N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
Car: 135i, 335i, X5D
Tuner: BMS
Default JB3 NX Nitrous Testing & New N54 dyno record - 05-25-2010, 10:23 AM
JB3 NX nitrous integration FTW?
Just got back in the office. Much data to dig through. But the objective of today's tuning session was to identify the fueling limits and I think we found one. I'll modify this post as I go through more data.
The car:
Our automatic 135i
The mods:
JB3 18 ohm board, 1.2k fueling resistors
NX dry nitrous kit. Simply the best hardware out.
Coolingmist meth injection, 100% meth
AR nitrous/meth elbow
3" ******* downpipes
Code3 IC
BMS DCI
97 octane
Drag radials
Worth noting:
Stock 135i single 2.75" catback system
Stock midcats
No golf tee mod
We prefer our cars quiet and odor free.
I did a couple baseline runs on map 9 just to see how the air/fuel ratio would track through the tailpipe sniffer with cats. I found it wasn't very accurate/stable until around 4000rpm. Probably a combination of the lower load you see on the dynojet, a questionable tailpipe sniffer, and the cats impacting things. Ideally one would want to sample the air/fuel from a dedicated wideband bung close to the turbo. But this will have to do for now.
Run_002 was a baseline done on map 9 using our new fuel tuning with a taper value of 10. I did a couple runs and the air/fuel was about identical.
Next I did a couple tuning runs to dial in the JB3's nitrous control. For the purposes of this test it's simply acting as a wot / window switch. But on the road there are some important benefits. We can talk about that later.
Run_005 was on map 10, 35 jet, 900psi bottle pressure, 2000ml/min of meth (maxed out). Fuel mapping/meth volume was unchanged from Run_002. Interestingly the fuel pressure held very well through the run but following the air/fuel trace you can see we're leaning out at this power level despite a ton of methanol. I suspect we're at the limit of the injectors.
Just to make sure I cranked the bottle pressure up to 1000psi and did another run. Sure enough the air/fuel leaned out further.
I have a lot of other data I need to dig through but this should answer most of your questions.
PS. New record?
Home of the Worlds fastest N54s and N55s!
N54 Overall Traps World Record (11.33@132.78)__N54 Stock Turbos WR (11.25@122.86)__N54 AT Stock Turbos Traps WR (11.38@125.24)__N54 Twin Turbos WR (11.01@129.30)__N54 Stock Turbos 60-130 WR (8.39)__N54 Stock Turbos WHP WR (456whp)__N54 Stock Turbos+n2o WHP WR (542whp)__N54 Stock Turbos+n2o 60-130 WR (6.95)__N54 Stock Turbos+n2o WR (11.11@129.47)__N55 WR (11.91@117.81)__N55 WHP WR (399whp)__F30 WR(11.99@114.35)
Sticky Sticky is offline
Minor Diety
Car: M3
Tuner: N54? LOL
Default 05-25-2010, 10:24 AM
I'm aroused.
enrita's Avatar
enrita enrita is offline
Default 05-25-2010, 10:27 AM
thats just beautiful Terry! when you can tune thats the result
07 335i AT - TD St.2 Turbos - COBB (Custom Cobb mapping by http://www.protuningfreaks.com/) - JB4G5 - Ported Head - Okada Coils - NGK 5992 Plugs - Injen Intake - Helix IC - Snow Stg. 3 - Stett CP - AR DPs - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
ar design ar design is offline
9 seconds or bust.
Car: N54, M10, ALH/AEB
Tuner: Red Bull
Send a message via AIM to ar design Send a message via MSN to ar design Send a message via Yahoo to ar design
Default 05-25-2010, 10:31 AM
Wow!!!!!!!!!!!!!!!!!!!!!!!!!!
andrew | andrew@ardesign.info | tel. 303.351.3515| www.ardesign.info
powering some of the world's quickest and fastest N54s | home of the world's most powerful n54 530whp/550wtq @20psi
Bowser330 Bowser330 is offline
N54TECH FTMFW
Car: E92 335i
Tuner: BurgerTuning.com
Default 05-25-2010, 10:34 AM
holy crap
lamia2super lamia2super is offline
Car: 335I
Default 05-25-2010, 10:39 AM
Wow! Nice!! what size shot is this?
