(#426)
Omar Omar is offline
Car: F06 640I
Default 12-20-2017, 02:07 PM
You forgot the most important thing, what fuel?
Sorry it's running 93 pump fuel
Default 12-20-2017, 02:28 PM
Why are you using port injection and meth? For pump fuels you'd want to use a good meth kit. No need for PI.
sabujan sabujan is offline
Car: 335i f30 2012
Default 12-21-2017, 12:12 AM
Hi Terry
new logging with WOT -car F30 N55 PWG - 2013- JB4 - Pure stage 2 - Down Pipe & aFe
pls let me have your recommendations .. thx
Default 12-21-2017, 09:25 AM
Boost targets are too low to evaluate. The map2 log doesn't have much full throttle.
Car: F06 640I
Default 12-21-2017, 02:09 PM
Hi Terry actually my target is around 500 WHP so I was
Afraid from fuel
Do you mean that extra fuel causing kind of limitations and what is excepted Afr for that kind of setup
BTW I am running a flash tune on my ECU not a stock file
Default 12-21-2017, 02:12 PM
Afraid from fuel
The PI just complicates things if you are on pump gas already running WMI. Better to have a properly setup WMI kit with JB4 monitoring meth flow and progressively adding boost as a function of that flow.
Marlinman's Avatar
Car: 335i coupe 2010
Default 12-21-2017, 06:34 PM
At about 4K in fifth if I go WOT, the car will buck and throw a superknocking injector shutdown code. Obviously this concerns me, but if I ease into it in fifth and then open her up around 5.5 K it really doesn't happen so I'm hoping that its not a standing issue but rather me just demanding too much from the engine at a "lower" RPM in fifth gear. (running map 7 in iso with PS2, stock TMAP). I can say that in third and fourth when I do this from a "lower RPM" it is totally fine. The word "super" is concerning to me, any thoughts out there?
Default 12-21-2017, 06:35 PM
Log of the specific issue? If you have major knock codes that's normally very bad.
Marlinman's Avatar
Default 12-21-2017, 06:44 PM
Wasn't able to catch it in a log since it doesn't happen normally, also didn't want to try to induce it again since it scared me. Only happens in fifth, could I be demanding too much boost for my octane or for the gear at a specific RPM?
Marlinman's Avatar
Default 12-21-2017, 06:48 PM
Should I even be able to go WOT at 3k or 4k in 5th gear without any issues?
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default FW version ? - 12-22-2017, 01:51 AM
frimware :
16/7//3 this mean ver T_3
i saw it on my log
btw i remember my last FW was t_6
How can I check which version I have installed ?
thx
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
dror135's Avatar
Default JB went wrong - 12-22-2017, 11:15 AM
Something went wrong ...
Map 5 The unstable stable AFR Very low
TRIM is very high
What could be the problem ?
Default 12-22-2017, 12:05 PM
Absolutely.
Default 12-22-2017, 12:06 PM
TRIM is very high
Doesn't look that off to me?
dror135's Avatar
Default 12-22-2017, 12:26 PM
afr down from 12 and trim up over 40
its Never happened
now it map 6
my FOL set to 50 ( run with 98 octane)
dror135's Avatar
Default dme_bt drop - 12-23-2017, 03:43 PM
look at my log dme_bt drop my trim high
i set fOL to 70
but its not help ( trim )
why ?
Default 12-23-2017, 04:08 PM
its Never happened
now it map 6
AFR and trims are indexed on DME BT so if DME changes that then expect a matching change to the AFR and fuel trims. Randomly changing DME BT is something we expect to resolve with the back end flash map.
dror135's Avatar
Default 12-23-2017, 04:12 PM
i never flash my dme its stock
Car: 335i f30 2012
Default 12-24-2017, 12:57 AM
Merry X'Mas & Happy New Year to All
Hi Terry
How to go about now on my ISO settings
Marlinman's Avatar
Default 12-24-2017, 06:39 AM
Originally Posted by cnm135i
Can you do a good log in map2 and share that?
Still working on trying to get a full log in fifth gear in a safe area, it's been hard with weather. The attached though, is a log in fourth gear in map 2. Maybe that will lend some insight. So far, its been good to go with no ability to reproduce symptoms in fifth gear. Lesson learned about trying to get too much boost! Now if there is some looming issue like a failing injector or crappy coil pack, then that could still be possible I suppose, but I would have no way of knowing for now.
dror135's Avatar
Default 12-25-2017, 02:47 AM
sabujan
I see that you have the same problem as in my TRIM high and low AFR
Marlinman's Avatar
Default 12-25-2017, 10:20 AM
How do you like having BM3 and JB4 stacked?
Car: 335i f30 2012
Default 12-26-2017, 04:34 AM
sabujan
let us hear from Terry - my JB4 stage 2 board is the 1st one released ..its an earlier log
Default 12-26-2017, 09:54 AM
This log looks good to me, although it's not really full throttle.
Default 12-29-2017, 10:50 AM
Terry
Not prime-logs, but as per file description I did two experiments. All with flat 12.1psi map6.
Adder10 fuel bias100: With flow 12.1 to 13.5
Adder30 fuel bias stepped 40-60-80: With flow 12.1 to 14.9 to 16.3
Hope this can help you fine tune the feature
It seems to be generally working as intended looking at the log. Now it's just a matter of how much meth fluid you want to dial in at different engine speeds.
