(#551)
cnm135i cnm135i is offline
Car: m135i
Default 01-12-2018, 04:23 PM
Originally Posted by WaqasRiyami
I updated to ISO_8_T2.
I will post some logs later, but they will be test's only as i am dialing in the TREBILA BEF Tune.
This is about boost control as I see it so the BEF should not influence that. 4-5 pulls in one log is needed to se if boost start oscillating like the picture above.
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4, Quaife LSD
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
Default 01-12-2018, 04:30 PM
Originally Posted by cnm135i
Then please test out the latest 8_T2 I have the below issue... Boost start out nicely on target but become more and more "wobbly" as pulls are added.
Any time you're looking at boost vs. target you need to also be looking at WGDC and FF.
Car: m135i
Default 01-12-2018, 04:45 PM
Here the same log with FF and WGDC. I sent the log on email also.
Default 01-12-2018, 05:01 PM
For tuning on PWG systems you can control the pid gain, which is P I and D factors scaled together, the FF, and the target itself. Often a lower PID gain improves oscillations
Car: m135i
Default 01-12-2018, 05:08 PM
I emailed you logs with both PID 25 and PID 10. The PID 10 is not much better. Maybe I went too low and PID 15 is the sweet spot. Guess I'll be back on the street testing again...
Default 01-12-2018, 05:53 PM
It's one of those things you'd have to dial in. At some point we'll expose the full P, I, and D functions in the tuning interface so you can better dial it in.
Car: m135i
Default 01-12-2018, 07:19 PM
Both you and Steve talk about matching FF and WGDC, but I would be inducing overboost by forcing up FF here wouldn't I?
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 01-13-2018, 10:20 AM
just did the diod thing and updated to the ISO firmware
attached 2 logs with map 1 and 3
fuel used is RON95 (91 octane) and running single nozzle CM10 with 100% meth
is there anything thati can change or do to make the car better?
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
Default 01-13-2018, 10:54 AM
FF is just the prediction of the ultimate WGDC output. Closer is better but I don't think it's an issue here. It seems like spool up mode (where WGDC is sitting at 100% as turbo spools) is cutting out a bit too soon causing the initial dip.
I tightened up spool mode for 3.5bar sensor maps on this test. See if its better or worse. If there is something there, I'll make it user adjustable like we have for the JB4 N54 single turbo firmware.
alo0oy215's Avatar
Car: 2012 f30 335i
Unhappy 01-14-2018, 02:55 AM
First thing, when cutting the diode should cut it from both sides and remove it or its ok to cut one side and leave it?!
The second question is why is the lp_fp and water temp became 0 and there not showing any thing after cutting the diode?!
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
Car: m135i
Default 01-14-2018, 02:59 AM
Terry
It was only running PID=10 that initial spool was not enough. PID=25 spool looks ok I think.
As said, I dont care much about a bit of tip in overboost as throttle takes care of that. It is the dip after wards that can sometimes be felt as loss of power.
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
You can cut one side only, i did it like this.
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | N20 3.5bar TMAP Sensor | TREBILA BEF Performance Tune | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | BMS 100% Meth-Dual CM7 Injection | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/iR4wm3I.jpg |
alo0oy215's Avatar
Car: 2012 f30 335i
Default 01-14-2018, 03:01 AM
Ok, and what about the lp_fp and water temp readings? Why did they became 0 and showing no other reading?!!!
Everything thing else is working perfectly and showing all the readings once i start the engine
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
Default 01-15-2018, 09:07 AM
ISO_9:
1) Redesigned logging engine for much faster sampling of all CANbus channels. Normal speed logging is around 10hz for all CANbus channels now, and slow speed logging remains an option for cars with older software and drops sampling down to around 6hz.
Car: m135i
Default 01-15-2018, 06:26 PM
ISO_9:
Oh wau - this is great! Which FW revison has 9 been build on - 8_T3? I'll test flash only 100-200 in about 3 hours. Will try this out then
Default 01-15-2018, 07:29 PM
It's built on T3
Marlinman's Avatar
Car: 335i coupe 2010
Default 01-16-2018, 09:24 AM
Terry, does this new firmware mean the slower CANbus guys may have better luck with Map 5 adapting? Right now I don't use map 5 because, as you've discussed with me, a possibility is the speed is too slow for the JB4 to adapt properly. Thank you
Default 01-16-2018, 09:26 AM
Yes, this should fix that issue! Try it!
Marlinman's Avatar
Default 01-16-2018, 09:35 AM
Okay awesome, well in the spirit of the current firmware I have, here is a final log I took yesterday; please let me know your feedback. Will install new FW today. Thanks again.
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Sweet, I'm in!!!! Thanks!
2013 BMW 335xi F30 N55 PWG
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 ISO_11 - Map 5/93 octane for winter/Custom tuned exhaust/stock turbo/Resonator Delete=Pops and Burbles!!
Stage 2 LPFP Walbro installed and strong, yeah I built it myself!
Coming Summer 2018: Speedtech BW 8374/PI/Dual Walbros/MHD BEF and Tune by Trebila = epic Summer!
Default 01-16-2018, 11:29 AM
I had the slower CANbus Issue , It solved my problem
Default 01-16-2018, 11:50 AM
I am not good in reading logs,But why do you have several Throttle Closures ?
Lamz Lamz is offline
Car: 2013 F30 335i
Default Iso 9 - 01-16-2018, 12:22 PM
Hi Terry
Im new to n54tech. I have a f30 n55 335i, bms intake,******* ** and jb4. Im running pump 95 octane down in South Africa. I did the upgrade to iso 9. There seems to be heavy knocking. I cant even log the car. The car idles at 4-5psi, ecu boost is starting at 22-25 psi when i try and log. When i go back to iso 8. The number look normal again. Idle at 0psi,14 afr. Im using all default settings as on page 1. Has anyone else had this problem. Should i just stick to iso7.12 or 8. Thanks.
Default 01-16-2018, 12:24 PM
Originally Posted by Lamz
Hi Terry
Did you Cut the Diode ??
Car: 2013 F30 335i
Default 01-16-2018, 01:56 PM
Yes. Cut one side. The numbers all just seemed to spike. Even afr was getting over 20. Back to 17/3 now and all seems good again. Logs looking smooth and numbers holding good.
