(#676)
joshuan1122 joshuan1122 is offline
Car: e92 n55
Default 04-03-2017, 01:17 PM
Originally Posted by Bimmer_Boost
You can not flash your car with a BEF using the JB4. You will need to purchase MHD flasher in the app store. The BEF that BMS provides is free so other than the cables and potentially an android device the only other cost is the app. Exhaust burble is an option when flashing the car.
My advise would be to look up some videos to see if it will provide the sound you're looking for and to read through this thread.
so how do i go about doing this? how much would the obd to usb cost and how much would the app cost? are there like instructions or a video on this?
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 04-03-2017, 01:29 PM
This is a link to their thread. Since the flash is free you are looking at only the flash license cost, then hardware. Anymore questions regarding how to use MHD or what you need should be directed to them in their thread. You should be able to find most of your answers in their first post though.
http://www.e90post.com/forums/showthread.php?t=1318714
2011 E92 335i Auto
12.0 @ 125MPH JB4
12.6 @ 112MPH 92 Octane | 11.7 @ 120MPH E30 MHD
Custom MHD Tune | XHP Stage 3 | ER Chargepipe | VRSF 7in Intercooler | Methanol Injection | Performance Line D-P | Pure Inlet | Pure Stage 2 | Go Fast Bits DV+ |
2014 E84 X1 35i - Stock For now 13.9 @ 99MPH 293 AWHP 305 AWTQ
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 04-03-2017, 03:07 PM
any new maps coming or nah ? im eager to see if my car can be even better with new bms bef releases ?
Stoolz Stoolz is offline
Car: 11 135i
Default 04-03-2017, 09:49 PM
Dude there aren't going to be any revolutionary new flashes released. Only minor tweaks.
Default 04-04-2017, 03:34 AM
the impact of flash differences will be driven by MHD's ability to unlock tables.
I guarantee if MHD unlocks some cool stuff Terry will support. If you want to keep track of it, make sure to keep up with table discovery.
2012 N55 135I, Speedtech 7670, JB4 + MHD, Fuel-it port injection & stage 3 LPFP, M4 A2W IC, Mfactory LSD, KW V1, Apex EC-7
Default 04-04-2017, 05:09 PM
Id like to know what tweaks they are working on if possible you dig ?
Car: 11 135i
Default 04-04-2017, 08:57 PM
Yeah i dig but I think your expecting cool stuff and that cool stuff will come from MHD not BMS. BMS are only gonna massage stuff around and give us a solid tune. I for example would kill for a proper dct launch control.
primamateria's Avatar
primamateria primamateria is offline
Car: 11' 335i xDrive e90
Default 04-05-2017, 12:25 PM
Originally Posted by Peen
36BE is a silent code, happens while flashing. It happened on the 40min flash the first time I did the flash even when it said it cleared codes. Had to manually clear it.
I just have a feeling people who say power is less may have this code in background.
My car has more power everywhere with E85 MHD BEF vs PPK and no PPK flash.
I know this post is several months old, but I recently noticed 36BE popping up on the JB4 code screen on the mobile. Since it can't be cleared via the JB4 how would I go about clearing it manually? Appreciate it, thanks.
11' 335i xDrive e90,
JB4 ISO Map 7 @ 20psi, ISO_14 Firmware, BMS/MHD e85 BEF, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF **, VRSF 7in. FMIC,
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 04-06-2017, 02:45 AM
Clear DME codes with MHD engine of, ignition on like for flashing).
Default 04-06-2017, 03:37 AM
Cool, had no idea I could clear it with the MHD app. I mean - I've seen the codes tab but never had thought of using it to clear it since I tried clearing it with the JB4 mobile app to no avail. Appreciate it.
Xdrive35i2014 Xdrive35i2014 is offline
Car: X1 Xdrive35i
Default 04-07-2017, 07:13 PM
Is there a planned mhd flash release date for poat 2011 e series n55? Thanks
Car: 2011 e92 335i
Default 04-07-2017, 07:53 PM
Originally Posted by Xdrive35i2014
Is there a planned mhd flash release date for post 2011 e series n55? Thanks
Twisted tuning posted this. MHD appears to be close to releasing something.