Down4it's Avatar
Down4it Down4it is offline
Tuner: Burger Tuning
Default 05-25-2010, 10:51 AM
Whoa!
S281E
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 07 Dinan S-335xi
Tuner: BMS
Default 05-25-2010, 10:53 AM
Congrats!
AT or MT?
07 E90 Dinan S-335xi *12.7@108mph * Pass Vids: External * In-Car | 91 E30 318iS * 117whp / 114wtq (SAE)
shyestsparks shyestsparks is offline
Default 05-25-2010, 10:48 AM
Wow, very nice; jet size? A/F ratio? Congratulation.
DBFIU DBFIU is offline
Joose Bocks
Car: 135, AT, JB3, DCI...
Tuner: BMS
Default 05-25-2010, 10:54 AM
Fack.
onefastman onefastman is offline
Car: 2009 135i 6mt 2011 m3 dct
Tuner: Terry :)
Default 05-25-2010, 10:56 AM
God dam terry. You make me happy to be a jb3 user, the future looks bright!
tek818 tek818 is offline
Car: E92 335i MT
Default 05-25-2010, 10:57 AM
jaw dropping...
Tuner: Terry :)
You need to go find some super cars to play with
ocbimmer ocbimmer is offline
Car: 335i E92
Tuner: jb3
Default 05-25-2010, 10:59 AM
Omg!!!
'09 335i E92, Space Gray, Sport, Premium packages, BMS DCI, JB4, BMS/CMGS Meth kit w/ CM10+CM7 dual nozzle, Quaife LSD, AA DPs, Yokohama Neova AD08 tires
best 1/4 ET: 12.47 on street tires
best 1/4 trap speed: 115mph
kennejp kennejp is offline
Default 05-25-2010, 11:06 AM
Wow thats awesome is that on the stock turbos? Is meth being used also? How big of a shot was this? Any more info on the car and setup would be great
LostMarine's Avatar
LostMarine LostMarine is offline
Stalker
Car: E92 DCT ///M
Tuner: BMutha****inS
Default 05-25-2010, 11:07 AM
^--- thats why its called a "Teaser"
E92 DCT M3
Evolve SuperCharged
R1000K3's Avatar
R1000K3 R1000K3 is offline
Car: 335i -07 MT
Tuner: Procede Rev II and JB3 2.0
Default 05-25-2010, 11:17 AM
Good power, that car must be incredible strong Ideal and affordable solution for quick quater mile blasts. 10 second ET's will soon become more common.
335ievo 335ievo is offline
Default 05-25-2010, 11:28 AM
holy...I think I need to go change my pants
ktmsmr12's Avatar
ktmsmr12 ktmsmr12 is offline
Tuner: Terry @ BMS
Default 05-25-2010, 11:18 AM
Terry,
Why are you showing these guys a dyno of my new Echo weedeater ;-)
2Slow's Avatar
2Slow 2Slow is offline
Velocity Challenged
Car: 2007 335i AT
Tuner: BMS
Default 05-25-2010, 11:27 AM
This is a big teaser, I can't see anything!!! Is there a dyno graph or something?
SlicktopTTZ's Avatar
SlicktopTTZ SlicktopTTZ is offline
Turbo Lover
Car: 300zx TT, 1M
Tuner: 361 Motorsports
Send a message via Skype™ to SlicktopTTZ
Default 05-25-2010, 11:31 AM
Strange, I don't see anything either.
Haha, talk about the ultimate teaser!
Tuner: BMS
Default 05-25-2010, 11:35 AM
Thanks guys. Added some more data.
2Slow's Avatar
Velocity Challenged
Car: 2007 335i AT
Tuner: BMS
Default 05-25-2010, 11:46 AM
Looks like I am going to need a secondary nozzle, STAT!
T, when you say you maxed out the meth, you mean your nozzles, not the pump, right?
Tuner: BMS
Default 05-25-2010, 11:48 AM
Meaning the two large nozzles running at close to 250psi on the pump. Honestly I don't know what the pump can flow, limitations of the lines, etc. But the CMGS gives you flow in ml/min.
Turbo Lover
Car: 300zx TT, 1M
Damn, that is a lot of mid-range torque for a 3.0 motor. Wonder how much the top-end would gain if it wasn't pushing through the stock mids and cat-back.
Copyright © 2007 - 2013, N54tech.com
