darth_bimmer88's Avatar
darth_bimmer88 darth_bimmer88 is offline
Car: 2008 335i E92
Default 10-28-2017, 12:16 PM
Alright so I came across a strange issue and can't figure out if this could be related to the Anti-Lag install, or if something else happened.
Just installed the kit this morning with chip and jumper wire. Works just as it should and confirmed with timing in the dash that it was working as it should with timing dropping to zero as I was on the brake, holding the volume down button, and flooring it.
But my I now no longer have AM/FM signal available. AUX port works just fine. Steering wheel volume buttons and track buttons work just fine. Every other thing in the car works perfectly fine, but after this install my car will not recognize AM or FM signals. As the Anti-Lag install and this issue happened simultaneously, I'm trying to figure out how one could impact the other.
Any thoughts?