"Ok, I've received numerous emails and PMs about this. But the time has come for the Late E-series owners that have been waiting anxiously yet patiently for MHD support of E-series N55 with build dates Post: 3-2012
Post up if you're one of these owners. Or tag and owner of you know them. Looking for a few more local owners to test the finalized process. Before full release.
#TwistedTuning #MHDflasher #N55 #bmw #*********** #e90post #bimmerboost"
2011 E92 335i Auto
12.0 @ 125MPH JB4
Car: X1 Xdrive35i
Default 04-07-2017, 08:25 PM
Thanks i cant wait!
lazer's Avatar
lazer lazer is offline
Car: 135i n55
Default 04-07-2017, 11:33 PM
Whats exactly the pump flash do? Good idea on stock turbo?
135i 2012 6speeds n55/FBO/ps1/inlet/stg2 lpfp/bms meth
Pump flash
Car: 2011 e92 335i
Default 04-07-2017, 11:35 PM
Higher boost, lower timing, more fueling control to keep trims and AFR in range.
2011 E92 335i Auto
12.0 @ 125MPH JB4
lazer's Avatar
Car: 135i n55
Default 04-08-2017, 12:06 AM
Cause i got like 14 15 timming ....more boost like what? We can use same octane on all map?
Pump flash
Car: 11 135i
Default 04-08-2017, 05:54 PM
Any Euro cars still getting 321F code or is it just me?
rhylea's Avatar
rhylea rhylea is offline
Car: BMW 335i N55
Default 04-08-2017, 10:27 PM
Stoolz, yes I got this code the other day. First time for me since the Euro-spec BEF came out. Have reset codes and wait to see what happens. See sig for more detail.
AUS 2011 - E92 - 335i - N55 - DCT - MSport
JB4 + FF Wires | MHD N55 BMS E85_PI BEF | aFe Power Magnum Stage 2-Si air intake | BMS Charge Pipe | Magnaflow 3-inch rear mufflers | NGK 5992s Gapped To 0.018"
Daily driven Map 7 running E85 at 55% | Settings: FW 5.16, DWP 60, PID Gain 25, FOL 90, WGA 80, Boost Safety 21
Car: 11 135i
Default 04-08-2017, 11:22 PM
Originally Posted by rhylea
Stoolz, yes I got this code the other day. First time ever for me. Have reset codes and wait to see what happens. See sig for more detail.
Ok must be evap stuff still in the flash then.
I've gotten it multiple times.
Another weird thing is twice in past 3 months on start up my car cranks and doesn't fire. I just stop it and repress and it fires straight up like normal.
No idea if it's flash related tho.
Default 04-09-2017, 07:02 AM
Check out the first page of this thread, it pretty much outlines the answer/s to your question.
Diox Diox is offline
Car: 2011 E90 FBO+JB4
Default 04-12-2017, 03:14 PM
Hi, I just did the BEF. I know that with just MHD and no JB4 you could pass state inspections (depending on state), but is this the same with a BEF?
I haven't had my CEL pop-up while I just had JB4 (I didn't have auto clear on, it just never came up). Now I am getting the error code for the ** (3106).
Do I still need to buy a ** fix or is there a way to be ready for the inspection?
orteeze orteeze is offline
Car: 08' 335i
Default 04-18-2017, 02:41 PM
Is is necessary to purchase the monitoring from MHD when running a BEF or will JB4 logs be sufficient when posting in support section?
E90 LCI M Sport
Default 04-18-2017, 02:59 PM
JB4 does all the logging, you do not need and will not use MHD monitoring.
swissi's Avatar
swissi swissi is offline
Car: e91 335ix
Default 04-27-2017, 02:01 PM
I have the same code like you.
BMW 2010 n55 e91 335ix, 6 AT xHP st.3, JB4 bef with connect kit rev.3 and FF wires, Pure st.2, pure hi flow inlet pipe, fuel it st.2 lpfp, bms wmi kit with 1 cn 5 in charge pipe, fuel it dpmi with 550cc injectors, aFe Magnum Force Pro 5r st.2 intake, Air Scoops, phx charge pipe, bms occ, wagner evo 1 comp fmic, c- less pipe, 98/100 oktane (vpower), 3.5 tmap.
Car: 11 135i
Default 04-27-2017, 11:40 PM
Hopefully Terry can remove that little gremlin next release.
