(#101)
Stoolz Stoolz is offline
Car: 11 135i
Default 03-12-2018, 12:21 AM
Car: 2011 N55 135DCT
Default Log - 03-26-2018, 02:21 AM
Hi all. Please see attached my log at 16psi 91 octane and cm2 meth. Had Tmap issues and this is now sorted. Still getting small overboost. But otherwise it looks good. virtual dyno figures at 17.2 psi shows 471whp. This was done in 3rd gear.
2011 135 n55 DCT RHD, MAMBA GTX3576R single turbo kit by CCD South-Africa,FBO,Fuel IT TBI and Stage2 Lpfp,BMS Jb4 and FSB,Devels Own meth kit. 3.5 inch single exhaust.
Default 03-26-2018, 02:22 AM
This is at 5500ft above sea level
Car: 11 135i
Default 05-15-2018, 07:28 PM
Ok.
How's the car going?
Had a chance to wind it up on the dyno?
Done any 1/4 runs?
What are your thoughts?
Are you happy or is there any pitfalls or traps to steer clear of?
Cheers!
Default 05-16-2018, 05:54 AM
Hi Going well. Busy Tuning it with TBI and CM10 meth. So far so Good.
I am very very happy. Car is fast at 25 ish PSI
keyap keyap is offline
Car: N55 135i
Default 05-16-2018, 05:58 AM
Good to know it's going well. Really wish I could see it in the real world.
Have you had it dyno'ed at 25? Wouldn't love to see the graph + log Vs a stage 2 option.
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
DD Map 7 at 20psi. Map 6 at 25psi for 'kill mode'
Car: 11 135i
Default 05-16-2018, 08:18 PM
Me too!
And love to see your quarter et/mph!
I know you got your car moving well before.
Default 05-17-2018, 03:03 AM
I only have some logs and speedo vids.
Car: 11 135i
Default 05-20-2018, 01:49 AM
Would you say all in all thinking about cost, time etc you have a better solution than a PS2?
I guess your answer will be something along the lines of "you gotta pay to play"
Seem quite an effort on our RHD cars
Default 05-20-2018, 12:31 PM
Yes this turbo conversion is amazing. Yes its a huge effort. But allworth it. Car is hauling.
Car: 11 135i
Default 05-20-2018, 01:05 PM
Ahhh good to know!
Still have a cheap as 2nd hand ps2 floating around over here. So close to just scooping it up.
Love NGs NFZ vids.
Can't wait to see some track results from you as well.
