(#401)
Ddang06 Ddang06 is offline
Car: 335i coupe 6MT
Default 11-07-2015, 06:57 AM
Installed anti lag and it works . Does anyone car feel
Like it bogs a hit when you release the button ? It sounds like it backfires a bit as well
jamhot's Avatar
jamhot jamhot is offline
Default 11-07-2015, 10:18 AM
I don't seem to be able to adjust my timing total correction anything lower than -20. I've tried running with this but seems to push too much power to the wheels. Am I missing something?
Forge fmic,VRSF **, Charge pipe with HKS BOV, BMS intakes, BMS jb4 G5, backend pump flash, 19" MV4s, Golf T mod
Default 11-07-2015, 11:21 AM
Modify your XDF file to adjust the lower range on that table.
davidrbixby's Avatar
davidrbixby davidrbixby is offline
Car: 2008 335i Sedan
Default G5 - 11-07-2015, 10:22 PM
Terry, is this in the G5 already or does it need this upgrade for anti-lag?
2008 E90 Sedan 335i, BMS G5, Quaife LSD, BMS Intake, Forge Diverter Valves, ER Charge Pipe, Forge Intercooler, Macht Schnell down *****, Bilstein Suspension, M3 Hood, Bumper, Sideskirts, Custom 700hp Oil Cooler, Square 18x9.5 wheels with 275/35R18 Continental Cup Tires.
Default 11-07-2015, 10:57 PM
Anti-lag requires the extra wire but technically speaking any G5 board shipped after 10/1/15 has its 24k22 chip already programmed with the correct anti-lag firmware.
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 11-08-2015, 01:22 AM
Just want to check its the same position in dmacs rev 3 bt adapter? Between orange and black cables in position 4?
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF **|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
jamhot's Avatar
Default 11-08-2015, 09:51 AM
Thanks Terry, I figured it.
Default 11-08-2015, 10:14 AM
Yes same position.
Joey_335i Joey_335i is offline
Car: 2007 335i
Default Anti Lag Logs - 11-09-2015, 10:51 AM
Some logs of the anti lag, I know my afr is weird... my hpfp is old
Default 11-09-2015, 10:58 AM
AFR is maxed probably because of a faulty o2 sensor or related fault. Anti-lag won't work until that is fixed.
Car: 2007 335i
Default 11-09-2015, 11:10 AM
Yeah the car had an issue with the flash. it was right after flashing. I turned the ignition off then on and everything started working great!
1///M's Avatar
1///M 1///M is offline
Car: BMW 1M
Default 11-10-2015, 10:56 AM
Hi Terry,
for some reason I am getting half an engine light every time I use the trigger. Example: when putting the volume down when listening to the radio, it appears or just after I release the trigger while rolling..
the code that appears is 2f30.... I went to the extent of setting fud to 50 and the half engine light still appears.
other than that it works perfectly and I tested it after install and the IAT does drop....
am I missing something?
RHD Top Mount ST
J. Dub J. Dub is offline
Default 11-10-2015, 03:16 PM
I may have to ditch MHD and move to JB4, seems you guys have features we don't.
Van3 Van3 is offline
Car: Bimmer
Default 11-12-2015, 01:44 PM
I need this so bad.
Default 11-12-2015, 02:24 PM
Why ditch MHD? Load our JB4 MHD back end flash map!
http://www.n54tech.com/forums/showthread.php?t=29236
illrider illrider is offline
Default 11-13-2015, 06:43 AM
Is this safe to run with meth? I would assume you would want to set the meth start psi higher than the anti-lag psi to ensure you aren't spraying meth during anti-lag mode?
Default 11-13-2015, 10:39 AM
I think you'd want meth spraying during anti-lag to keep EGT down. At least its programmed that way for now.
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 11-13-2015, 05:54 PM
Terry,
So is the JB4 MHD E85 BEF better than the BimmerBoost JB4 E85 BEF?
I own both so price isn't a consideration.
I've done BB before but recently bought MHD to try
I'm going to have to reflash when I get my car back with its new computer.
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF ** | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
Default 11-13-2015, 06:39 PM
The MHD platform is preferred if its in the budget.
Car: 2009 BMW 135i
Default 11-13-2015, 11:00 PM
qwik_ss qwik_ss is offline
Default 11-13-2015, 11:09 PM
Hey terry, I'm on the latest firmware update but I'm still having issues with the cold weather bug on the anti lag. Is there anything you'd recommend me doing? Thank you
Default 11-14-2015, 12:17 AM
If the issue is the flash IAT min is set too high for the weather then lower it using TunerPro. If you have a log of the issue I can suggest a specific change.
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 11-14-2015, 12:26 AM
To make things easier, It could be automaticaly calculated from iat or outside temperature i guess
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Default 11-14-2015, 03:19 PM
It's all basically automatic. But in climates where the temps are less than say 40 degrees ambient I think one of the flash values needs to be adjusted. We've also adjusted the JB4 firmware for those climates. Since so few engage us with low weather logs and problems it's all being done on as needed basis. When people send in the logs showing those problems then we'll help them fix it and incorporate those changes in to the general firmware release.
Blaster400's Avatar
Blaster400 Blaster400 is offline
Car: 2007 BMW 335 E92
Default 11-14-2015, 06:48 PM
Doing high HP 3rd gear pulls for logging with ambient temps below 40 degrees is not easy and far from safe. That's probably why no one is sending you these logs.
JB4 G5 w/BMS MHD backend flash | MOTIV 750 | 100% E85 | MOTIV port injection | Fuel-It Stage 3+ LPFP | Akrapovic Exhaust | DSS Axles | DEFIV lockdown kit | Quaife LSD
