Car: A Black 1
05-04-2009, 09:46 AM
Burner arrived today, thanks Terry!! I will give this a shot tonight.
05-04-2009, 10:05 AM
Terry, was lagfix increased on the other lagfix maps or map 7 only? Also, I'm assuming that the fuel pressure boost <2.5krpm is applicable to all maps?
Banned
Car: 135i, 335i, X5D
Tuner: BMS
Fuel pressure changes are on all maps, lagfix was only changed on map 7.
Banned
Tuner: BMS
05-04-2009, 10:06 AM
Sounds good! Looking forward to your feedback,
T
maniac
Car: e93
Tuner: BMS FTW !
05-04-2009, 10:59 AM
Originally Posted by DELTA BMW
If you are running a map that is just too strong for you wouldn't your car go into limpy?
Then scan and I assume if you get a tuner manipulation code you should change maps?
In summation, would I blow anything or break anything without the car going into some type of fail safe mode first?
you can run a map that is too strong and it may not limp.
you could just run SLOWER with a higher map so u need to test.
if your car isn't scary - it's just not fast enough !
JB3 2.0 beta / BMS Tuning Gauge / RPI IC / UR non catted DPs / UR CAI / Quiaife LSD / Snow Methanol Injection / VK Oil Cooler / Forge DVs
Riss Catch Can / M3 Rear Sway Bar / M Sport Steering Wheel / Paddle Shifting 6AT / Logic 7 / Dunlop Direzza Z1 235/255
Mod in Training
Car: AW 335i COUPE
Tuner: BMS
05-04-2009, 11:24 AM
so you can do damage without really knowing until its too late?
Banned
Tuner: BMS
05-04-2009, 11:33 AM
Lots of issues. Long term concern, compressor life at the high RPMs it takes to sustain boost levels at altitude. Short term concern, knock retard on your 91 octane. So map 2/3 is probably best.
Slow Car Owner
05-04-2009, 08:16 PM
Went from 8D3 to 8D4 along with my BMS tuning gauge today. Only thing I noticed is my BMS DCIs are MUCH louder now. I suppose this is a good thing... means more boost I guess.
It's too damp outside to get a good butt dyno reading, (rained for 3 days straight in NYC) but the DCI noise is much more pronounced on 8D4.
Jet Black | 6MT | 20% Tint
Best ET 12.446@111.23 /w 1.89 60ft (15psi meth not working) Best Trap 115.3
Car: e91 335i
Tuner: JB3
05-04-2009, 08:57 PM
has anyone strengthen the lagfix to max. using the BMS gauge? big difference?
Car: E60 M5/ 335i
Tuner: BMS
05-04-2009, 10:37 PM
I am not sure if i missed it, im sure i did.
What are the direct signs if you are running a map that is just too high on your car. Limp? CEL?
Other then loss of power running too much boost for your octane/mods, will you get a cEL or a limp?
05-04-2009, 11:54 PM
I hate how Cali doesnt have 93 octane... ****ing state sucks my nut.
maniac
Car: e93
Tuner: BMS FTW !
05-05-2009, 09:28 PM
FATS test maybe???
per scalbert: do a 3rd gear pull starting at 3000 rpm, when you hit 3,500 rpm note the time it takes to get to 6,500 rpm.
the shorter the time elapsed, the more added power you have.
so use a lower map as a FATS baseline, work your way up in maps doing FATS test to see if u r running faster.
note when doing a pull DO NOT hit the tranny kickdown on the 6AT.
cheers
maniac
Car: e93
Tuner: BMS FTW !
05-05-2009, 09:29 PM
only one word you need to know......... methanol
05-06-2009, 01:19 AM
Guys, im getting a programmer does not recognise 18F2431 processor... software sees it on K149, using Vista 64bit. Device on Com3 ideas?
Im using a really old beta eeprom from the arly jb3 days  ie BETA
maniac
Car: e93
Tuner: BMS FTW !
05-06-2009, 06:37 AM
if this is a burner question, better to put it in the burner thread.
05-07-2009, 09:14 AM
What is this methanol you speak of?
I gotta look into that, Im sick of paying $9/gal for 100 octane just to get the pump gas to go to 93 octane.
LeMans 135i ///M-sport 6MT
JB3 1.4 - 3" MS DP's - RR S3 Intake - RR OCC - BMW SSK - CDV - Golf Tee
18" CSL Rep's - 215/245 Dunlop Runcraps
Car: 2009 E92 335i 6MT
Tuner: JB3, BT, BMS Boost Gauge
05-07-2009, 10:11 AM
Terry has the 1-2 and 2-3 throttle closesure issue been resolved with rev 4 on 6MT cars?
Car: 135i jb3
Tuner: bms
05-07-2009, 11:05 AM
Im at 8,000 feet altitude no mods only DV´s , 92 oct th best here , i will use map 3 terry what do you think? will be good on track? or I will reach limp mode easier?
Please give me your opinion of which map I have to use at track and which one at highways
regards
Banned
Tuner: BMS
05-07-2009, 11:08 AM
regards
I would start with map 2 or 3 and keep in touch with me via email to see how that works. At elevation with lower octane there are a lot of variables in play.
Banned
Tuner: BMS
05-07-2009, 11:09 AM
It's been improved, may still be more work to do on it. The issue is there to a degree unmodified so completely killing it will take some time.
maniac
Car: e93
Tuner: BMS FTW !
05-07-2009, 11:42 AM
regards
i am at 8,500 feet and with 50% methanol and 50% distilled water being sprayed throttle body: my car runs MUCH faster with it.
methanol will cool your intake charge making our high altitude (thin) air much denser.
also methanol will give you race gas octane.
Banned
Tuner: BMS
05-07-2009, 11:43 AM
i am at 8,500 feet and with 50% methanol and 50 distilled water spraying into my intake: my car runs MUCH faster with it.
What map are you using again? 4?
maniac
Car: e93
Tuner: BMS FTW !
05-07-2009, 11:45 AM
look at my above post and then search forums under methanol.
maniac
Car: e93
Tuner: BMS FTW !
using map 3 on your 1.3 8D revision4.
Car: 135i convertible
Tuner: JB3 2.0....
8D rev4 -
05-07-2009, 12:48 PM
Terry,
I was finally able to get home after several weeks..... I got to test your newest 8D here in Germany. Man this is really the best one so far. I have only been rolling with map 3 but it's really powerful. I hear the turbos now when parked and revving. I swear I did not hear that before.
Thanks for your work.
can I test map 5 and 7 without upgrades or should I wait for my intake and maybe my dp's
| Thread Tools |
| Display Modes |
Copyright © 2007 - 2010, N54Tech.com | BMW N54 / N55 Engine Forum
