nika1993's Avatar
nika1993 nika1993 is offline
Car: bmw 535i
Default HELP. AEM fuel pump - 04-17-2017, 07:44 AM
Help me please. How do I install aem fuel pump on bmw 535i e60? Somebody has an instruction.
rcpro88 rcpro88 is offline
Car: 535i
Default 04-26-2017, 07:00 AM
I would advise you to sell the AEM and use a Walbro 450.
I had an AEM 320 and was recommended by many to swap it to a Walbro 450. If you have an AEM pump and can't return it/don't want to buy a Walbro, the install for the AEM is the same as the Walbro.
There is a DIY on the forums somewhere, I recommend NOT to follow it. Do not put a soldering iron anywhere near your car when your fuel tank is open. Also don't try to remove the pump unless you have less than 1/4 (preferably less) tank full.
I did my own e60 walbro lpfp mod.
Make sure to use 3/8" PTFE tubing, this is what I used:
http://www.radiumauto.com/Submersibl...bing-P672.aspx
You will need 2 of them, connect them with a 3/8" brass male to male hose/barb.
There is quite a lot of little things that will need to be done to ensure reliable operation.
You will also need to modify the small black bucket that seats in the large white bucket. IF you don't feel like doing all this work/not confident in your ability, you can send me the LPFP assembly and your AEM or a Walbro if you want that. Ill bill you for the cost of supplies/time(we can talk about this)
VRSF Inlets, Chargepipe, **'s, FMIC
HKS BOV, BMS DCI, BMS Meth Kit
JB4 w/MHD-BMS E85 Backend Flash w/Nexus 7
Custom Map 6 21.5 psi (E70 mix)
Walbro 450 LPFP - 4 Bar TMAP Sensor - Muff Delete
SAT Transmission Flash/retrofit (Thanks to Wedge!)
AD Engineering Oil thermostat - Rob Beck PCV Valve
Gloss Black BMW M359 M3 Competition Wheels
Continental Extreme Contact DWS06 Tires
Installed all the parts myself.
nika1993's Avatar
Car: bmw 535i
Default 05-11-2017, 11:27 AM
How can i will modify the small black bucket?
