MalibuMafiaV MalibuMafiaV is offline
Car: V10M5 & turbo stuff
Default have I seriously gone through 3 N54's in 1 year? - 11-09-2017, 12:50 PM
This is my 3rd! yes 3rd! N54 low miles. Good logs ( they're posted in the log section ) and now this? wtf is this? I'm hoping it's just a head gasket. Or at the most a cracked head...
https://www.youtube.com/watch?v=N9fMqRupPL8
I used a tiny camera to look inside a bit. I found cyl 3-4-5 becoming steam cleaned by coolant. The ignition coils were also extremely wet. Cyl 4 misfired and I immediately pulled over turned car off and found that. Luckily I was close to home and coasted in Natural back with the engine off.
I have not started it since. I pulled all the plugs and they all look fine. I opened the oil cooler top holes. No coolant in the oil that I can see.
What are your guys thoughts? I have a compression tester sitting here I can use as well.
www.themalibumafia.com
Instagram - @MalibuMV
2006 BMW M5 - REALLY LOUD
2007 BMW 335i - Single Turbo 6266
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 11-09-2017, 01:12 PM
Wow what the hell! Are those pits an area where water would get to if there was a head gasket issue? Was the coolant contaminated? Did the car overheat?
Default 11-09-2017, 01:17 PM
no contamination and car dd not overheat.
Where the coolant is sizzling are just small little pits on the cylinder head. The coolant just collected in there from coming out of some where else. I have no idea where.... and that's where I stand with this.
Newguy123's Avatar
Car: 12' 135i
Default 11-09-2017, 01:30 PM
time to think about an N55
jk hope it all works out
12' DCT 135i
#PURETURBOS
#FUELIT
Default 11-09-2017, 01:36 PM
Ha. And have the same if not worse issues. Thanks man I hope it works out to.
Like I said if it's just a head gasket? cool that **** I can replace myself in my garage.
Pessimistic Poster
Car: 135i N54
Default 11-09-2017, 05:00 PM
Don't you have to remove the turbos and re-do the whole valvetrain timing with N54 head gasket?
Default 11-09-2017, 07:22 PM
Yup!
IMHO, I'd rather just swap motor than do a head gasket swap.
Default 11-09-2017, 11:48 PM
Yup!
Head gasket replacement or head is the only option at this point. Or sell car as is. If I get ANOTHER engine that would be the 4th engine Iíve put in this year in 1 year.
naoaki's Avatar
naoaki naoaki is offline
Default 11-10-2017, 01:22 AM
There is a cool place in a great place. It seems there is a crack in the head itself rather than head G / K.
BMW 2007 E90 335i
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 11-10-2017, 09:35 AM
A leaking head gasket doesn't seem like it would be able to get coolant in those holes ... you confirmed it was actually coolant in the pits, not just water?
No sign of coolant anywhere except the pits and coil holes, and evidence of steam in the chambers - together, that makes me think cracked head.
Would be interested to find out where and how it cracked.
2009 535i Sport - 548whp
Software :
Car: 2010 135i
Default 11-12-2017, 01:57 PM
Are we sure that it's not fuel?
My coolant (BMW) is a purpleish color.
2010 135i auto, MHD E40 tune, Fuel-It stg 2 pump, best 1/4 mile 11.863 @ 119.17 mph
new mods this year, VRSF 5" stepped IC, RB EVO inlets, CP-e/Tial CP, 1320 **'s, xhp stg 3 trans tune, E-85 tune
Best 1/8 mile: 7.469 @ 98.56, 1.769 60'
Best 1/4 mile: 11.480 @ 121.79 1.802 60'
natedog7700's Avatar
natedog7700 natedog7700 is offline
Car: 2007 bmw 335i e90 auto
Default 11-12-2017, 03:50 PM
I see your running a 6266, what HP levels are you at? What are your mods? Who has been tuning the car?
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
2012 Ferrari 458 Italia - SOLD
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default 11-13-2017, 07:51 AM
Yup!
No way, I can do a head gasket swap in the car in under 10 hours. Pulling a motor and transferring everything over is a huge hassle. If you are running the right turbos, just two V-bands and the head comes out, turbos stay where they are.
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
Default 11-14-2017, 11:48 AM
Definitely not fuel.
Was only on 17-18psi. Nothing crazy. same tune EVERYONE else uses. Jb4 w/ MHD backend.
Yeah that's what I'm pretty sure it is to is cracked head. I'm just selling the car as is though. Already have a buyer. Taking a huge loss on the car. But don't care at this point. 4 engines in 1 year isn't suppose to ever happen.
Default 11-14-2017, 11:57 AM
To each their own, re doing the timing etc is not for me. Swapping stuff over is simple, esp when we've already done it hundreds of times.
LessIsMore's Avatar
Inner Circle Member
Default 11-14-2017, 01:31 PM
not sure of you saw this ...
http://www.n54tech.com/forums/showthread.php?t=49778
Suck to take a big loss on it, but sanity is worth something too
Curious - did you buy all the engines from the same place? If they blew so quick, any of them still within a 30/90/etc. day warranty?
Never heard/ seen of anyone cracking an N54 head ... I'm sure it's happened, but that would make me suspect it wasn't 100% when you got it.
Software :
Stucks Stucks is offline
Default 11-16-2017, 05:03 AM
Did you do a compression test and leakdown of the new motors upon acquisition of them? Perhaps you just have bad luck and picked up some not so great condition motors?
Current: 2008 e92 335i coupe.
