ceedawg ceedawg is offline
Car: 2015 f30 335i Msport Xdrive
Default 01-24-2018, 02:36 PM
Originally Posted by luchocamp
0.92 A/R
Assuming its a TS I doubt even still that it would have boost creep. I have a TS AR.91 on my DSM with a BW 8875 and I have no boost creep ,well I'll admit I have a dual external wastegate setup as well.And running 30psi+.
bcaz808 bcaz808 is offline
Car: 2011 E90 335i
Default 01-24-2018, 03:05 PM
Originally Posted by ceedawg
I would be surprised if that was the case with the size of thatT4 borg warner turbine housing plus I think it has a 1.05 AR TS housing at that.
CES ran the 8374 on the N54 Steedspeed manifold and the car made 18 psi with the iwg locked fully open. They even tried porting the iwg and could only get it down to 16psi. I'm hoping this isn't an issue for us N55 guys as I'm also very interested in this turbo kit but the only data log I've seen looked to have boost creep.
Default 01-24-2018, 03:23 PM
Hmmmmm I see. Was that mani similar in design to the speedtech mani? Hopefully this ewg setup wont experience that. I would perhaps be more concerned of the probability of it happening to a PWG style wastegate. I know on the EVo side of the forums there are lots of guys running tubular manis with the EFR7670's at 25psi plus and I have not heard any reports of boost creep with. lol Then again this is a six some I'm sort of assuming the same possibilites.
Car: 2011 E90 335i
Default 01-24-2018, 04:05 PM
Yeah similar enough manifold although the steedspeed is CNC. Whether it's an electronic or pneumatic actuator is irrelevant, they're both opening the same exact wastegate. Evo guys have boost creep issues with the IWG as well, do a google search and you'll find threads on it.
Like I said though, hopefully it's not an issue for the N55 but we will find out soon.
OP, sorry for the slight thread diversion, good luck and I look forward to results.
Default 01-24-2018, 06:11 PM
Well hopefully the op lets us know soon. Im so anxious to know how the car runs now.
luchocamp's Avatar
Default 01-24-2018, 06:26 PM
With speedtech kit there is no way to have boost creep because you keep using oem parts to control boost.
W.R. 11.01 @127.6mph, LUCHOJB4, BMS BEF MHD, E85/Reg + meth 24.8psi ~ Set-up on Drag Track online instagram @luchocampusano ➡
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 01-24-2018, 06:50 PM
congrats lucho!!!
-16' X4 M40i Tweaked CTS Turbo FMIC | Custom CTS Turbo D0wnP1pe | BM3 E30
- 17 F80 ZCP | BM3 E30 | CTS Turbo D0wnP1pe/CP/HeatExchanger & Mid-pipe
$ECA $XRP $XLM $TRX $ADA
Car: 2011 E90 335i
Default 01-24-2018, 08:35 PM
Control of the wastegate isn't the issue. The fact that the internal wastgate of the efr turbos can't physically flow enough exhaust gas is. As I stated earlier CES locked the 8374 wastegate fully open with a piece of wire and made 18 psi. That was on a N54 and a steedspeed manifold though so who knows what the N55 and this manifold will do hopefully you can let us know soon.
luchocamp's Avatar
Default 01-25-2018, 03:17 AM
Results soon
Default 01-25-2018, 07:49 AM
http://www.full-race.com/articles/ef...ll-guidelines/
I don’t see how creep could be a issue with such a big wastegate but it could be improper actuator position or the need for a new lower pressure actuator
2012 N55 135I, Speedtech 7670, JB4 + MHD, Fuel-it port injection & stage 3 LPFP, M4 A2W IC, Mfactory LSD, KW V1, Apex EC-7
SeanWRT SeanWRT is offline
Car: m2
Default 01-25-2018, 09:01 AM
BMW N55 Turbofold vs Speedtech manifold
Maybe Jeff need to consider building such manifolds (one piece including turbine house) for factory BW turbo? It can open up a much bigger market.
luchocamp's Avatar
Default 01-25-2018, 09:34 AM
Manifold is expensive and then need to weld oem turbine house for extra 40hp.. I think is better deal to buy PS1 or PS2
Default 01-25-2018, 09:59 AM
That's what I was kind of saying but hopefully you will see and let us know when you test drive her.
Default 01-25-2018, 10:02 AM
Results soon
Its called Night and day!!
luchocamp's Avatar
Smile 01-27-2018, 10:59 AM
I donít see how creep could be a issue with such a big wastegate but it could be improper actuator position or the need for a new lower pressure actuator
Agree
luchocamp's Avatar
Default 01-29-2018, 06:22 PM
Today we made first start up .... in a few days my plan is going to same dyno with same fuel system ( oem bmw ) + meth injection (7+7) and see diference in spool up, tq and hp ... ( PS2 vs ST3 )
Default 01-29-2018, 11:09 PM
Oh yeah!! Looking forward to this!!! Please do a run without meth as well if You can.
2015 335i Xdrive Msport stock for now
1995 Eagle talon TSi AWD 612awhp e85
1998 AMG c43 to 55 5.5L conversion FBO Kleemann Superchip custom SW 307whp 329wtq
2004 G35 coupe aero package Brembo brakes stock
luchocamp's Avatar
Default 01-30-2018, 03:32 PM
Ufff very happy with the performance of Speedtech ST3 first logs 9-10psi of boost.
Default 01-30-2018, 05:43 PM
Looking good. Mine hasent seen 4psi due to ssp break in. Jealous and glad it’s looking so good.
luchocamp's Avatar
Smile 01-30-2018, 06:30 PM
No problem with Speedtech ST3 EFR 8374
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 01-30-2018, 06:47 PM
Sweet! Hope you get an opportunity to hit the dyno sometime.
Mods: Stock for now
Car: 2011 E90 335i
Default 01-30-2018, 09:05 PM
Awesome, now I really want to get rid or my PS2 lol
luchocamp's Avatar
Default 01-31-2018, 06:43 PM
Lowon's Avatar
Car: Bmw M2
Default 01-31-2018, 07:00 PM
That's a stealthy install!
Mods: Stock for now
luchocamp's Avatar
Default 02-01-2018, 08:36 AM
This morning some test 13psi of boost 12.1@118mph with Dragy
