Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 02-15-2018, 04:50 PM
Originally Posted by WaqasRiyami
Will i be needing N20 3.5 bar Tmap sensor after installing the PS2 ??
If you want to run over 20psi then yes, otherwise no.
2011 E92 335i Auto
12.0 @ 125MPH JB4
12.6 @ 112MPH 92 Octane | 11.8 @ 120MPH E30 MHD
Custom MHD Tune | XHP Stage 3 | ER Chargepipe | VRSF 7in Intercooler | Methanol Injection | Performance Line D-P | Pure Inlet | Pure Stage 2 | Go Fast Bits DV+ | Diff Lockdown Bracket |
2014 E84 X1 35i - Stock For now 13.9 @ 99MPH 293 AWHP 305 AWTQ
Peter @ Pure's Avatar
Car: F20 M135i
Default 02-15-2018, 11:56 PM
If you run pump fuel and meth you could do around 21-22 psi. So the N20 tmap is advised.
F80 M3 - 100-200: 4.9, 60-130: 5.6
F20 M135i (sold) - 100-200: 6.26
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 02-16-2018, 12:03 AM
I am not sure how much psi will i run..
But i have no EXX fuel available and no meth.
I have acces to 98RON/93OCT only will i run above 20 psi ??
2011 F10 535i N55 PWG AT | JB4 ISO - BT.Rv3 | TREBILA BEF Tune | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/XEO6ZpR.jpg |
Coming Soon: | Pure Stage 2 Turbo | Custom High Flow Inlet | GFB DV+ | Fuel-It Stage 2 LPFP | N20 3.5bar TMAP Sensor
Car: F20 M135i
Default 02-16-2018, 01:40 AM
if on pump fuel only, you will run 15-17 psi. So then not needed.
peter@pureturbos.eu
pureturbos.eu
Car: 2011 e92 335i
Default 02-16-2018, 02:05 AM
Depends on timing targets. I would just stay under and keep the factory tmap.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Default Yesterday, 12:47 AM
Update:
Bought the Inlet from : AZ-MCRacer
Ordered Item's:
Stage 2 turbo
DV+
Custom Inlet
N55 Install kit
Waiting for Peter@Pure to Ship the Turbo, Shout-out to peter so he can make it happen faster.
Just Confirmed with the workshop that will make the install:
It will take 2 Full Days & he told me he will take the engine down , perform the install , and put it back in. HE Says this would be a clean install as we can check that we installed everything and tightened all the connections & check if anything else needs to be changed or fixed in the way.
Car: F20 M135i
Default Today, 12:27 PM
Update:
Ordered Item's:
Stage 2 turbo
DV+
Custom Inlet
N55 Install kit
We try our best always to ship out asap. But we cant do magic
peter@pureturbos.eu
pureturbos.eu
Default Today, 12:30 PM
I know You are doing your Best, But i really Can't Wait Let the Magic Happen haha
Default Today, 12:31 PM
BTW just Ordered - Fuel-It Stage 2 LPFP | N20 3.5bar TMAP Sensor
So, Now it will be
Pure Stage 2 turbo
DV+
Custom Inlet
Car: 2011 e92 335i
Default Today, 12:33 PM
That's overkill. I wouldn't pay for that much teardown during the install.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Default Today, 12:43 PM
What do you mean ??
Car: 2011 e92 335i
Default Today, 12:55 PM
What do you mean ??
Removing the engine is not necessary at all and is a lot more work. More work equals more hours (2 day install) which means you'll be paying a lot more money.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Default Today, 01:07 PM
Actually i was Quoted 500$ for the install ( Including Turbo , DV+, Inlet, Fuel-It Stage 2 ), Which is more than reasonable
