N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Tuner: JB3 2.0, map#8+meth
Default Continental extremcontact DW or Hankook ventus v12 - 02-20-2012, 07:18 PM
for same price...your opinion
thanks
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB3 2.0|Unlocked 18ohm Board|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, 11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 10.18
kickit's Avatar
kickit kickit is offline
Tuner: JB4
Default 02-21-2012, 11:58 AM
Can't comment on the conti, but I really like my ventus v12's. For the price, hard to beat. On my second set. Rears last me about 25k and the fronts 35k. Handle well, decent ride and grip well. Maybe not corner quite as well as the OEM runflats IMHO.
bluescoupe bluescoupe is offline
Tuner: BMS
Default 03-03-2012, 04:35 AM
Have Continental DWs on Audi B6 S4, and Hankooks on Audi B6 A4.
Both good tires.
The DW's should probably get the nod for your car though.
A little stiffer sidewall.
Never give up, never surrender...
elsabor67's Avatar
elsabor67 elsabor67 is offline
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Tuner: Schaefer Clubsport/BMS
Default 03-17-2012, 12:21 PM
I own Conti DW's for the last 2 years and the handling and grip is superb. Wet traction is fenomenal. I also used them for some laps last year on the 'ring and they are excellent.
You will not be dissapointed.
Autobahn.......its what's for dinner!!!
Robertbenson30 Robertbenson30 is offline
Car: 08 135i
Tuner: BMS JB4
Default 03-19-2012, 10:54 AM
I have the hankook v12s. Very good tire. Great wet traction. Conti DW's are good to from what I hear. You wont be disappointed with either tire.
JB4 15 Ohm | AR DPs | Helix FMIC | Cooling mist CM10 | Injen DCI | RR Mids & Axel Back | SF-71s 19s with Hankook V12s (For Street) | Mickey Thompson ET Streets 245/40/18 (For Track) |
Best: 12.0 @114 1.88 60' @5800ft D/A
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Tuner: BMS
Default 03-19-2012, 01:22 PM
Havent ridden on the stock Conti's but have v12's on the car now. They get my approval.
-'08 135i - RB's, G5 ISO, BMS Flash, N20 MAP, VRSF FMIC, DCI, CM 2.2g CM14, VK DP's, Riss Racing Mid & axle-back, BMS OCC, Alpina AT Flash
-'08 135i (RIP)
-'95 ///M3 (sold)
themyst themyst is offline
Super Demigod
Tuner: Cobb
Send a message via AIM to themyst
Default 03-19-2012, 06:21 PM
Hancrap tires are the WORST for straight line traction. Those tires are made of plastic or something and refuse to heat up. I know two people who ran those tires because they were a good "value" tire and got their money's worth.
On the N54, I've run the OEM RFTs (not bad actually), Dunlop Direzza Z1 StarSpec (AMAZING lateral traction but extremely noisy and hum like bad bearings after some miles) and the Continental DWS (the perfect all-season tire).
Although I've never run the DW, the DWS can dead hook with 410-420 whp in 20 degree ambient temps from a 40 roll. I've cut 1.9 60fts with my automatic in similarly frigid temps.
E90 LCI N54 6AT
bmw loe bmw loe is offline
Car: e92 N54 335i
Default 03-21-2012, 05:12 AM
I don't like the V12's either, they are too soft in sidewall structure that the car will feel floaty and your steering response goes to crap, especially after coming from the stiffer sidewalled Bridgestone RE050A RFTs.
According to tirerack, the conti DW's aren't any better in sidewall stiffness.
MathR601's Avatar
MathR601 MathR601 is offline
Tuner: Burger Motorsports
Default 03-22-2012, 07:52 AM
Did not try either of these but I need new rubbers so I read about them a lot.
I will probably go with the the Conti DW.
I heard at first they feel very soft for cornering but after a while they get stiffer.
The wear rate is better for the Continental: 340 versus the V12: 280.
They are both a lot more comfortable than the stock runflat.
Stockies being runflats, the sidewall is really really stiff so there is no lag when turning. You should expect some lag with non-runflats...
TERARMT TERARMT is offline
Car: nissan
Tuner: レッドストーン RMT 買取
Default 04-09-2012, 10:57 PM
TERA RMT
ラグナロクオンライン2 RMT
RO2 RMT
レッドストーン RMT
REDSTONE RMT
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Tuner: BMS
Default 04-12-2012, 09:48 AM
Hankook V12's are horrendous for traction like others have said... they make a rs-3 that you may be interested in and may hook better but wet traction will not be nearly as good...
I had continental DWS on my OEM wheels and went with Kuhmo Ecsta XS on my advans and despite tons of reviews on how good the XS' were they are WORSE than the DWS in every aspect except for high speed lane changing and cornering due to a nice stiff sidewall... I regret not going with DWS' instead of them... and to top if all off the DWS is the LIGHTEST tire pretty much on the market... 5 lbs lighter PER TIRE than the hankooks in a 265/35/18 size
08 JB4 135i 6M - 12.0@120mph - SOLD
09 e92 7AT - Terry Based Cobb/G5- 11.9@119.6
MathR601's Avatar
Default 04-12-2012, 10:35 AM
Nice info
But it is about Continental DW not the DWS.
According to tirerack:
DW: Max Performance Summer
DWS: Ultra High Performance All-Season
blackshan blackshan is offline
Car: 335i coupe
Tuner: bms
Default 04-23-2012, 09:20 PM
Dw's all the way! V12s traction wasn't very good! All my opinion but from experience.
jb4 G5 fbo with Bms flash e85 and meth!
gbk99's Avatar
gbk99 gbk99 is offline
Car: 2008 e92
Tuner: BMS
Default 04-26-2012, 07:44 AM
I have Continental DWS as well, can't complain at all. Really good performance in all weather, really sturdy sidewall which is good. I bent a rim but no bubbles on the side
Ian Ian is offline
Car: 09 335i
Tuner: Cobb
Default 05-11-2012, 03:45 PM
I ran the Conti's on my M3, I had good experience with them. Decent grip, fantastic wet performance, wear was decent for what they are. I managed like 8-9k miles out of a set of rears and 18k or so from the fronts. To note, I am NOT talking about DWS's, I am talking about DW's. HUGE difference.
I personally would never buy Hankook anything. That's just my personal preference.
If I were you, I would spring a few hundred more for Pilot SS's.
zzz04pt's Avatar
zzz04pt zzz04pt is offline
Car: 2008 335i Sedan
Tuner: JB3
Default 06-22-2012, 07:05 AM
I had the V12 Evo's and they really do suck in straight line traction. They were great in the rain but the OEM runflats had much better dry traction. I ended up putting on Bridgestone RE-11's and have loved them so far.
Mods: JB3 1.4, BMS DCI
12.7 @ 112 on Map 8 w/ 100 octane.
BMS Meth kit keeping her cool.
LostMarine's Avatar
LostMarine LostMarine is offline
Stalker
Car: E92 DCT ///M
Tuner: BMutha****inS
Default 06-22-2012, 04:09 PM
V12s are awesome, except for straightline traction. quality/feel/noise/steering is all good with v12s, except straightline, dont know why, but its true
E92 DCT M3
Evolve SuperCharged
Copyright © 2007 - 2013, N54tech.com
