N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
(#151)
robc1976's Avatar
robc1976 robc1976 is offline
Tuner: JB4 G5
Default 04-27-2012, 07:12 PM
Originally Posted by Vroom
I borrowed the right tools & practiced on a broken garage door opener.
Do it..
Then punch it & just hang on!
Wish I could find theses parts locally...I hate waiting....I was thinking maybe a TV repair shop might have this??
JB4 G5 ISO+BMS flash,Walbro 455 LPFP, DO meth kit 4-AN SS lines, BMS OCC, RB turbos W/3.5 N20 sensor, RB valve, BMS DCI, 3" AR kittyless Dps, Strett 2 oil OC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 Strut Brace, M3 front sway-bar, Meyle HD tie-rods, HPA rear toe arms, Wavetrac LSD, DEFIV differential kit, BC Coil-overs, Power-Flex subframe bushings, stoptech slotted rotors, Rogue Tranny Mounts, Concept 1 CS-5.0 rims,
robc1976's Avatar
Tuner: JB4 G5
Default 04-28-2012, 08:36 AM
Talking to a local TV repair shop to get the parts...he has a 15 ohm resistor but it is more then 5 watts....would this be a issue?
mykal335xi's Avatar
mykal335xi mykal335xi is offline
boom
Car: BMW
Tuner: BMS
Default 04-28-2012, 10:52 AM
I mailed mine into Terry, he did the 15ohm mod and the nitrous trigger wire for a reasonable price and had it back the same week
2008 335xi
11.81 @ 117.5
az335iat's Avatar
az335iat az335iat is offline
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 04-28-2012, 12:34 PM
Yes, any wattage larger than 5 watt is too large to fit on the board.
09 335i Coupe
JB4-G5 Iso, Pre & Post Turbo Meth,
DCI, FMIC, BMS AccessPORT, Alpina Flash
Sold 08 335i Sedan
12.035 at 118.14 1.92 60 foot
JB4, Meth, FMIC, Mr5 CAI
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Tuner: JB4
Default 04-28-2012, 05:08 PM
Originally Posted by steve.kodra
Did the garage door open? Would be a good indicator to proceed! :-)
HaHa,
I practiced removing & replacing components on the board, solder sucking and using copper mesh to clean up the problem holes. It was a confidence builder.
Vroom's Avatar
Car: 335i 318ti
Tuner: JB4
Default 04-28-2012, 05:14 PM
Not sure where you are at but here's where I got my stuff. No Credit cards and not the friendliest people to deal with but they had the resistors.
Tri-State Electronic Corporation
200 West Northwest Highway, Mount Prospect, IL
(847) 255-0600
robc1976's Avatar
Tuner: JB4 G5
Default 04-28-2012, 07:05 PM
(847) 255-0600
I ordered it....but I appreciate the info!!
Question guys, what kind of difference did you guys feel from this mod?
Vroom's Avatar
Car: 335i 318ti
Tuner: JB4
Default 04-28-2012, 07:30 PM
I have FBO & Meth & it made my car scary again. Also found out quickly that the OEM clutch could not hold the power in 3rd & 4th.
robc1976's Avatar
Tuner: JB4 G5
Default 04-28-2012, 07:40 PM
I am thinking it will do this for me since I am under target with a high Wastegate duty cycle of 130. Hopefully this helps...there is also the new board coming out soon to "G5"
robc1976's Avatar
Tuner: JB4 G5
Default 05-01-2012, 03:10 PM
Had the 15 ohm done by a local TV repair guy for $5.00 and I must say this mod made a bigger difference than Dps, FMIC....I pulled 4-5 car lengths on my buddy with the same car same mods same mix except he has 18 ohm. I guess my car really needed this..my Wastegate duty was at 130...will log tonight to see what it is now. The car pulls harder all the way thru the RPM range...more boost thru the range via my boost gauge also.
