(#426)
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 07-06-2017, 02:34 PM
What's this MHD XHP flash of which you speak?
2008 E90 335xi AT 59K MILES
MHD CUSTOM E50, N20 TMAP, FUEL-IT TBI & STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, FORGE DV, BMS DCI, BMS T-STAT DELETE, BMS OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, ALPINA B3 TCU, SCOOPS
N54QC N54QC is offline
Car: 07 BMW 335i
Default 07-06-2017, 03:37 PM
I'm assuming you are referring to me but if you select an MHD map, it comes up with another screen that lets you select transmission type. XHP flashed transmission is one of the options. I only read about it and noticed it the one day when I was scrolling through the MHD app looking for something else even though I don't use there maps.
VTT Stage 2+, JB4 G5 w/ Trebila BEF, Fuel-It Stage 3, XHP Stage 3, VTT Inlets, MMP Outlets, BMS Meth Dual 10/5CM, VRSF 7" FMIC, VRSF **'s, BMS CP, BMS DCI, Turbosmart Dual Port, 3.5 TMAP, BMS OCC, VTT PVC, BMS Anti-Lag, NGK 5992, M3 Rear Upper Controls And Godspeed TB's, Lock-Down Brace, 235/275-18 PSS
Maximum996's Avatar
Car: 08 535xi
Default 07-06-2017, 05:44 PM
The MHD only flash xhp is an option, with the jb4 backend it is not available, i have asked terry about this and basically from what i understand he does not believe there is a need for this, but i do wonder if there is especially since other tuners offer this option as well...
08 535Xi - jb4 iso w/mhd flash, Bms dci, AR ********* **, er cp with forge dv, second *** delete, muffler delete, xhp trans flash, ets fmic, bms oil tstat bypass.
harrychiu012 harrychiu012 is offline
Car: BMW E92 335i
Default 07-06-2017, 11:17 PM
I've read some people had issue with JB4 while flashing. So does turning JB4 to map 0 solve the problem? Or you have to unplugged the unit from the DME?
Also, with MHD having XHP option while flashing, is there anything JB4 MHD backend flash are missing out on?
Stucks Stucks is offline
Default 07-07-2017, 02:57 AM
I flashed xhp stage 3 with the jb4 in map 0 and a bef on the car at the time....no issues.
Current: 2008 e92 335i coupe.
rays 335i's Avatar
rays 335i rays 335i is offline
Car: 07 335 coupe
Default 07-09-2017, 02:55 PM
ok got it working once i got mhd v7, and works great in manual mode. where can i adjust in xhp or mhd to get firmer shifts in all modes???
09 conv mhd v7 tune xhp stage 3 bms intake ***
255/19 front 275/ 19 rear e85
rays 335i's Avatar
Car: 07 335 coupe
Default 07-09-2017, 03:01 PM
also the xhp option in mhd im using it because i have xhp, but what does it change or exactly what does is do???
E92Beast E92Beast is offline
Car: 09 E92 335i AT
Default 07-17-2017, 03:42 PM
As mentioned in a few post a few pages back by others. I have the stage 2 xhp with latest update flash version. When in M mode on low throttle, shifting between 1500-2500 I get some shift flare, mostly 2-3, 3-4. I have about 25 miles on the flash maybe more. Will this clear up? I had no issue with Alpina and I'm not able to log with Testo. Thanks. My dme flash target's around 650-660 dmetq e60 custom flash
09 E92 335i Msport, fbo+e85 flash, 11.91 @ 119
10 E90 335i, MHD Stage 1
1and1 1and1 is offline
Car: '09 135i
Default 07-17-2017, 05:20 PM
Give it some more miles for the adaptation to settle. I run S2 on my e82 with mhd s1+ ots and m mode is actually pretty smooth just cruising around.
D mode adapts the quickest, by about 50 miles of light throttle driving it's all set. M mode seems to take a bit longer, but after a few days it's all good.
1and1
135i - E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD s1+ / xHP s2
X1 - E84.N20 2013 / MGM / Stock - The Wife's
RayBan81's Avatar
RayBan81 RayBan81 is offline
Car: 335i E91
Default 07-19-2017, 04:36 AM
This option affects the TQ setting of the ECU, to match the TQ Values and Limits used in xHP maps. Depending on what setting was used in the past, this can greatly improve overall shift quality and makes sure, that xHP OTS maps behave as similar as possible on your car, compared to our development cars.
xHP Flashtool: The worlds first Android-based TCU Flashtuning tool!
More Infos on Youtube -> http://bit.ly/2hfYJT8
xHP on Facebook: https://www.facebook.com/xhpflashtool/
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-19-2017, 04:51 AM
On stage 2 anyone noticed on the D mode on 3rd gear when you are on low speed and slowly accelerating it vibrate and wobbling that u feel the whole car shaking between 1500rpm until it's 2000-2500 then goes normal.
