mannerism mannerism is offline
Car: BMW 2016 ACTIVEHYBRID 5
Default Turbo upgrade - 03-22-2018, 08:17 PM
One of my friends has a blown up turbo in his 335i n55.
He was thinking to upgrade the turbo from stock to kinugawa turbo which is as follows.
- 49.5 / 67.0mm (Billet 6+6 Blades)
(Stock Wheel 45.8 / 62.0mm)
How much whp increase should he expect over the stock?
Just an approx figure would be appreciated.
Bmw 2016 535i hybrid ( active hybrid 5 ) , kittenless **, charge pipe, bms intake.
luchocamp's Avatar
Default 03-22-2018, 10:52 PM
for difference in price is better that your friend buy Pure stg 1
11.26 @124mph, LUCHOJB4, BMS BEF MHD, E85/Reg + meth 19psi ~ Set-up on Drag Track online instagram @luchocampusano ➡
Default 03-22-2018, 11:33 PM
The stock motor is blown so it wont be accepted as a core charge.
The only option is going gor an own or the kinuhowa turbo.
Kindly suggest
Default 03-22-2018, 11:36 PM
The stock turbo is blown up so it wont be accepted as a core charge. The only options are kinugawa and oem
Kindly suggest
Stoolz Stoolz is offline
Car: 11 135i
Default 03-23-2018, 12:10 AM
Kindly suggest
I'd have thought the Kin would be about +50
Default 03-23-2018, 01:09 AM
Thank you for your kind reply
Let others comment too. Lets see
luchocamp's Avatar
Default 03-23-2018, 02:26 AM
Kindly suggest
If you could put a kn turbo you could put a Pure Stg 1 just contact by email Pure Turbos ( since 2017 PS1 has a new and better design )
Default 03-23-2018, 05:29 AM
Dear bro i think we are having a little problem maybe because english is not my first language.
Let me try to explain.
The stock turbo is blown up. Its of no use right?
Now the KN turbo will come packed just plug n play or you can say bolt on .
The problem with pure turbo is that they need the original turbo back or else they wont refund my core deposit which is 1500 USD.
So the pure turbo would cost me 2500 USD.
In case of KN there is no core deposit. I,ll just have to pay 850 USD without any core deposit and i,ll get my turbo delivered to me.
Kindly correct me if there,s something wrong in my understanding.
luchocamp's Avatar
Default 03-23-2018, 06:09 AM
kn turbo only send you a cold side part of turbo and you need to keep using your oem turbofold. Same as PS1 be aware.
Default 03-23-2018, 06:21 AM
I,ve emailed them again.
I think they will send the complete turbo because the weight is 18 lbs and the packing is 33x23x28 cm.
What do you say?
The rest members are also welcome to comment :-)
SeanWRT SeanWRT is offline
Car: m2
Default 03-23-2018, 08:48 AM
My take on it:
1) It's unlikely they sell you the entire turbo kit (including turbine housing and manifold one piece) for just 850USD.
2) Compressor inducer 49.5mm seems not big enough, just about the same as EWG stock turbo (I measured it). Normally STG1 offering seem to have a 51~52mm compressor inducer. BTW, not sure how do know compressor exducer being 67mm, you cant see it without tear it apart.
luchocamp's Avatar
Default 03-23-2018, 10:29 AM
Oem turbo and manifold weight +35lbs
Steve @ PURE's Avatar
Steve @ PURE Steve @ PURE is offline
Car: F80M3
Default 03-23-2018, 10:33 AM
We accept blow up turbo as core for stage 1 as long as the housing is in good shape
Pure Turbos | Bootmod3 | 2MGT3 WideBody | Aristo Wheels | G1000 APRPerformance wing | Autopower Rollbar | Status Gruppe Coilovers | RK-Tunes Intakes and ChargePipes | GTHAUS Meisterschaft turbo back | DinMann CF parts | Gaphix Seats Belts, RECARO CS Sportster | JB4 | CSF Top and front coolers | Full MPerformance interior |
Default 03-23-2018, 12:05 PM
What is the size of inducer and extucer?
Default 03-23-2018, 12:10 PM
My car is the hybrid version of 535i so i am 340hp stock.
How much gain should i expect with the following mods.
Kitenless
Charge pipe
Intake
Mission performance stage 2 tune
Stage 1 turbo.
93 octane with 2 bottles of NOS octane booster with every tank.
Will i be around 475hp ?
Car: 11 135i
Default 03-23-2018, 04:14 PM
Kitenless
Charge pipe
Intake
Stage 1 turbo.
If you're going to bolt a heap of stuff on go straight PS2.
Default 03-23-2018, 06:23 PM
PS2 is far complicated than PS1.
I was just having an idea of the output of the car after the turbo installation. I guess it would be 450-475
What do you say?
Default 03-23-2018, 06:24 PM
@steve kindly answer
terryd5150's Avatar
terryd5150 terryd5150 is offline
Car: BMW 335xi
Default 03-23-2018, 06:52 PM
I thought the Kinugawa (and others) only came in PWG; have I missed something?
Car: 11 135i
Default 03-23-2018, 07:21 PM
What do you say?
http://www.n54tech.com/forums/showthread.php?t=26268
terryd5150's Avatar
Car: BMW 335xi
Default 03-25-2018, 08:02 AM
There should realistically be some potential upside to that number.
A few things have changed since then:
* Pure is on a different revision of the S1
* Flash tunes are available
* Lpfp upgrades are available
And a few things that weren't included in the original testing:
* Meth
* PI
* Upgraded intercooler (that test used the stock FMIC)
I think breaking into the 470 range would still be a challenge; however, I would think 450 could be achievable, considering the items above.
