(#1201)
blckz06 blckz06 is offline
Car: 340i
Default 04-16-2018, 05:04 PM
Seems like I'm still able to log even when running map 0. I'm assuming logs would be identical between running map 0 and 4?
Default 04-16-2018, 07:27 PM
Yes
Bullitt1841's Avatar
Default 04-16-2018, 09:22 PM
Yes, I do it all the time. Haven't noticed any difference between the two.
2017 F36 440i Gran Coupe | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
SOLD: 2007 E90 335i | PURE Stage 2 N54 Turbos | JB4 | FBO | 160k+ miles on the car, 120k+ miles on the JB4
Car: 340i
Default 04-17-2018, 04:47 PM
Thought so, thanks!
High Flier's Avatar
High Flier High Flier is online now
Car: 340iX 6MT MPPSK
Default 04-18-2018, 06:27 AM
The Install Guide, link on first page of this thread, is Aug 2016. There is a more current install guide from Nov 2017: http://www.burgertuning.com/instruct...STALL_CARB.pdf
I haven't found any "official" bluetooth installation instructions from Burger Motorsports, just a few videos online. But just to confirm, the wire from the bluetooth module can connect to either of the red wires on the JB4 wire harness?
Hoosier Daddy Hoosier Daddy is offline
Car: M140i
Default 04-19-2018, 06:41 AM
Yes. Both are power
High Flier's Avatar
Default 04-19-2018, 05:44 PM
Probably a dumb question, but I'm assuming that I select rev3 on the app?
luchocamp's Avatar
Default 04-20-2018, 09:57 AM
This thread will be the single source of information for everything BMW B48/B58 JB4 related! Note both engines use the same hardware. The JB4 will detect the different during installation and map accordingly.
B48/B58 JB4 Install Guide: Latest Install Guide
JB4 Windows Interface: Latest Interface Download. When updating your interface you may need to first go to "add remove programs" and "remove" your previous JB4 interface. The B58 JB4 is fully compatible with JB4 Mobile and the REV2 & REV3 blue tooth adapters!
If you need directions on how to connect a laptop to your JB4 to update firmware or how to datalog Click here.
Map Guide as of v8 firmware:
Map0: Stock tuning, fully disable JB4
Map1: Additive map with peak of 3psi over stock added (91 octane)
Map2: Additive map with peak of 4psi over stock added (91-93 octane)
Map3: Additive map with peak of 6psi over stock added (93+ octane)
Map4: Stock tuning with CANbus features active
Map5: Additive map with peak of 6psi over stock added & more aggressive timing profile for higher octane fuel (experimental, 93+ octane, bolt on modifications)
Map6: Custom tuning map allowing both additive (below 10psi) and absolute (above 10psi) targeting
Map7: WMI map (boost varies based on WMI additive and map settings)
Firmware:
BMW_B48_B58_OBDII_9:
1) Redesigned CANbus logging engine for faster sample speed and all available parameters including cyl1-6 timing, water, oil, and trans temp, full time.
2) Corrected speedo calibration issue when using in dash menu.
3) Added FutureUseD Bit4 option to disable startup sweep.
4) Added in dash timing and AFR gauges under menu 2/3 and 2/4 respectively.
5) T2 - Fixed bug with fault code reading.
6) T4 - Fixed possible bug with alarm engaging.
BMW_B48_B58_OBDII_8:
1) Adjusted map numbering per above!
2) Removed intake temperature signal adjustment from map1. Option is now available for map6 or map7 using the 6cyl timing field. 0 disables it, value of 10 increases IAT sensor readings lowering timing, value of 70 decreases IAT sensor readings increasing timing. Adjustment active on maps 6 and 7 only. Experimental feature.
3) Adjusted additive maps so they can be used without OBDII cable
BMW_B48_B58_OBDII_7:
1) Added CANflap operation to allow control of the factory exhaust flapper from the drivers seat. Press the BC button for a second to change modes. Left arrow is flapper open full time, right arrow flapper in OEM operation which is generally closed unless at full throttle.
2) Internal CANbus changes to improve speed and operation.
3) Groundwork for virtual flex fuel sensor added. See E85 FAQ below.
4) Wastegate dutycycle offset for cars with modified exhaust that experience excessive throttle closure. When equipped with an EWG connector on the JB4 harness FutureUseA can be used to apply a static negative offset. Generally a value of 30 is a good starting point.
Default Settings:
Attachment 64379
'OBDII In Dash Menu
'0 map menu, map shown on tach
'1 Not currently used
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. (OFF tach = 0, ON tach = 1000)
'3 Not currently used
'4 Delete fault codes
'5 1st gear boost limiter, setting for gear boost limiters is RPM = boost * 200. e.g. 2000rpm = 10psi cap, 3000rpm = 15psi cap.
'6 2nd gear boost limiter
'7 3rd gear boost limiter
Copyright Notice:
B58
11.26 @124mph, LUCHOJB4, BMS BEF MHD, E85/Reg + meth 19psi ~ Set-up on Drag Track online instagram @luchocampusano ➡
High Flier