Vroom's Avatar
Car: 335i 318ti
Tuner: JB4
Default 05-02-2012, 06:17 AM
+1
MadMan77's Avatar
MadMan77 MadMan77 is offline
← Ex-Con
Car: JB 135i
Tuner: Un-Tuned ;)
Default 05-14-2012, 08:41 AM
Finally got decent enought weather to be able to pull my engine bay apart to do this mod. I am loving it but my already slipping clutch is hating it!
Vroom's Avatar
Car: 335i 318ti
Tuner: JB4
Default 05-14-2012, 09:40 AM
Join the crowd.
I put in a clutchmasters Stg. 3 w/ Fiber Tough plate. Worked fine on road course, plan to hit the strip in the next 2 weeks.
K20A2_S K20A2_S is offline
Tuner: jb4
Default 05-22-2012, 09:07 PM
I just did my first datalog, I had an ffmax wastegate adaptation value of 124. This is on fbo minus exhaust. I'm about to start running Meth in a week or two, I'm guessing this would probably take me over the 130 recommend limit.
Wonder if I should run Meth first for couple weeks to make sure its all running good, then do this mod.
Mods are jb4, bms dci, Vrsf downpipes, helix intercooler, synapse bov and chargepipe. 07 335I
Bms Meth kit very soon.
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Tuner: BMS
Default 05-23-2012, 02:58 PM
I just did my 15ohm mod but i used 1/4w resistor instead of 1/8w.......is that ok or do i need to change it? I do have the 1/8w resistor
az335iat's Avatar
Minor Diety
Car: 2009 335i AT
Tuner: JB
Cool 05-23-2012, 08:23 PM
If they fit on the board then you good to go.
09 335i Coupe
Sold 08 335i Sedan
atlninerfan's Avatar
atlninerfan atlninerfan is offline
Car: 2008 535i
Tuner: BMS
Default 06-15-2012, 05:08 PM
I'm planning on doing this mod tomorrow. How would I know if I did it wrong? Will the car start, just not go in command mode? I just want to be prepared for worst case scenerio.
joshwalker's Avatar
joshwalker joshwalker is offline
Car: 2008 Bmw 335i
Tuner: JB4
Default 08-09-2012, 12:21 PM
I just opened my JB4 to do this mod and it already has 5w 15ohm resistors? I bought the JB4 a week or so ago, the new ones already come with the upgrade?
2008 335i JB4 DP DCI Meth Tial BOV
Goose Goose is offline
Car: Space Gray e92 335
Tuner: Active Autowerke & BMS
Default 08-09-2012, 01:45 PM
just ordered my G5 upgrade
waiting patiently for them to get back in stock
bmw loe bmw loe is offline
Car: e92 N54 335i
Default 08-10-2012, 08:34 PM
for those that done this with FFMAX stuck @ 130 with an 18ohm board, what did your FFMAX value drop to with a 15ohm board?
robc1976's Avatar
Tuner: JB4 G5
Default 08-10-2012, 08:51 PM
Mine dropped to about 120....got the G5 board and here are in the 52-55 range!
steve.kodra's Avatar
steve.kodra steve.kodra is offline
IXLR8
Car: 335xi
Default 08-10-2012, 09:19 PM
Ditto! What Rob said.
(07 335xi AT) RB's and Stuff
(12 X5d) JBd
robc1976's Avatar
Tuner: JB4 G5
Default 08-10-2012, 09:55 PM
It is awesome!!!
Vroom's Avatar
Car: 335i 318ti
Tuner: JB4
Default 08-11-2012, 05:26 AM
From mid 120's to 90's w/ 15 ohms. Hi 40's low 50's w/ G5.
jlcolon2001 jlcolon2001 is offline
Car: 335i 2007
Tuner: BMS (JB4, DCI, WW Meth, BMS OCC)
Default 08-11-2012, 08:28 AM
Mine is 129 right now. I will report back when I install the G5 that Terry sent me a couple of days ago
Copyright © 2007 - 2013, N54tech.com
