quing quing is offline
Car: bmw 335i
Default 12-09-2012, 12:49 AM
Great DIY with a very clear and easy instructions! I see the torque setting for the valve cover bolts is 7 ft lbs, but what about the fuel rail?
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 12-09-2012, 01:10 AM
I thought I posted those, I will get them....MAKE sure you put the bolts in first....do NOT connect any thing to the rails....the fuel rail bolt holes strip so easy and any tension could result in this...hand tighten all the way down first.
Car: bmw 335i
Default 12-09-2012, 10:59 AM
I forgot to mention, what is the torque setting for the fuel rail fittings?
rudypoochris rudypoochris is offline
Default 11-19-2013, 06:13 PM
The 26 bolts seem like they can be reused. Is that also true for the other 5?
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
robc1976's Avatar
Car: 2007 335i
Default 11-19-2013, 07:49 PM
I reused all of them and no issues.
Gizm0 Gizm0 is offline
Car: 08 335i
Default 12-27-2013, 11:22 AM
This is going to be my first 2014 repair on the N54... Thanks for the DIY. What size socket do you need for the 26 ASA bolt? Can you just use a regular HEX socket of do you have to use a special socket?
There is a video I found on Youtube with some good advice. It saves some time by not having to completely remove the fuel rail.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 04-28-2014, 12:11 PM
Did the OFH gasket last weekend. Removed the intake manifold with no trouble. This cylinder head gasket is my next. Ordering Rob's PCV also. Great diy. Thank you.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E50,
Fuel-it! Stage 2,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.026")
jmvoss's Avatar
jmvoss jmvoss is offline
Car: 2007 335i
Question DIY Valve Cover Gasket - 09-13-2015, 03:36 PM
Think I messed up, nobody's fault but mine I should have done more research. I took the word of youtube and a representative at a major corporate auto parts store. So, I replaced VCG but I also used a silicone sealant as well. Looked into manual and it also said to use a light bead of sealant. I didn't use any when I did the OFHG(oil filter housing gasket), so know I'm wondering if I'm going to do major damage to engine by putting a little bead of sealant on with new gasket?
Thank You in advance for responses
mp333 mp333 is offline
Car: E46,E60 & E90
Default 05-14-2017, 04:07 AM
Jmvoss - How did you make out? I did the same as I saw couple nicks either they were there or I did it while cleaning the surface on the engine. Now I have a leak that collect on the silver Shield near the vacuum lines. I used Permatex Ultra Black. Thin bead only at the bottom length wise.
The valve cover thoroughly cleaned clearing all the passages and also replaced with RB PCV.
The bolts were torqued three times starting in the center in cross pattern starting in the center. First two times were done using extension & fingers. As I didn't have a torque wrench that went that low. I gently snugged them as I had done on my 2003 e46.
2008 535xi
Jeffman's Avatar
Jeffman Jeffman is offline
Default 05-15-2017, 01:33 AM
Great DIY! I have 60K miles on mine. Other than visibly seeing oil leaks, what symptoms typically indicate that the valve cover gasket needs to be replaced? What benefits arise by cleaning the valve cover?
2008 E90 335xi AT 63K MILES
MHD CUSTOM 93 OCT 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, FORGE DV BLUE SPRINGS, BMS DCI, BMS T-STAT DELETE, BMS OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS
PR IGNITION - COMING SOON!
