N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
tredirtyfive tredirtyfive is offline
Car: 335 E92
Tuner: none
Default BMW 4-LED bulbs Installed - 05-04-2012, 08:20 PM
So I put these suckers in today and the first thing I will say is...Holy Whiteness! They don't have that nasty cyan/greenish white like regular GP thunders or similar "whiter" bulb replacements. For now, I can only compare them to what I previously had on my 335i E92 which was dual LEDs from a member here and I totally forget the name as that was over 2 years ago. These are much brighter and much more accurately white. I will say it is still not perfectly even across both rings like pretty much all replacement bulbs outside of a full retrofit but I think they are better than the all the HID replacements. Plus they are inexpensive compared to most and do not dim from ON to OFF lighting and there is no flicker of any kind...radikus. So, for now, I'll flame-suit myself and declare these the best LED angel eye replacements you can get for your rides outside of OEM and retrofitting based on price and the support you've grown to know and trust from Burger. Also, lease excuse the crappy iphone pics but these are right out of cam and sized down, outside of the one i had to cover my plate.
cyrilB cyrilB is offline
Banned
Default 05-07-2012, 01:00 AM
Cool bulbs. I like it.
Car: 2008 BMW 535i Sport
Tuner: BMS, what else?
Default 05-07-2012, 07:00 AM
Are those the $129 BMS versions? Looks like they come with resistors.
Sleeper edition 5 series
Performance: JB4/G5 ISO w Cobb BMS flash, BMS WW Meth, BMS DCI, AR Design DPs, ER FMIC & CP, BMS OCC, RB turbos, Walbro LPFP, H&R Sport springs, Koni FSD shocks
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 digital preamp, Zapco Z8 DSP, Zapco Z-150.6 amp
Car: 335 E92
Tuner: none
Default 05-07-2012, 10:12 AM
These are the new 4-LED variants /w cylindrical ballasts (PnP)...so far so good.
rdeterman's Avatar
rdeterman rdeterman is offline
Car: 2008 335i
Tuner: JB4
Default 05-08-2012, 08:25 AM
i got a set a few wks back and i love them!
2008 335i Coupe 6MT
JB4 G5_FBO_BMS Cobb flash_Walbro 455_Spec S2+ Steel SMFW
CosmosMpower CosmosMpower is offline
Car: 07 335, 06 Elise SC, 06 Cayman S
Tuner: JB4
Default 05-08-2012, 08:29 AM
Are these straight p2p with no error codes etc?
Tuned1M's Avatar
Tuned1M Tuned1M is offline
Car: AW 1M
Default 05-08-2012, 09:25 AM
^ Yep. No issues with codes.
Meisterschaft GT exhaust l Meisterschaft non-resonated mids | H&R Sport Springs l ER CP w/Tial BOV | CP-E DCI | BMS AE
Tech112's Avatar
Tech112 Tech112 is offline
<---N55 turbo
Car: 135i N55 DCT
Tuner: bms
Default 05-13-2012, 06:40 PM
I just installed mine this weekend and love them also. The only thing is the inner ring is alot brighter the the outer ones.
2011 135i N55 DCT
12.669 @ 112.90
2011 BMW 135i DCT N55: 12.669 @ 112.900 MPH
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Tuner: BMS
Default 05-14-2012, 12:58 PM
Installed mine a few weeks ago. Looks waaaay better than the factory ones and are fairly easy to install. The center ones are brighter but so were the factory ones to an extent.
Do you guys ever get any flickering when the car starts? Only during cranking, they almost alternate like police lights lol.
-'08 135i - RB's, G5 ISO, BMS Flash, N20 MAP, VRSF FMIC, DCI, CM 2.2g CM14, VK DP's, Riss Racing Mid & axle-back, BMS OCC, Alpina AT Flash
-'08 135i (RIP)
-'95 ///M3 (sold)
Matt135i Matt135i is offline
Default 05-14-2012, 06:40 PM
I ordered mine and love them!
BTW for those who may encounter an error code, check the positioning of the ballast. I was getting a code at first, then emailed Terry and that is what he suggested. Sure enough it worked!
Car: 335 E92
Tuner: none
Default 06-03-2012, 07:40 PM
There is a very specific/optimal spot that most users with mini-ballasts are using without errors and obstruction which is on the bottom center of the cover (double-sided tape or industrial velcro). I'll have to dig for the image.
sam0329 sam0329 is offline
Car: BMW 135i
Tuner: Cobb
Default 06-25-2012, 10:18 AM
will everything sit inside the cover after install?
Car: 135i, 335i, X5D
Tuner: BMS
Default 06-25-2012, 10:26 AM
Yes all goes inside.
Home of the Worlds fastest N54s and N55s!
N54 Overall Traps World Record (11.33@132.78)__N54 Stock Turbos WR (11.25@122.86)__N54 AT Stock Turbos Traps WR (11.38@125.24)__N54 Twin Turbos WR (11.01@129.30)__N54 Stock Turbos 60-130 WR (8.39)__N54 Stock Turbos WHP WR (456whp)__N54 Stock Turbos+n2o WHP WR (542whp)__N54 Stock Turbos+n2o 60-130 WR (6.95)__N54 Stock Turbos+n2o WR (11.11@129.47)__N55 WR (11.91@117.81)__N55 WHP WR (399whp)__F30 WR(11.99@114.35)
Copyright © 2007 - 2013, N54tech.com
