CT_Drifter's Avatar
CT_Drifter CT_Drifter is offline
Car: 14' F30 335i EWG N55
Default N55 EWG PS2, conistant misfire Cyl 6 at 6K - 11-17-2017, 08:33 AM
2014 335i n55 EWG with Pure Stage 2, GFB diverter, stock inlet, BMS intake, VRSF **, resistor mod, BMS meth & JB4 running ~E30 and 100% Meth with CM10 nozzle.
At higher boost levels (above ~19psi) I consistently get cylinder 6 misfire at 6K rpm with these codes:
140010 misfires, more cylinders: Recognized
140610 misfires, cylinder 6: Recognized
140001 misfires, more cylinders: ignition switched off
000000 No description found
Car has 50k miles on it. I just changed to NGK 97506 plugs gapped to .020" and replaced cylinder 6 coil with Delphi GN10571.
Is there anyway to determine root cause of misfire? See attached log with timing on all cylinders. Thanks
Newguy123's Avatar
Car: 12' 135i
Default 11-17-2017, 09:05 AM
Auto?
12' DCT 135i
#PURETURBOS
#FUELIT
CT_Drifter's Avatar
Default 11-17-2017, 10:08 AM
Nope, stick with OEM DMF and 550i clutch.
Default 11-20-2017, 12:24 AM
Hard to diagnose misfires with logs but HPFP is beginning to struggle. Meth flow is a bit weak, I'd recommend investigating that first.
cnm135i cnm135i is offline
Car: m135i
Default 11-20-2017, 01:13 AM
Running that much boost I'd recommend you to get a BEF to get trims re-scaled - only so much you can achieve by increasing FOL. It is maxing out shortly during tip-in and getting your meth flowing properly will not solve this I think. Not a big deal...but for piece of mind
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4, Quaife LSD
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
Newguy123's Avatar
Car: 12' 135i
Default 11-20-2017, 08:35 AM
18-20 psi is also where the DMFW can start to cause misfire issues with a PS2...my car did it on anything over 18psi always between 5800-6200 rpms until I swapped in the m4 non weighted DMFW
12' DCT 135i
#PURETURBOS
#FUELIT
CT_Drifter's Avatar
Default 11-21-2017, 10:34 AM
I figured it was the DMFW and just ordered the Mfactory SMF. I wasn't aware of the M4 flywheel, does it fit on n55? Do you have a P/N?
