Car: 135i, 335i, X5D
Tuner: BMS
"Hot air intake" myth testing -- Revisited -
09-20-2011, 12:02 AM
It's been around three years (!) since we did our first intake air temperature testing which showed open element intakes do not result in higher air intake temperatures or "heat soak" as many assumed they would. But back then when we did the original testing the car had a larger intercooler which many felt skewed the results and the testing was done with an OBDII tool which was a little difficult to read. We also omitted the critical "stuck in traffic" test.
So for this round of testing we used our 135i which happens to be 100% stock at the moment aside from the JB4 using 91 octane + NOS octane booster (~93 octane). I've been testing map 2 with a default CPS offset lately so kept that all the same between both tests.
The two sets of tests were performed within 20 minutes of each other under identical conditions. First I did a 40-110mph sprint (on a safe private road) to evaluate the intake temperature increases throughout the run. Secondly an 8 minute (limit of JB4 logs) driveway test simply logging the car with the hood down and AC on to monitor intake temperatures at rest.
According to "hot air" conspiracy theorists the dual cone intake should result in higher intake temperatures during the wide open throttle run, no power gains, and heat up dramatically sitting in the driveway soaking up all that engine heat.
First up: Stock intake system
Next up: BMS Dual Cone Intake
Results:
I hate to say it again but the results were exactly as expected. The DCI did not produce higher air intake temperatures at wide open throttle, did not heat soak more sitting at a standstill for 8 minutes, and all around felt faster. I should also add it's certainly possible modifying your OEM airbox with an extra filter might offer minimal gains over a dual cone intake assuming you don't mind up cutting up your factory airbox but don't expect much. We've tested this as well with no significant performance gain over a DCI in 40-120mph VBOX times. You have a lot of options for intakes but three+ years later the tried and true DCI is still the intake of choice for those of us who are serious about performance...
Home of the Worlds fastest N54s and N55s!
N54 Overall Traps World Record (11.33@132.78)__N54 Stock Turbos WR (11.25@122.86)__N54 AT Stock Turbos Traps WR (11.38@125.24)__N54 Twin Turbos WR (11.01@129.30)__N54 Stock Turbos 60-130 WR (8.39)__N54 Stock Turbos WHP WR (456whp)__N54 Stock Turbos+n2o WHP WR (542whp)__N54 Stock Turbos+n2o 60-130 WR (6.95)__N54 Stock Turbos+n2o WR (11.11@129.47)__N55 WR (11.91@117.81)__N55 WHP WR (399whp)__F30 WR(11.99@114.35)
Car: 2009 135i
Tuner: Dinan
09-20-2011, 04:10 AM
Great thread. I have a BMS DCI and I'm glad I bought it!
Car: E92- 335i
Tuner: JB
09-20-2011, 04:47 AM
Just curious what the ambient temps were..
Car: 335i M sport
Tuner: bms
09-20-2011, 07:28 AM
Originally Posted by dzenno
Would've been nice to see mr.5 intake results in there as well but good data in any case, thanks
He's saying there isn't significant gain over DCI, but I guess there is some, just for some it's not worth it to cut the stock box for.
Tuner: procede
09-20-2011, 07:31 AM
thanks Terry for sharing this
Car: 2008 BMW 535i Sport
Tuner: BMS, what else?
09-20-2011, 07:36 AM
How much power do the DCI add over stock airbox? I saw some graphs on that once but can't remember where.
Sleeper edition 5 series
Performance: JB4/G5 ISO w Cobb BMS flash, BMS WW Meth, BMS DCI, AR Design DPs, ER FMIC & CP, BMS OCC, RB turbos, Walbro LPFP, H&R Sport springs, Koni FSD shocks
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 digital preamp, Zapco Z8 DSP, Zapco Z-150.6 amp
09-20-2011, 07:43 AM
great test. what was the outside temp?
07 335i AT - TD St.2 Turbos - COBB (Custom Cobb mapping by http://www.protuningfreaks.com/) - JB4G5 - Ported Head - Okada Coils - NGK 5992 Plugs - Injen Intake - Helix IC - Snow Stg. 3 - Stett CP - AR DPs - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
Car: 2009 335i M Sport sedan
Tuner: BMS
09-20-2011, 07:50 AM
So a vendor does a test showing that it's own product does not suck.
I felt the difference on my own, no need for vendor's own tests to make me believe. I bought an Injen intake to replace my stock airbox and after 3 days I was looking for ways to do the Mr.5 modification.
metanol pawa!!
Tuner: jb4 G5
09-20-2011, 08:00 AM
Thank you for sharing this experience
Time is the best teacher
Car: FBO 335xi w/FSB 50/50 meth
Tuner: JB4
09-20-2011, 08:09 AM
Looks like ignition advance recovered to a higher amount post shift with the DCI as well.. is this consistent, or just a fluke captured in the logs?
