(#276)
RayBan81's Avatar
RayBan81 RayBan81 is offline
Car: 335i E91
Default 04-25-2017, 10:38 AM
Originally Posted by MEGALE
I have a 2010 535xi with a 6AT. Will this work on my car?
Yes!
xHP Flashtool: The worlds first Android-based TCU Flashtuning tool!
More Infos on Youtube -> http://bit.ly/2hfYJT8
xHP on Facebook: https://www.facebook.com/xhpflashtool/
Maximum996's Avatar
Car: 08 535xi
Default 04-25-2017, 11:23 AM
The e60 flash is ready?
08 535Xi - jb4 iso w/bms flash, Bms dci, AR Kittyless DP, er cp with forge dv, second *** delete, muffler delete, trans sport mode enable, ets fmic, bms oil tstat bypass.
RayBan81's Avatar
Car: 335i E91
Default 04-25-2017, 12:28 PM
Yep, ready. Just waiting for one last OK for this release. Hopefully we can give it a go tomorrow.
Default 04-25-2017, 02:42 PM
Oh, can't wait. Subscribed!
Performance: Pro tuned MHD, DCI, AR kittens, ER FMIC & CP, Fuel-It Stage 2 LPFP w ported rail, RB turbos, RB inlets, KW V2, Mfactory LSD
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 04-25-2017, 05:32 PM
E-60 Flash? Is that a new tune flash for the car?
Default 04-25-2017, 06:28 PM
E60 is the chassis code, just like e90 e92
2007 e90 335i
Hexon turbos
Trebila Custom tuning
Turbeau Turbeau is offline
Default 04-25-2017, 10:04 PM
Can you brake boost in second gear?
Car: 2010 535i
Default 04-25-2017, 10:54 PM
For the E60, I recall reading somewhere that if we are using the SAT flash we need to flash back to the stock bin before flashing with xHP. Is this true?
Maximum996's Avatar
Car: 08 535xi
Default Yesterday, 12:54 AM
I believe as long as you do not have the coding missing fault, you can back up your sport flash...i had coding missing fault and got my flash guy to take care of it with the directions on the previous page.
I just hope the xhp flash for the e60 is compares to the sport flash alot of us 5ers have because of the more performance oriented up and downshifts, and holding gears at different throttle inputs and speeds...
Default Yesterday, 07:07 AM
I have the RWD Sport which comes standard with the sport flash some of you load into your AWD e60s (7601458). Curious to see the effect on both D and Sport mode.
I will flash it as soon as green light is given. To avoid bricking the car!
pits200 pits200 is offline
Default Yesterday, 07:08 AM
New D mode is too aggressive for twins. In the effort to compensate for the slow spool of a single, D mode for stage 3 is way too high revving. Most of us want these for standard D mode(slightly higher than Alpina, similar to stock) and very aggressive sport manual mode. When I want my car to run passive while the oil is warming up and it doesn't shift till 3200 is ridiculous while in D mode. There should be 2 stage 3s, one for singles, one for twins.
mfish123 mfish123 is offline
Car: 2009 BMW 335i xDrive E90 Sedan Auto Trans
Default Yesterday, 08:08 AM
Originally Posted by bradsm87
I was thinking the same. I'm sure many more cool things will come with time. In a perfect world, I'd love to see map packs as a single purchase then be able to choose with a slider or check box one of maybe 3 options for shift speed/firmness and 3 options for shift points for both D and S modes.
+2. That sort of functionality would be awesome!
2009 335i AT xdrive E90 Sedan
Xhp Stage 2
BQ Tuning Custom 93 Octane Tune
FBO + Inlets
RayBan81's Avatar
Car: 335i E91
Default Yesterday, 09:01 AM
Well, it's a similar story, like we had it the last weeks with the 335i. A lot of user have flashed their cars with WinkFP in the past, but never coded their TCUs after flash. xHP then complains about missing coding on backup.
I know this is pita for some guys, but we have to restore the coding after each flash, as the transmission is throwing it away each time you write on it. If we would ignore this fact, users will end up with a fault code in memory after using xHP. So no need to flash back to stock, but your TCU has to be coded, otherwise xHP won't do a backup. (which is required)
Well, there are 4 of them. Just use V1.1.
Maximum996's Avatar
Car: 08 535xi
Default Yesterday, 11:33 AM
Facebook says you have e60 flash available, i bought license and searched but no maps available yet...forget it had to update xhp, d mode better shifting, but s mode feels the same as the sport flash so far
RSicks's Avatar
RSicks RSicks is offline
Car: 2010 535i M-Sport
Default Yesterday, 12:49 PM
Is that on stage 3? I'm at work and can't play with my car, so I'm living vicariously through everyone.
'10 535i ///M Sport
RB PCV Mishimoto OCC BMS DCI ER FMIC & CP Forge DV E60 exhaust mod MHD E40 Tune
Maximum996's Avatar
Car: 08 535xi
Default Yesterday, 01:24 PM
E60 flash stage 3...needs alot of work, does not downshift to first in 3rd gear in s mode, and shift speeds seems same in s mode, but i should let the trans adapt maybe before i give my opinions...
Default Yesterday, 02:03 PM
Did you roll it back to stock sport mode with WinKFP? How is D mode?
Maximum996's Avatar
Car: 08 535xi
Default Yesterday, 02:23 PM
No i backed up my sport flash then flashed xhp stage 3...d mode definetly quiker shifts, at some speeds goes from 3rd to 5th real quik, if i look up for a split secong 4th is almost non existent at certain speeds, needs work...but like i said i will put more miles on it and let it adapt before i give anymore input...on a side note i would of been happy with all the up and downshift algorithims of my sport flash but with the added quiker shifts and other options of xhp...
HanSolo71 HanSolo71 is offline
Car: 2008 135i 'Vert M-Sport
Default Yesterday, 03:04 PM
I tried using a BimmerSoftware DCAN cable and it wouldn't connect. Do I need to buy one of the ones you linked?
Copyright 2007 - 2016, N54tech.com
