phoebee phoebee is offline
Car: 428i
Thumbs up How to check knock on jb4 mobile?? - 08-25-2017, 11:08 PM
Hello
F32 N20 jb4 ewg 2014+
I using bluetooth jb4 mobile.
Q1. How to know knock on jb4mobile while driving?
Q2. Can I change maps with driving on jb4mobile?
Q3. Is there anybody use map2 with stock car?
Thank you very much.!!
Default 08-26-2017, 08:39 AM
1) You'd want to look at ignition timing and check for repeated 3 degree drops. There is a how to read logs thread here if you need additional advice on that: http://www.n54tech.com/forums/showthread.php?t=21269
2) Just double tap the map gauge on the front, or select change map from user adjustment.
3) On higher octane some have gotten away with it.
Car: 428i
Default I have one more question - 08-28-2017, 04:18 PM
thank you so much for answer.
I have one more question.
There is no matching actual gear and gear on jb4mobile.
Why does this happen?
Is there solution? )))
