socaln54 socaln54 is online now
Car: 535i
Default 335i and 535i Technical question - 06-13-2018, 07:26 AM
I was cross refrencing turbo part numbers and it looks like the front turbos of both cars are the same but the rear turbos its where the difference is, picture attached 535i (Left) and 335i (Right), my question is that since its basically the same turbo just clocked/position differently, can you install the 335i turbo on a 535i, if not why so?
Payam @ BMS Payam @ BMS is online now
Default 06-13-2018, 10:26 AM
IIRC housings are different so it would cause the actuator bracket to sit different and the charget pipe etc etc. More than likely the ******** angle may be different as well.
Car: 535i
Default 06-13-2018, 10:30 AM
the down pipe should be the same angle right? basically you are saying the "outlets" would be different no, not the chargepipe?
Default 06-13-2018, 11:43 AM
Sorry, yes the outlets.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Might depend on the exact turbo - you're correct that the only difference is clocking, but as to whether a re-clocked turbo would allow the wastegate to fit between models, would probably be the main question.
Yes, outlet may have a different angle but use the same part, should fit either (no one offers model-specific outlets AFAIK, they're universal). Inlets (from the filters to turbo inlet) are the same.
********* are completely different from model to model, as we know.
2009 535i Sport
Software: JB4 G5 | MHD | Trebila Tune | XHP Stage 3
Hardware: GC Lites | Inlets | Outlet | 3" D-P's | 7" FMIC | S2 LPFP | TBI | DCI | ER CP | Forge DV's | 3.5 TMAP | RB PCV | Koni FSD
Car: 535i
Default 06-13-2018, 11:57 AM
I think the down.***** are the same in regards to the diameter, they're just different in the way they're routed/bent so they should fit right in correct? because as I mention the front turbo is the same model number as the 335i
LessIsMore's Avatar
Inner Circle Member
Default 06-13-2018, 12:44 PM
The degree that the compressor inlet is clocked won't affect the turbine, and thus ******** angle. Yes, the actual d0wnp1pes are different in routing of piping, angles after turbine, etc. The d0wnp1pe-to-turbo mating size is the same between models (since they all fit the same turbine housing), but not sure if exactly the same diameter piping between models, but probably pretty close if any difference.
2009 535i Sport
Car: 535i
Default 06-13-2018, 01:10 PM
Sorry, yes I meant the mating size should be the same, im guessing the only issue here is if the wastegate actuator arm would hit the frame, everything else shouldn't matter I believe since you confirmed their is only one outlet part #, and the inlet size im going with an aftermarket/custom one
