spoonie spoonie is offline
Default 09-07-2017, 09:20 PM
Just installed Jb4 and the anti-lag chip
If using the bluetooth rev3, can I use that to connect the black wire, or is the USB to serial required?
I did the install and could not connect to bluetooth, I ended up swapping the chip back to the old and disconnecting the black wire from the BT rev3 go get things working - However, I may of swapped in the old chip into the other socket (closest to large data connector) but all works (except anti-lag) that possible?
Is there a way to verify I have the correct chips in the right sockets?