Tuner: BMS
09-20-2011, 09:24 AM
70-72 degrees.
Tuner: BMS
09-20-2011, 09:25 AM
I'm testing some "too hot for my mods" settings and cylinder1 advance has not been overly consistent from run to run. There should be some reduction in advance due to the increased intake flow there but nothing significant.
Tuner: BMS
09-20-2011, 09:28 AM
I don't have the exact data handy but we did a series of 40-120mph runs and one or two of the runs gave identical times to the DCI and one or two were a tenth of a second quicker. Overall we decided the gains were not significant and consistent enough over the $95 DCI to justify offering a $500+ Dinan style intake (which was what we were evaluating at the time). Mr5 is just a home made version of the Dinan. I like the concept of it and would encourage anyone who doesn't want a DCI to go that route. It's much better than wasting your money on an AFE, Injen, etc, which are essentially less efficient versions of the $95 DCI, as so many do.
Tuner: BMS
09-20-2011, 10:40 AM
It all depends on the boost levels and engine RPM. I've posted charts before showing 25whp gains at high RPM at 17-18psi boost levels. But for the typically map 1 or map 2 driver the gains are around 5-10whp from 5500rpm to redline. We have a few dyno charts at lower boost levels but most of those are from before the JB4. So I hope to hit up the dyno this week or next to do some more stock vs. DCI comparison testing on a 100% stock car for the website.
metanol pawa!!
Tuner: jb4 G5
09-20-2011, 10:52 AM
will be interesting to see how go it with the JB4, though I doubt that the records vary.
Car: 335i M sport
Tuner: bms
09-20-2011, 11:33 AM
Yeah fukk that I already sold mine and made profit, it just didn't feel right having a $650 intake. I want to make the Mr.5 one
Car: 2008 335xi
Tuner: JB4
09-20-2011, 11:37 AM
Love the dirty DCIs! That alone should put the conspiracies to rest.
Car: ML63_335i
Tuner: Terry
09-20-2011, 12:53 PM
Nice info Terry!! love these tests.
Current: ///M5 || ML63 AMG
Retired: 2007 E92 335i || 2010 335i E90 LCI M-sport
ElevenPointFive
Car: 2009 135i
Tuner: BMS
09-20-2011, 03:29 PM
Thanks for the test, I look forward to seeing this on myth busters
Car: 2007 335i 6MT
Tuner: BMS
09-20-2011, 05:43 PM
I love my DCI. I love the sound. I love how simple it is. I love the price compared to other stuff out there.
I'm not cutting up my intake. I'd like to keep the option to go back to completely stock at any time.
Maybe I could make 2 more hp with a Mr. 5. Maybe I could go 60-130 .2 seconds quicker. In my opinion though, it's not worth cutting up my stock air box.
(Not to take away from Mr. 5. I have a lot of respect for people who take initiative to do their own thing and succeed.)
Tuner: BMS
09-20-2011, 08:43 PM
Originally Posted by boom
There is always room for dissenting opinions.
Just keep in mind there are a lot of variables at play. Just doing a cursory look at your first post there it appears there is a good deal of run to run variance, and that the DCI and stock airbox eventually trapped within 1/2mph of each other in the end. IAT deltas look similar and you are using a load based tune.
Using a load based tune the DME will simply raise boost to compensate for increased compressor outlet temperatures and reduce it to compensate for reduced outlet temperatures, so unless you are operating at the edge of efficiency it's harder to spot a net performance gain.
Like I said I like the Dinan/Mr5 concept and if someone wants to go that route I have nothing negative to say about it. But for maximum performance we've found the DCI to operate at the same level for a lot less effort and cost.
Car: 135I 6SPD
Tuner: none
09-20-2011, 10:06 PM
Nice post  I've been wanting to get the DCI but is it worth it being stock? What kind of gains should be expected? Also, some people say engine responsiveness improves a bit and others say the opposite... any input on this? Sorry for the noob questions. I just might order DCI this weekend, for 95$ seems like a pretty good deal.
Tuner: BMS
09-20-2011, 10:21 PM
Power gains are minimal stock but it sounds and looks good. There is no significant change to response either way at lower boost levels. I personally think people get caught up with the sounds, their opinion on hot air, and "feel" response is improved or degraded depending on their particular viewpoints. The flow differences do not become significant enough to "feel" until higher RPM and higher boost levels.
Tuner: procede
09-21-2011, 03:35 AM
can be cleaned with KN kit
| Thread Tools |
| Display Modes |
Copyright © 2007 - 2013, N54tech.com
