Newguy123's Avatar
Car: 12' 135i
Default 01-18-2018, 09:43 AM
You shop should have a hand held vacuum pump. You can test the wastegate in under 5 mins from the top to verify it is closing completely. If that checks out remove the intake and hook a boost leak tester up to the turbo Inlet pressurize up to 10-15 psi listen for leaks
12' DCT 135i
#PURETURBOS
#FUELIT
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 01-18-2018, 05:47 PM
That seems to be a big boost leak.
I got my ps2 installed today. Did some pull on map5 to see the difference with out changing nothing beside turbos and I"m over boosting up to 20psi been 16 target,
and slipping on 3rd like hell. Tried map 2 and boost seems normal around 15 but still no traction.
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
HydroStream6 HydroStream6 is offline
Car: 2010 335i xDrive Sedan
Default 01-18-2018, 06:11 PM
I will almost guarantee it's an issue with the reference line on the wastegate actuator or solenoid. I have an xdrive as well, and you can reach it without too much effort. I've done it. I think I did it from underneath, I don't remember. But it's doable. The line is either pinched/broken/disconnected. Often times, the rubber gets brittle and won't go back on and stay on. You need to cut half inch off and reconnect.
hi rpm hi rpm is offline
Car: 2013 335i Xdrive Coupe
Default 01-18-2018, 09:40 PM
Hopefully tomorrow I can swing by the shop and take what I've learned.
Originally Posted by cnm135i
93aki is good for flat 16psi all day. You will get in trouble running 17psi though with hpfp crashing. I have JB4 logs of every possible combination I'd say...
What's your date of production, aka do you have the newer HPFP? Item number 13518604231. If you have the old DME that can be unlocked electronically, you supposedly have the HPFP that's better than this one.
Peter @ Pure's Avatar
Car: F20 M135i
Default 01-19-2018, 12:23 AM
On F series there are not magical HPFP's that flow a lot more. They are all the same. Like people have said around 16 psi on pump fuel should be doable. If the pump fuel contains 10+ % ethanol you may get issues.
F21 M140i - currently stock
F80 M3 - 100-200: 4.9, 60-130: 5.6
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 01-19-2018, 12:30 AM
The story was that the E series HPFP had a little higher capacity than F. But the other day I found out the changeover to the new one happened before the E>F transition, and I have the new low capacity one.
I can only get 91 locally without ethanol, so I've been using pump E30. I don't know the base fuel octane but I'm sure it's the worst they could find, 85 or 87, so the end result is 94-95. I can mix 91 with E85, but pump E30 is sooo much easier.
Default 01-19-2018, 02:50 PM
Taking it to the mechanic, I relayed the working theory that it was the wastegate actuator vacuum line, and in about a half an hour he'd fixed it and taken a test drive. According to him the approx. 3" line leading to the boost solenoid was loose, so he replaced it. No apparent problem with the direct connection to the wastegate actuator.
Long story short it's already too fast at 11psi and it's for sale now. Not really. :D
Car: F20 M135i
Default 01-19-2018, 03:22 PM
Glad you had it fixed. Now enjoy the car with pure stage2!
peter@pureturbos.eu
pureturbos.eu
Default 01-20-2018, 08:39 PM
It looks like my current limit is 13.5psi. Preliminary, since I did approximate fuel mixing instead of the usual full tank of E30. (Tried to get octane to 93.)
At 14, I think I could feel the timing being pulled, the car deciding to tone things down a bit. Logs seem to reflect it. I don't feel that bad settling for less at the moment, since the car screams at 13 and 13.5. I do have a...striped tiger. I'll do "final" tuning in a week or so, and maybe port injection for pure E85 in a year if I'm bored.
Thanks all for the advice in this thread. Logs here for reference, feel free to comment.
13: https://i.imgur.com/YLKI2nC.jpg
13.5: https://i.imgur.com/5y2v0Rv.jpg
14: https://i.imgur.com/mpZeVLG.jpg
