Default speedtech 7670 DCT logs - 03-20-2018, 02:07 AM
Wanted to post a few logs and dragy results on my build. Finally getting the PID settings dialed in. Still a little boost spike but I am working it. So far OEM controls is doing a good job can hold whatever boost I want so far. Dynojet at 575/620 but need to redyno with cleaner boost curve (this was with a larger spike). Have about 2K on the speedtech and SSP clutches so far.
https://***********/u/jturboawd/23ps...25-26-27-28-29
2012 N55 135I, Speedtech 7670, JB4 + MHD, Fuel-it port injection & stage 3 LPFP, M4 A2W IC, Mfactory LSD, KW V1, Apex EC-7
cnm135i cnm135i is offline
Car: m135i
Default 03-20-2018, 02:30 AM
Definitely sparaying enough meth haha! I'd be a little concerned not getting any throttle closure with all that over boost.
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4, Quaife LSD
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
Default 03-20-2018, 02:38 AM
its a single cm10, likely not needed just the one I had. Probably need to go down to a 7 or 5. Its only boost juice though pre intercooler. Youre right on the throttle closures, not sure whats going on there. timing is good though, enough octane with e50 and some meth.
luchocamp's Avatar
Default 03-20-2018, 02:45 AM
Great ..... keep it up !
11.26 @124mph, LUCHOJB4, BMS BEF MHD, E85/Reg + meth 19psi ~ Set-up on Drag Track online instagram @luchocampusano ➡
Car: m135i
Default 03-20-2018, 05:45 AM
A single CM10 causing trims to bottom out...sure its not a CM12? Even running much lower boost I have never had my CM10 affect trims that much. However when I tested all my nozzles i found that they dont exactly deliver as advertised sooooo haha
Default 03-20-2018, 05:53 AM
@cnm 135: You are right.... I need to back off the PI from the looks of it. I was running more E the other day, now I am down to e50ish. The AFR is to fat. Ill pull in PI some.
Car: m135i
Default 03-20-2018, 05:08 PM
Huh? You are running meth+PI?
Default 03-20-2018, 05:29 PM
Yeah I backed the pi down to 50
I had a meth kit lying around when I built her
Keeping iat suppressed aids in tuning
Default 03-20-2018, 05:31 PM
I’ll post 60-130 and more logs tomorrow
Having 3rd gear traction problems
luchocamp's Avatar
Default 03-20-2018, 05:34 PM
Iíll post 60-130 and more logs tomorrow
Love that 3rd gear traction problems .... that's good news
Default 03-20-2018, 05:38 PM
Rwd problems lol. And I’m on 285 ps2. Need drag radials
Car: m135i
Default 03-20-2018, 05:46 PM
3rd gear hahaha I always log in 5th to get a clean log (8AT so my 5th is probably similar to your 4th) I am on 245 PSS (stock size). I get consistent wheel spin in 4th up to ~65mph. I blame the dusty/poorly surfaced roads though. And the PSS - grip went down very fast after the first ~8000miles.
https://youtu.be/QB2Qndk95sc
Default 03-20-2018, 06:07 PM
I have lsd and good rubber but she just gets loose at 22. Sucks. I’m going to cap the boost for 3rd and up it to 25 for some runs tomorrow.
Newguy123's Avatar
Car: 12' 135i
Default 03-21-2018, 01:28 PM
in for some 60-130 results!
12' DCT 135i
#PURETURBOS
#FUELIT
Default 03-21-2018, 04:06 PM
Still having traction problems. Logs look good but only hitting 8.1 spinning through 3rd. Tried traction control but could only get 4.2 to 60 and 12. Have much to learn. I might need stickier tires.
Car: m135i
Default 03-21-2018, 05:41 PM
My best ever 0-60 is 4.3 so in the same ballpark and result is the same no matter what driving mode I try. So damn difficult putting the power down.
I'd really like to try the Nankang AR1 - just can't find it here in China. The AD08R is very popular so I'll probably end up buying that.
keyap keyap is offline
Car: N55 135i
Default 03-22-2018, 07:28 AM
Unless you've already upgraded, keep an eye on those drive shafts too.
Just finished changing a broken one on mine
Default 03-22-2018, 08:36 AM
Keyap,
When did you break them? What was the load event? Launch?
Car: N55 135i
Default 03-22-2018, 10:07 AM
3rd gear rolling run going WOT at ~4000 rpm, targetting 26psi.
I believe Newguy123 also did the same but I'm not sure of specifics
Default 03-22-2018, 11:05 AM
What did you upgrade to? That spool and peak torque did it I am sure. I fractured the joint on one in my old e36 m3 turbo, similar.
Car: N55 135i
Default 03-23-2018, 05:34 AM
Stock has gone back on for now, simply because cost to me with this option was £0
The JB4 is however firmly pinned on mapped 7 until something changes. As you said, this is probably a result of how the PS2 delivers torque so may not be as much of an issue with singles
The more and more I see the singles progressing the more I'm wondering whether to switch? The PS2 is great, but both have their place depending on end goal and for those looking at 500+ I know which way I'd go now.
I'm also conscious of the DCT and, so far, it would appear that singles may have some advantages.
houtan houtan is offline
Default 03-23-2018, 06:13 AM
You say drive shafts. There is only one. Just wanted to make sure I understand what you broke. Was it the drive shaft or one of the axles?
also, are you guys running upgraded subframe bushings. I am not sure what is causing the drive shaft to break, but having the subframe flop around back there with soo much power makes me think upgraded bushings may help.
newguy broke something in the driveshaft around the area where it connects to the differential.
