N54TECH.COM : BMW N54 / N55 Turbo Performance forum
elitt13's Avatar
elitt13 elitt13 is offline
Car: bmw 335i E92 Pack ///M
Tuner: wait and see
Default suspension and brake M3 or "BMW Performance" on 335i - 01-14-2010, 03:33 AM
Hello,
I have a question about the suspension and running gear of the 335i
I have a E92 pack/ / / M since September 2007, and I am under contract "serenium" guarantee until September 2011.
I run on track, and I would like to improve the suspension bearing products bmw.
THERE has someone tried to mount M3 E92 suspensions or suspensions "bmw perfomance" no concession available for 335i in France ditto for brakes
thank you in advance for your answers, if you have pictures of the assembly I am taker
I looked at several posts in the forum, but I have not had confirmation yet
PS : sorry for my english
Matt@Camber-Toe Matt@Camber-Toe is offline
Tri-state installer
Car: E28 535
Tuner: BMS
Send a message via AIM to Matt@Camber-Toe
Default 03-07-2010, 08:23 AM
I know of someone who has done M3 bits, but because of the longer arms the camber is increased greatly, and even when using the factory adjustments, the lowest camber in the front is about 1.8 degrees..it will increase tire wear considerably.
JPSlick's Avatar
JPSlick JPSlick is offline
$90 Canbus HID BNIB FS
Car: 2009 335i 6MT
Default 03-08-2010, 10:55 AM
Matt I know you know a thing or 2, but I've ran upwards of 2.5 degrees in my cars in the past with no abnormal tire wear so as long as the toe is set to 0 degrees.
2009 335i Coupe Sport 6MT-
2002 RSX Type S Supercharged/Nitrous-Sold
My Vids
For Sale $95 Full LED Interior Save 20% On Your Electric Bill $69 LED Angel Eyes BNIB
Tri-state installer
Car: E28 535
Tuner: BMS
Default 03-08-2010, 07:00 PM
short term its not a big deal, if you run 2.5 degrees over a considerable length of time (20-30k miles) you will wear the inside of the tire first. How do I know? Because I had it set that way on my own 335. at 25k miles the inner sidewalls were bald...and yes my toe was set to less than 1/8" toe-in in the front.
JPSlick's Avatar
Car: 2009 335i 6MT
Default 03-09-2010, 07:22 AM
I guess BMW's are different then Acura
50K -2 Degrees Camber in Front, 0 toe, 245 Wide Tires, 50K. Went through 2 sets of tires but always wore even. Kuhmo MX.
I guess I got lucky
My Vids
Tri-state installer
Car: E28 535
Tuner: BMS
Default 03-09-2010, 12:47 PM
Originally Posted by laloosh
I'm with Jpslick. Never had an issues if my toe was 0. This is on multiple cars btw. Current I am running -2.7 on the 135. Its been 10k miles and I'm showing zero abnomal wear. Then again if we are talking about upgrading suspension pieces, getting 25-30k out of tires shouldn't be your goal in the first place lol.
exactly...plan to sacrifice tire life for cornering ability
vB code is On
Copyright © 2007 - 2010, N54Tech.com | BMW N54 / N55 Engine Forum