Didn't had this issue on the alpina flash and so far no errors
09 E92 335i - GULF Version, Hot-Climate Version, Middle East package, M Sports suspension, 19" Rims, 6AT with Xhp stage 2 flash, JB4 - Map 3 - MHD BMS Race Flash with modified Duty Bais and PID - BMS Oil Cooler Valve - RB PCV - K&N drop in Filter - AFE Air Scoops - 98 Super Fuel - WAGNER FMIC - 3" **'s - BMS Water/Meth 40/60 VP Racing M1 with 70 adder
Maximum996's Avatar
Car: 08 535xi
Default 07-19-2017, 05:01 AM
I have the jb4 backend mhd flash and do not see the xhp flash option... Also, the previous updates that were applied to the e90s there were no e60 updates..
RayBan81's Avatar
Car: 335i E91
Default 07-19-2017, 05:18 AM
With JB4 BEF there are no options anyway in MHD. This applies only to OTS MHD Maps.
Maximum996's Avatar
Car: 08 535xi
Default 07-19-2017, 10:10 AM
This goes back to me asking Terry to make specific xhp maps for us backend jb4 guys, basically from what i got he does not believe there would be any benefit from returning the torque calculations back to original (he has mentioned that we can do it in tunerpro, but i have no idea, as many others, on how to do it). If there is a benefit, could you explain that there is, especially since it would be helping our autos with even better shift quality. Or is this going to be an MHD ots only feature?
RayBan81's Avatar
Car: 335i E91
Default 07-19-2017, 10:45 AM
From my understanding, thats only works in MHD OTS Maps, as the BEF is delivered through MHD "as it is". ATM I don't even have an idea what TQ values the BEF transmits, so I can't judge on that if there could be a benefit.
tho tho is offline
Car: 2011 335i Convertible
Default 07-19-2017, 11:35 AM
I recently changed my phone and my license and purchased flash seemed to carry over fine but I have 2 issues:
1. When I try to flash, it asks me to do a backup. I copied my backup files over from the old phone but it looks like I'm missing a setting?
2. When I try to do another backup (not sure if this would even work as I've already flashed my TCU with stage 3), I get the error message "Too many read errors. Your INPA cable returned empty data packets. Aborting the process. Errors total:3" This is the same cable that I've used in the past to do the XHP and the MHD flashes?
2011 335i - JB4 ISO | MHD PUMP BEF | Exhaust Mods | CP | 5" stepped FMIC | BMS Meth Injection CM12 | BMS Intake | Pure Stage 2 | Pure Inlet | FF wires | Fuel It Stage 2 | DV+ | N20 TMAP | Ethanol mix
RayBan81's Avatar
Car: 335i E91
Default 07-19-2017, 11:52 AM
+ copy the xhp.state file from the old phone and you're good to go again.
rays 335i's Avatar
Car: 07 335 coupe
Default 07-19-2017, 12:05 PM
yeah sort of a mild groan, as though it is shifting too soon or on /off clutches not in harmony. find myself in s-mode to work around.
E92 420 E92 420 is offline
Default 07-19-2017, 12:45 PM
Is this not a torque converter issue. Termed "transmission shudder"
I got this after flashing alpina and it only got worse. I used some stuff called lube guard auto transmission shudder fix and it cured it! It's a friction modifier you put in the transmission oil.
Maybe @rayban can chime in on this?
UK WEDGE TUNED
RB TURBO 335i
Rushan's Avatar
Car: 335i E92 2009
Default 07-20-2017, 01:44 AM
So I'm not the only one...
Additives will mask it but I believe the issue related to something in the tune, on the alpina and stock flash I never had this issue, and I'm sure my transmission not abused
RayBan81's Avatar
Car: 335i E91
Default 07-24-2017, 01:59 AM
That's the Torque Converter dying most likely. With closed torque converter clutch on low revs it gets more noticeable. Stock, Alpina and Stage 3 all used different strategies for the TC clutch, thats why it gets more or less noticeable.
RayBan81's Avatar
Car: 335i E91
Default 07-25-2017, 05:33 AM
Happy to introduce the xHP SUPER - LICENSE.
Due to popular demand, we introduce the possibility to purchase the General Flash License and ALL OTS Maps in one sweep. So for everyone not sure, what Map to take, this is the route to go and save 77 USD/EUR compared to single purchases.
Existing customers may upgrade at the following rates:
Stage 3 customers: 30 USD
Stage 2 customers: 50 USD
Stage 1 customers: 70 USD
Please contact us under office@rbttuning.com with your VIN, if you want to upgrade!
Please update to the latest release (V1.1.72) to get the license!
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 07-25-2017, 02:34 PM
Quoted wrong thread
08 E92 335i AT 20k Miles | Wedge E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ Wedge E60 flash 1/4 = 11.8 @ 120
Default 07-25-2017, 02:37 PM
Any more info on this, just tried to flash my friends car and his said same thing at 75% of backup. He's never installed xhp before. Could it be the cable itself "Too many read errors. Your INPA cable returned empty data packets"
RayBan81's Avatar
Car: 335i E91
Default Yesterday, 03:00 AM
It's just an unstable connection. When an errors occur towards the end of the backup, it's likely one of 2 things:
- Cable not stable on heavy use (get new one from Bimmergeeks)
- Battery of vehicle got low
