorry to revive an old thread but i have a few questions. I have an '09 n54 DCT but could never get launch control to work, I read somewhere that this update would sort that out. I have a normal 335i and not the is, would this still work for me? any help would be appreciated, this is my first time attempting this sorta thing on my car.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 08-18-2017, 06:23 AM
Yes mine is a European E92 335i. It'll work for you but it wont make LC work if it's not working already. Do you have the kickdown button deactivated or blocked?
Make sure your engine is up to full temp and you've driven maybe 5 miles before trying. Put the car in DTC. Hold the brake. Slam the throttle to the floor. It should come on. If you feel the car pushing against the brakes then it hasn't engaged. Every time you start the car it monitors how far you have driven. I have made the LC work at the drag strip after having the car turned off for a few hours but still up to temp. It can be quite moody about when it lets you though. Sometimes in an exact same scenario it just wouldn't come on.
If you don't release the brake then it wont launch. Just let off the gas while still on the brake and it'll go back to idle. So you dont have to rape the clutch just to try this.
Car: E93 N54 DCT
Default 08-18-2017, 06:29 AM
Hi Awsaws, thanks for the reply, I've tried everything but could never get it to engage, my buddy has a 2010 and he tried the same method he uses for his car and still no luck, any idea what it could be? The kickdown seems fine because it changes down to quite a low gear if I'm driving and i use it.
as3.0cl as3.0cl is offline
Car: 335is
Default 08-18-2017, 08:47 AM
do you have a US car or European.
only the 335is had a DCT in the US. Europe i have heard there was some earlier years with a DCT, do not know the years.
the 135 had a DTt in it.
2011 335is - Alpine White on Red - JB4+BEF, BMS DCI, Mishimoto IC, BMS OCC, VRSF CP, BWS WMI 70M/30W CM10, Turbosmart Plumb Backs
Car: E93 N54 DCT
Default 08-18-2017, 09:02 AM
I'm from South Africa so not sure how our cars came spec'd
Car: 2011 N55 135DCT
Default n55 DCT - 08-18-2017, 09:54 AM
Hi i loaded a diffrent dct flash on my car and im from south africa. Its not the 335is or 13is one.
2011 135 n55 DCT RHD, MAMBA GTX3576R single turbo kit by CCD South-Africa,FBO,Fuel IT TBI and Stage2 Lpfp,BMS Jb4 and FSB,Devels Own meth kit. 3.5 inch single exhaust.
Car: E93 N54 DCT
Default 08-19-2017, 02:07 AM
Hi Jacques, which software did you load?
FL335's Avatar
FL335 FL335 is offline
Sua Sponte
Car: 13 335is
Default 08-19-2017, 10:58 AM
Have you ever had your software updated? WinKFP will pick the latest update for you or you can pick and choose the ZB# that you want to try. Use INPA and read your UIF as a starting point and to know exactly what software version you're presently using and what your options are.
'13 LMB 335is DCT | MHD/BQ Tuning |
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 10-12-2017, 07:23 AM
subscribed.
2007 AW 335i E-92 6AT MMP Stage 3 @ 24psi / JB4 G5 ISO / XHP STG3 / VRSF ** / MMP INLETS&OUTLETS / MHD E85 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / CYBA SCOOPS / BC STAGE2 LPFP 10.98 @ 131
CharliesN54's Avatar
CharliesN54 CharliesN54 is offline
Car: 2008 335xi
Default 10-12-2017, 10:45 AM
-deleted post-
Single Turbo Z4 that's constantly broken
