(#601)
m123 m123 is offline
Car: 440i F32
Default 04-04-2017, 02:53 PM
Originally Posted by ninefourteener
Hello, I about to order the JB4 + bluetooth module for my 2016 340i Msport.
Just a quick question..... will I be able to control the exhaust flap with the JB4?
Not yet for the b58
F32 440i JB4
F11 550i N63tu JB4 Stage 1
BlackCats BlackCats is offline
Car: bmw f30 320i LCI
Default 04-07-2017, 01:58 AM
Hello!
I'm awfully sorry! Could you help me please?
Yesterday I bought JB4 for my 320i LCI, but i don't see where I can connect BMS cable to update firmware, I have no socket for it in my JB4 box..
Box like this:
http://www.burgertuning.com/B58_JB4_...nce_tuner.html
Bee Pee Bee Pee is offline
Car: BMW F20 m135i
Default 04-07-2017, 02:07 AM
Open up the jb4 casing - remove grey connector of serial end of USB cable - plug into the empty rs232 type socket on the opposite end of jb4 board - lay USB cable into small half hole in jb4 casing - snap close top half of jb4 casing with USB cable sticking out from opposite end of main loom.
F20 M135i EB AT with options - what a hoot !
Default 04-07-2017, 03:08 AM
Wow! Thank you very much!
I will try it)
I hope, I don't ruin the casing while opening)
Mrpink Mrpink is offline
Car: M140i
Default 04-07-2017, 06:13 AM
Use a flat head screw driver which is approx the same size as the gap and just twist, do this both sides and it pops off easy.
f30roxs f30roxs is offline
Car: 340i
Default 04-11-2017, 05:40 PM
On the iPhone app, how do I check which JB4 version is currently installed?
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default EWG on B58 - 04-12-2017, 03:13 AM
Could someone please post a picture of the Location of the EWG connector on the B58.
Also do you have to change any settings (auto code delete) after fitting the KittyLess DP's.
Car: M140i
Default 04-12-2017, 03:56 AM
You need to remove the whole air box. Very easy.
Then below there is a heat shield with poppers, underneath there is the EGW connection. There is only one so you can't miss it or mistake it.
I just fitted and blew my board, even although I disconnected my battery first. My only thoughts are that I left the OBD connector in place and there was some residual power in the system still, as it only took me about 5 mins to fit. So if I was you I would be safe, disconnect the battery and wait 30 mins or so to be safe, maybe pop out the OBD port too. I might be completely wrong here but just my thoughts.
BazBar's Avatar
Default 04-12-2017, 07:55 AM
Thanks for the Advice, think i will remove the OBD connector as well as disconnect the battery. Do you just pull UP on the bottom half of the Air Box to remove it ?.
Car: M140i
Default 04-12-2017, 09:06 AM
Yep, it's just held on 3 rubber mounts. Pops off easily.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 04-24-2017, 01:36 AM
Originally Posted by RMM
Here are some logs on a 120i with different maps and gas FYI. Any comment would appreciate. Waiting for full tank of 98 to get some 98 runs. Just doing 1-2-3rd gear pull, about 0-130km.
Post in the support section :
http://www.n54tech.com/forums/forumdisplay.php?f=35
And you need to upload the actual .CSV file to the forum using the attach feature not an excel graph. Support requests in this section are deleted, and BMS will not offer support here.
Here's a video regarding how to data log
https://youtu.be/vWJPJk_pSbk
~Lowon
Mods: Stock for now
2016 Porsche 911 (991) GT3 RS: white, PDK, carbon ceramic brakes, Fully loaded
Mods: Fabspeed race headers, competition exhaust, High flow fiters, Ecu flash race gas and pump tune, roll cage, schroth harness, clear bra.
2017 Audi R8 V10 plus- dynamite red, fully loaded
Mods: Currently stock (hopefully a super charger and full exhaust soon)
Thisisdudewhoru Thisisdudewhoru is offline
OEM+
Car: '16 340i
Default 04-24-2017, 08:46 PM
Besides killing o2 sensors. Is there any reason I shouldn't put a lil bit of 110 leaded in the car before drag racing? We have 110 race gas at pumps around here. I probably only go to track 1 or 2 times a year. Maybe 5 passes then immediately fill up with 93 to dilute the rest back out.
2 gal 110 plus 3 gal 93 equals 5 gal 100.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake
RMM RMM is offline
Car: 120i
Default 04-25-2017, 08:05 AM
Thanks for the help, I deleted the message. The support forum is a bit of a mess with all the mixed together, I wanted to find someone with logs on the B48B to compare with but I will post there and see.
I am running map 7 now and it is a lot of fun, I guess I should post a log in support group to see if it looks OK, there is some slight surge when you go form no throttle to full in 3000-4000 RPM, but other then that it is like a different car.
One general question regarding these new higher compression turbo engine, it looks like they run aggressive and lean when off boost, but when the boost kicks in at lower RPM there is only 3-6 deg advance and still is pretty lean even on boost, then timing climb as RPM climb. Is this normal for this these new engine or what people expect with modern high compression turbo's?
Also I tired map 6 but it didn't seem to work, always similar to map 2 regardless of the parameters, is map 6 non functional at this stage? Any timeline for it to be enabled?
Copyright 2007 - 2016, N54tech.com
