(#951)
cnm135i cnm135i is offline
Car: m135i
Default 10T6 - 03-04-2018, 10:42 PM
Terry
Logs to keep the ball rolling It does not really show in the log but I felt a consistent hesitation after shifting into 5th. Felt/sounded as if Auto Shift Reduction is set too high, but that looks good in the log. ****ed the logs up a bit by forgetting to allow Target under DME_BT... I still prefer fixed FF and DB but this is really good for "set and forget"
PID=25
DWP=0
FUD=0
ASR (Auto Shift (boost) Reduction)=20
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4, Quaife LSD
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
luchocamp's Avatar
Default 03-05-2018, 02:14 AM
Ok guys ... car brings oil temp on dash it's not difficult to knew where is oilt temp if you have water temp.
Transmission Temp is not related to engine temp.
( You could have engine temp in 160 and Transmission over 190 )
If you want that your tranny works well put all the power in the 170 ~ 178 range.
Before 170 it could easily fails ( slips too much or even do not pass to next gear)
Over 178 it takes a lot of hp from engine. Check your dyno
This data is only ZF8 on xdrive models maybe RWD do not need to be so specific on TT.
W.R. 11.01 @127.6mph, LUCHOJB4, BMS BEF MHD, E85/Reg + meth 24.8psi ~ Set-up on Drag Track online instagram @luchocampusano ➡
luchocamp's Avatar
Default 03-05-2018, 04:47 AM
Terry.. good day ! Great work with ISO 10 ... I notice max boost 1st / 2nd is not working
Car: m135i
Default 03-05-2018, 07:59 AM
Another log with FUD=16 (allowing Target under DME_BT). Feels much better. I'll stay on this FW and test some map3 next
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 03-05-2018, 08:14 AM
What dose this do ? allowing Target under DME_BT ??
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | N20 3.5bar TMAP Sensor | TREBILA BEF Performance Tune | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | BMS 100% Meth-Dual CM7 Injection | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/iR4wm3I.jpg |
Car: m135i
Default 03-05-2018, 03:48 PM
With this setting JB4 can go below DME boost target.
Default 03-05-2018, 05:54 PM
Be sure to disable the under boost fault also in the BEF if using that setting.
Car: m135i
Default 03-05-2018, 06:05 PM
Dont ever get that CEL anymore which puzzle me a bit. I think the 6-cyl setting solved that Or is it something else you refer to?
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 03-05-2018, 06:36 PM
I have got drivertrain malfunction, boost lower than expected, 2 time now with t6. Anyone else?
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
Car: m135i
Default 03-05-2018, 06:47 PM
Try set your 6-cyl timing setting to 20
peopleschoice1 peopleschoice1 is offline
Car: f30 335I
Default 03-12-2018, 11:54 PM
93 octane BM3 BEF logs. How can I get it to be more consistent and less laggy?
Rayzor Rayzor is offline
Boost is Life
Car: F30 335i & E90 330d
Default 03-13-2018, 01:32 AM
So finally got a chance to do the ISO mod. Modified the board and adjusted settings as suggested on the first page.
Car ran ok while adapting and after i kept getting drivetrain errors every time it started boosting. What was strange is, on map5 on constant partial throttle you can hear the turbo spool then cut then spool then cut and so on as the revs increase, Its very inconstant. Any sugestions on what I need to change? I had to disconnect the unit in order to drive the normally due to the drivetrain issue.
Also got the error, boot target lower than expected.
here are some of the logs:
Marlinman's Avatar
Car: 335i coupe 2010
Default 03-13-2018, 08:34 AM
Increase your six cyl timing
Car: 13 f30 335i
Default 03-13-2018, 08:59 AM
Im also getting drivertrain malfunction, boost lower than expected and that didn't work for me.
Default 03-13-2018, 09:03 AM
Logs look fine to me. Don't see a spool up log. 5th gear flooring it at say 1200rpm, to check boost response.
Default 03-13-2018, 09:04 AM
Maybe your tuner disabled the under boost fault already for you in the BEF.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Unhappy 03-13-2018, 10:04 AM
Same here.
Mike Levy
2017 X3 xDrive35i
Default 03-13-2018, 10:08 AM
If you are not able to disable boost lower than expected in the back end flash map, then be sure bit 4 is off. If you continue to trigger it capture it coming up in a log and we can check out what conditions are letting actual boost drop below the flash target.
Car: f30 335I
Default 03-13-2018, 10:33 AM
Ok, will do.
Car: 13 f30 335i
Default 03-14-2018, 07:41 AM
Terry,
How this log looks for 16psi on 93? Trims seems low, timing? Hpfp seems ok as long I dont overboost to 19-20psi Adding some e85 will help trim to above 25? Thanks
Default 03-14-2018, 01:20 PM
Terry,
Looks good to me. These PWG setups are always a headache to dial in.
Car: 13 f30 335i
Default 03-14-2018, 05:24 PM
Yeap.
Im still working on how to fix these two issues that are actually related I think.
1- Drivertrain malfunction light, boost lower than expected, still popping up in the first medium to hard throttle
2- Throttle response slow up to 50% pedal in normal driving. I get 1-1.8 psi till I smash the pedal more than 50%. Before I was getting 4-6psi right away below 50%. That could be why the Drivertrain malfunction issue.
It could be the way this ISO fixed the overboosting
Here is a log.
Car: 13 f30 335i
Default 03-14-2018, 08:22 PM
I cant open the Bef,It was disable on the last bef you send me I guess.
Car: m135i
Default 03-14-2018, 08:47 PM
Yeap.
Here is a log.
Did you try to dial up the 6-cyl timing setting? Set it at 20 and do a log.
Boost is Life
Default 03-15-2018, 07:46 AM
Thanks, increase it to what value next, if it does not wok?
