(#876)
Kolbe's Avatar
Kolbe Kolbe is offline
Car: BMW F10 M5
Default 01-04-2018, 12:44 PM
Originally Posted by Kolbe
Hi, I am about to install my JB1 ==> JB4 upgrade and will install the stand alone BCM later. The first post states that Map1 is additive boost but I thought that it was changed to absolute boost. I am confused as the first post gets regularly updated. So, what is the situation i.c.w. Map1 - is it additive or absolute boost and what is the peak boost?
... my confusion is sorted out, thanks.
Sossa215 Sossa215 is offline
Car: F10 M5
Default 01-05-2018, 10:10 PM
So I'm waiting for my JB4 to be delivered to install it on my F10 M5, but I was wondering after install will I get any popping or burbling sounds from the exhaust? I don't have ********* but I do have a full titanium Akrapovic exhaust.
Default 01-06-2018, 01:09 AM
No, it will sound similar to stock.
Car: F10 M5
Default 01-06-2018, 02:00 AM
Thanks Terry, one other question you might be able to help me with. Which of the Maps is best for me to use with my setup? Iím not looking to change out my clutches.
Default 01-06-2018, 10:57 AM
Normally map1 is a good starting point, log and evaluate that.
Gab24m6's Avatar
Gab24m6 Gab24m6 is offline
Car: F13 ///M6
Default 01-13-2018, 05:07 PM
Where do I email my data logs?
Default 01-13-2018, 05:47 PM
You can post them to the support area on n54tech with details on the cars, or check the tech support email address on our website under contact us.
conquistador conquistador is offline
Car: 2012 335is
Default 01-14-2018, 12:38 PM
what changed for firmware 2.0?
Default 01-14-2018, 01:55 PM
It's for new v2 boards only.
Car: F10 M5
Default 01-14-2018, 08:03 PM
So if I have ******* ********* on my M5 and I'm installing the JB4 Beta do I have to keep on clearing that check engine light? If so how often will I have to clear that error?
Default 01-16-2018, 01:12 PM
Working on new firmware with much faster datalogging. Will post soon.
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 01-16-2018, 10:14 PM
Tried out the new FW... improved power delivery and the added monitor parameters make it a must-have. Same boost levels car feels stronger!
Thx Terry!
Default 01-16-2018, 10:17 PM
S63TU Firmware:
Firmware is in the first post. Note there are two separate board types and loading the wrong firmware for the board will result in check engine lights and no boost until the firmware is corrected. V1 systems (firmware version ending in //5) must use the JB4_S63TU_V1_xxx firmware. While V2 systems with integrated BCM (firmware version ending in //6) must use the JB4_S63TU_V2_xxx firmware.
V1_1_7_T1:
V2_2_1:
1) Redesigned the CANbus engine for much faster logging rates of all parameters resulting in smoother performance and better logging. By default the S63TU JB4 ships in "slow speed" CANbus mode (FutureUseD bit#4 = 1), which will run around 6hz from CAnbus on the new firmware. You can also try disabling this bit which will run 10hz from CANbus. If your vehicle can't handle the higher speed you'll see RPM drop out in logs. I'd be curious to know how many cars still require the slower speed with the new update.
2) Removed option for ulta-high speed logging (previously on bit7) as its no longer relevant.
3) Changed fuel pressure high and low to log full time.
4) Added load and calculated torque logging parameters for those running back end flash maps.
