(#1276)
JBoe JBoe is offline
Car: M240i
Default 06-17-2018, 08:18 PM
Hello Payam and/or Terry. I posted my map 1 logs here: http://www.n54tech.com/forums/showthread.php?t=53725
Probably best to use third pull. If you could, please check them out and let me know what you think.
tZe tZe is offline
Car: F32 440i
Default 06-18-2018, 08:29 PM
I have a weird bug with v9 on F32 440 B58 -- the green indicator on the shifter is not working. When the car starts, the P light is on but once I shift out of P, the green indicator light goes out and stays off. Can someone with the v9 have a look and see if this occurs on yours?
No other issues otherwise. Great product. Have emailed Terry but just wanted to see if anyone else has this issue
Default 06-18-2018, 09:05 PM
Don't see anything in the JB4 code that could be related to that...Might be normal stock behavior. Let's see if anyone else reports any issue.
tZe tZe is offline
Car: F32 440i
Default 06-18-2018, 09:10 PM
I am quite sure it wasn't there prior to the JB4 install so it shouldn't be stock behavior. Small issue - as you said, let's see of anyone else reports an issue.
Could the install have caused this or a loose connection?
Thanks for the fast reply!
tZe tZe is offline
Car: F32 440i
Default Yesterday, 04:48 AM
Just to close the loop.
The gear shifter LED is spoilt and needs to be replaced. Nothing to do with the JB4.
Terry - quick question - putting aside the warranty concerns, is there any chance that the JB4 firmware can be corrupted by a reprogram of the ecu systems in the car?
Bullitt1841's Avatar
Default Yesterday, 06:57 AM
Take the JB4 out before going to the dealer. Not worth the hassle from the dealer.
2017 F36 440i Gran Coupe | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
SOLD: 2007 E90 335i | PURE Stage 2 N54 Turbos | JB4 | FBO | 160k+ miles on the car, 120k+ miles on the JB4
tZe tZe is offline
Car: F32 440i
Default Yesterday, 08:17 AM
Thanks for the tip. I am well aware of the hassles etc etc and the debate over dealer vists/warranty.
But putting that aside, I am interested to know whether it is possible to corrupt the JB4 firmware if the ecu modules in the car are reflashed while the JB4 is attached but on Map 0 and OBD plug out. I would think it is not possible for any corruption to occur but just wanted the expert's (Terry's) input on this.
Default Yesterday, 10:33 AM
Terry can chime in, but I don't think it's possible on the B58 JB4. Only on the N54 JB4 since it connected directly inline with the DME cabling.
BMW After BMW
Car: BMW M240i
Default Yesterday, 09:10 PM
I works and I believe we are using it on Map 5. The current FUD setting bit 2 on the latest firmware will have the IAT spoof on all maps so you can test map 1 and see how it does if you don't have the octane/modifications to test map 5 off the bat.
Hah, you know what? All my runs with the spoof bit on were WITHOUT 6cyl timing set to 1. I missed that because it was in the v8 instructions but not in your v9 instructions. Do we still need to set 6cyl to 1?
2017 F23/M240i Convertible (B58) / 6MT / FP Wires / EWG Wires / BMS Air Intake / Stock Exhaust / 93 Octane + 2 gallons E85
