N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
Dr3K0 Dr3K0 is offline
Tuner: BMS
Default Help with lower springs. - 05-15-2011, 12:09 PM
Hi guys, I’m in the middle of a dilemma.
I installed an H&R Cup kit to my 135i and it looks awesome but I have some issues. I installed some VMR 701 and the car is rubbing, as expected. Took the car for fender roll but it still rub if I corner too hard or somebody is on the back.
After some thought it seems to the rear compress a lot it almost get close to the wheel. I believe the rear shocks are under damper for the springs. I was thinking to buy the koni yellows and set them to a stiffer setting to control the damping travel.
Am I correct on my idea?
Other hypothesis is that the rear springs for some reason are softer than should be.
I was about to put my stock suspension back but stop and think about this issues.
All help is welcome.
Dr3K0
Okman335 Okman335 is offline
doodoomeat
Tuner: BMS
Send a message via AIM to Okman335
Default 10-23-2011, 04:27 PM
Dr3K0
Thats the problem with springs, your better off with coil overs so you can adjust height and rebound. If I were you I'd sell your springs and run stock until you can scrap up enough for a good set of coil overs, H&R and anything from the KW line are very reputable brands and would be your best bet.
Hope I could help.
Copyright © 2007 - 2013, N54tech.com
