keyap keyap is offline
Car: N55 135i
Default E82 N55 DIY/How To For Removing Transmission - 03-25-2017, 09:14 AM
Anyone got a link to a DIY/how to for an E82 N55 transmission removal, preferably DCT.
Can find a few for the N54 but not the N55. If there are none, is the N55 much different to the N54?
Ichiban Ichiban is offline
Car: 135i DCT
Default 03-31-2017, 01:56 PM
Are you changing your clutch plates?
Car: N55 135i
Default 04-01-2017, 01:37 AM
Not sure yet? May just swop out the flywheel.
Car: 135i DCT
Default 04-01-2017, 10:30 AM
Do the plates while your at it. it's quite a lengthy job. My dealer said they could do it for me $1400. Complete clutch plates and install my new flywheel if I provide an OEM part.
Car: N55 135i
Default 04-02-2017, 07:22 AM
Am tempted however, whether I go in there depends on whether a reduced weight flywheel helps with the N55 misfires, especially on most DCTs?
Car: 135i DCT
Default 04-02-2017, 08:08 AM
If you are pushing out that much WHP then I would do it.
Car: N55 135i
Default 04-02-2017, 09:01 AM
Will be interesting to see the results from Pure.
Their early testing on a N54 DCT shows a lighter flywheel cures the high 500 misfires and for the N55 I think they were initially going down the M4 flywheel route, as this fits the N55 DCT and is 10.5lbs lighter than stock but, it costs 800!
MFactory have some early production units which are marginally lighter than the M4 option at around 390.
Hopefully Pure should have some results out soon
