Eulogy32 Eulogy32 is offline
Car: F30 N55
Default FBO F30 N55 Low Boost Concerns - 03-22-2018, 10:12 PM
Greetings,
2014 F30 N55 Xdrive 6MT EWG
FBO - JB4, VRSF FMIC, EW CP, Injen CAI, VRSF ******* **
Logs taken with E20 and 92 Octane pump gas with 45-50 degree F ambient temps
Current Codes:
180001 ******* ******** detected
102001 Air mass plausibility - Tuner code, ignore
I'm concerned that my peak boost numbers are low. I ran the car for a month on Map 1 prior to the ** install on 93 octane where I was peaking at 11PSI. Now that I have ** installed and running on Map 2 with E20, the car does not feel appreciably stronger and I'm only peaking at 12PSI.
I have attached two logs, each with multiple pulls, for Map 2 (what I tend to use) and Map 5 (only used today to capture this log).
Really appreciate your help!
Default 03-23-2018, 05:46 AM
Do a few good adaption logs on map 5 in 3rd or 4th gear from 2k to redline at WOT and set your FOL to 70.
Car: F30 N55
Default 03-26-2018, 06:12 AM
Thanks Steve! I increased my FOL to 70. Please see attached for two new logs in Map 5 after having given the car time to adapt to the new setting.
Default 03-26-2018, 08:50 AM
Looks okay to me but trims are about maxed out, I would not suggest adding any more ethanol with your current configuration.
